SMSL RAW PRO-DAC1 DAC
The SMSL RAW PRO-DAC1 is a precise, high-performance DAC based on an ESS ES9039MSPRO DAC chip and a USB XMOS XU-316 interface. It can therefore support high-resolution sampling rates up to PCM 32bit 768kHz, DSD512 and MQA/MQA-CD.
Reference : 20227
699,00 €tax incl.
582,50 € tax excl.
Shipping date: 27-05-2025.
SMSL RAW PRO-DAC1 DAC ES9039MSPRO Bluetooth 5.1 aptX HD LDAC 32bit 768kHz DSD512 MQA-CD
Photo of SMSL RAW PRO-DAC1
The SMSL RAW PRO-DAC1 is a precise, high-performance DAC based on an ESS ES9039MSPRO DAC chip and a USB XMOS XU-316 interface. It can therefore support high-resolution sampling rates up to PCM 32bit 768kHz, DSD512 and MQA/MQA-CD. In addition, it features Bluetooth functionality thanks to the latest Qualcomm QCC5125 chip supporting aptX HD and LDAC (24bit/96kHz) codecs for extremely reliable wireless transmission. The performance of the SMSL RAW PRO-DAC1 is made possible by its optimized Accu Silicon clock circuit and low-noise power supply. In terms of appearance, we find the slim, elegant lines that characterize SMSL products, but also a beautiful color display that facilitates the user experience. As for connectivity, there's a full range of digital inputs, including USB-C, USB-B, Toslink optical, SPDIF coaxial, AES/EBU and I2S via HDMI.
SMSL RAW PRO-DAC1 highlights
SMSL RAW PRO-DAC1: ES9039MSPRO DAC chip and XMOS XU-316 USB interface
The SMSL RAW PRO-DAC1 is based on high-quality Hi-Fi components such as the ES9039MSPRO DAC chip and an XMOS XU316 interface. This enables it to support high-resolution sampling rates up to PCM 32bit 768kHz, DSD512 and MQA / MQA-CD on its USB inputs. MQA / MQA-CD is also supported via Toslink optical and coaxial SPDIF. This means you can play high-resolution files and enjoy top-quality music listening sessions.
Bluetooth functionality of the SMSL RAW PRO-DAC1
SMSL RAW PRO-DAC1 : Bluetooth 5.1
The SMSL RAW PRO-DAC1 benefits from an ESS ES9039MSPRO Bluetooth chip, enabling it to support high-definition codecs: aptX and LDAC (24bit/96kHz). This ensures reliable, stable wireless transmission of the audio stream.
SMSL RAW PRO-DAC1: Low-noise power supply
The RAW-DAC1's isolated low-noise power supply provides clean current to all its components.
SMSL RAW PRO-DAC1 power supply
SMSL RAW PRO-DAC1: I2S input via HDMI
The SMSL's I2S input via HDMI enables it to be powered by an I2S source and, consequently, to deliver a high-resolution signal, unaltered and little affected by jitter.
Pin I2S via HDMI
SMSL RAW PRO-DAC1 overview
1Display
2Indicator light
3IR receiver
4Multifunction button
5Single-ended RCA output
6Balanced XLR output
7AES/EBU input
8Bluetooth antenna
9I2S input
10SPDIF coaxial input
11Toslink optical input
12USB-C input
13USB-B input
14Power input
SMSL RAW Pro-DAC1 test by Audio Science Review
The RAWPRO-DAC1 provides flawless performance, topping all of my measurements. It is attractive both mechanically and when it comes to the display. As picky as I am, I can't find any faults to report. I am happy to recommend the SMSL RAW Pro-DAC1 stereo DAC.
Product typeDAC
DAC chipES9039MSPRO
USB interfaceXMOS XU316
Bluetooth receiver chipQualcomm QCC5125
Inputs1x USB-C
1x USB-B
1x Coaxial
1x Optical Toslink
1x AES/EBU
1x I2S via HDMI
Bluetooth
Ouputs1x Single-ended RCA output
1x Balanced XLR output
Supported sampling ratesUSB and I2S: PCM up to 32bit 768kHz, DSD512
USB: DSD DoP256, MQA
Optical Toslink, coaxial and AES/EBU: PCM up to 24bit 192kHz, MQA-CD
Optical Toslink, coaxial: DSD DoP64
Supported Bluetooth codecsSBC, AAC, aptX, aptX HD, LDAC
Output amplitudeVariable or fixed mode
RCA: 2.5Vrms
XLR: 5.2Vrms
Output impedanceRCA: 100Ω
XLR: 100Ω
THD+NRCA: 0.00007% (-123dB)
XLR: 0.00005% (-125dB)
Dynamic rangeRCA: 127dB
XLR: 132dB
USB transmissionUSB 2.0 (Asynchronous)
USB compatibilityWindows 7 / 8 / 8.1 / 10 / 11 (driver required)
MAC OSX 10.6 et plus
Linux
Power supply100-240V AC
Power consumption< 20W
Standby power consumption< 0.5dB
Dimensions254 x 203 x 48mm
Weight1.9kg
ColorSilver
Package1x SMSL RAW DAC PRO-DAC1
1x Bluetooth antenna
1x IR remote control (RC-8C)
1x Power cable
SMSL RAW PRO-DAC1 measurements
InputI2S via HDMI
InputAES/EBU
DAC / ADC ChipES9039MPro / ES9039MSPro
Max sampling rate768kHz
Max sampling rateDSD512
Max sampling rateMQA
ColorSilver
Remote ControlYes
The SMSL RAW PRO-DAC1 is a precise, high-performance DAC based on an ESS ES9039MSPRO DAC chip and a USB XMOS XU-316 interface. It can therefore...
