SMSL M300 SE DAC Headphone Amplifier 2x CS43131 XMOS Dual Clock NDK Bluetooth 5.0 32bit 768kHz DSD256 MQA
The SMSL M300 is a powerful and compact DAC in an atypical format. Integrating high quality components, it is the perfect ally to offer your HiFi audio system a digital-to-analog converter capable of reproducing your audio files with both a beautiful transparency and an astonishing sound richness.
4.0 / 5
Reference : 17731
129,00 €tax incl.
107,50 € tax excl.
Shipping date: 16-07-2025.
SMSL M300 SE
 DAC / Headphone Amplifier 2x CS43131 XMOS Dual Clock NDK Bluetooth 5.0 32bit 768kHz DSD256 MQA
SMSL M300 SE DAC / Amplificateur casque / Préamp 2x CS43131 XMOS Double Horloge NDK Bluetooth 5.0 32bit 768kHz DSD256 MQA
SMSL's M300 SE is a powerful and compact DAC with an atypical form factor. Integrating high quality components, it is the perfect ally to offer to your HiFi audio system a digital/analog converter able to reproduce your audio files with a beautiful transparency but also an amazing sound richness. It  also features a tempered glass panel giving it a high-end and durable look.
Dual CS43131 DAC, MQA decoder & high-end components
The M300 SE is equipped with 2 high-end CS43131 DAC chips. The latter supports high sampling rates, in PCM up to 32bit 768kHz and in DSD up to DSD256.
These high performance chips allow it to ensure a high SNR (131dB) and a very low distortion (THD+N -117dB) for a neutral and precise reproduction, with a beautiful sound image.
They are associated with many quality components such as a third generation USB XMOS interface, two Japanese NDK ultra low phase noise clocks to limit considerably the jitter on 44.1kHz / 48kHz and multiple frequencies, and finally a series of resistors and capacitors specially designed for audio use. In addition, an MQA decoder will allow you to enjoy the best audio files.
Bluetooth 5.0
The M300 SE has a bluetooth 5.0 chip working with an antenna and allowing a range of up to 15m for a stable and fast transmission.
Pure DAC preamplifier function
The M300 SE can deactivate its volume control in preamplifier mode and keep its output power at 4Vrms (XLR) or 2Vrms (RCA). The M300 SE works then as a pure DAC
Powerful headphone amplifier
With its two headphone outputs, the M300 SE easily adapts to different headphone connections. Moreover, a headphone impedance detection chip allows it to work with headphones ranging from 32Ω to 300Ω. In terms of power we get 148mV for 32Ω headphones and 15mW for 300Ω headphones.
Design, Screen & Connections
All the components are integrated in a beautiful CNC machined aluminum housing, both robust and allowing to limit the interference that could degrade the audio signal. The front panel is dressed with a tempered glass plate of the most beautiful effect and a screen, allowing to display all the information related to the reading of your files (input, filter, sampling rate, read format...). The control is done simply thanks to the two buttons on the front panel or with the supplied infrared remote control, allowing you to turn on / off the device, select an input, change the display color, choose an audio filter, control the volume, etc.
In terms of connectors, we find, on the front panel, a Jack 6.35mm headphone output and a Jack 4.4mm headphone output. On the rear panel, there is a balanced XLR or unbalanced Jack 3.5mm output. In inputs the M300 SE presents a coaxial input, an optical Toslink, a USB-C plug as well as Bluetooth.
1Screen
2Power ON/OFF
3Input selection
4Jack 6.35mm output
5Balanced Jack 4.4mm output
6Control knob
7Balanced XLR output
8Jack 3.5mm output
9Coaxial input
10Toslink Optical input
11Bluetooth Antenna
12USB-C Power Aux
13Input/Power USB-C
Product typeDAC
Headphone amplifier
Input1x USB-C (XMOS)
1x Optical Toslink
1x S/PDIF Coaxial
Bluetooth
Output1x Single-ended Jack 3.5mm
1x Balanced XLR
1x Balanced Jack 4.4mm headphone output
1x Single-ended Jack 6.35mm headphone output
Output levelsRCA: 2Vrms
XLR: 4Vrms
THD+N0.00013% (-117db)
Dynamic rangeRCA: 120dB
XLR: 132dB
SNR131dB
USB transmissionAsynchronous
USB CompatibilityWindows 7 / 8 / 8.1 / 10 / 11
Mac OSX 10.6 or later
Linux
Bluetooth BT 5.0 (SBC support)
Sampling rate / Bit depthUSB: 32bit 768kHz / DSD256
Optical / Coaxial: 24bit 192kHz
Consumption3W
Standby power consumption< 0.1W
Dimensions (L*D*H)70*165*73mm
Weight540g
OutputJack 4.4mm
OutputJack 3.5mm
OutputJack 6.35mm
DAC / ADC ChipCS43131
Max sampling rate768kHz
Max sampling rateDSD256
Max sampling rateMQA
Remote ControlYes
Très bien
Facteur de forme pratique et mignon, fonctionne très bien et délivre un beau son riche et dynamique.
J'apprécie aussi le fait qu'il démarre tout seul dès que la tension d'alimentation (+5v) lui est appliquée et qu'il ne génère aucun cloc à cette occasion, ni à l'extinction d'ailleurs (très bien pour mes enceintes actives Adam Pro).
Par contre, l'extinction (programmable) et l'intensité (variable) de l'écran incorporé sont incohérentes, des fois ça marche, des fois non, et c'est d'autant plus énervant que j'ai deux exemplaires accolés qui ne réagissent absolument pas de la même manière,
This review has been posted for SMSL M300 SE DAC Headphone Amplifier 2x CS43131 XMOS Dual Clock NDK Bluetooth 5.0 32bit 768kHz DSD256 MQA
The SMSL M300 is a powerful and compact DAC in an atypical format. Integrating high quality components, it is the perfect ally to offer your HiFi...
