DAC suitable for high-quality active PC speakers.
It doesn't seem like a suitable adept for a large lineup, but absolutely ideal for a PC.
I run it with a Genelec 8330CP speaker via XLR and the sound is fine.
By buying this product you get 34 loyalty points
Balanced DAC ES9068AS USB XMOS 32Bit 768kHz DSD512 MQA
The SMSL SU-8s is a symmetrical DAC featuring the new ESS ES9068AS digital to analog conversion chip. This last one supports high sampling rates, up to PCM 32bit 768kHz and DSD512 and ensures a clear and dynamic restitution. This DAC is associated with a USB XMOS XU216 32bit interface, promoting a beautiful sound transparency. Moreover, the SU-8s is also able to read MQA (Master Quality Authenticated) files, allowing to enjoy a sound reproduction as close as possible to the original recording.
Displaying a complete connectic panel, the SMSL DAC will adapt to all situations and all systems. We can find in input USB-B, Coaxial, Optical, but also a Bluetooth 5.0 reception. This last one is compatible with the codecs of transmission aptX and aptX-HD, allowing to reach a high sound quality in wireless. Finally, on the output side, the SU-8s offers single-ended RCA and balanced XLR.
Finally, all the components are integrated in a beautiful and robust CNC machined aluminum case with a front panel display for easy and convenient use. It is also delivered with a remote control to control it remotely.
1 | IR Receiver |
2 | Screen |
3 | Multifunction knob |
4 | Power connector |
5 | Bluetooth antenna |
6 | Optical input |
7 | RCA Output |
8 | USB Input |
9 | Coaxial input |
10 | Balanced XLR output |
"We are so lucky that, despite the low cost of these devices, they continue to compete with each other to snatch the last bit of performance. There's really no fault to be found."
Product type | DAC |
Inputs | 1x USB-B 1x Optical 1x Coaxial Bluetooth 5.0 |
outputs | 1x Single-ended stereo RCA 1x Balanced stereo XLR |
THD+N | 0.00009% (-121dB) |
Dynamic range | XLR : 130dB RCA : 123dB |
SNR | 130dB |
Output impedance | XLR : 207Ω RCA : 142Ω |
USB transmission mode | Asynchrone |
USB compatibility | Windows 7 / 8 / 8.1 / 10 Mac OSX Linux |
Supported sampling rates | USB : PCM up to 32bit 768kHz, Native DSD up to DSD512 Optical / Coaxial : PCM up to 24bit 192kHz, DSD DoP up to DSD64 |
Supported Bluetooth codecs | SBC, aptX, aptX-HD |
Power supply | 100-240V 50~60Hz (power cable included) |
Operating consumption | 5W |
Standby consumption | < 0.5W |
Dimensions | 187.5 x 154 x 40mm |
Weight | 0.79kg |
Input | USB |
Input | Optical |
Input | SPDIF |
Input | Bluetooth |
Output | XLR |
Output | RCA |
DAC / ADC Chip | ES9068AS |
Max sampling rate | 768kHz |
Max sampling rate | DSD512 |
Color | Black |
Networking | No |
Remote Control | Yes |
Average votes 5.0 / 5 2 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Lubos S.
Arnaud P.
