DAC Headphone Amplifier AK4493S XMOS XU208 32bit 384kHz DSD256 Silver
Topping unveils with the DX1 a compact, affordable and yet powerful DAC and headphone amplifier combo. It benefits from an optimized design allowing an efficient digital/analog conversion as well as a robust headphone amplification.
The DX1 features the brand new AKM AK4493S DAC chip. This ensures a precise and musical conversion, while allowing, in association with the USB XMOS XU208 interface, the support of high resolution audio streams, up to PCM 32bit 384kHz and DSD256.
The Topping DX1 uses a discrete LNRD (Low Noise Reference Driver) circuit to effectively filter out noise and interference from the USB power supply. As a result, the power supply stage is able to provide the DX1's audio circuitry with a clean and stable electrical signal.
The volume of the line output is fixed at its maximum level and is not adjustable.
The headphone outputs and the line output are active simultaneously.
Product type | DAC and headphone amplifier |
DAC chip | AKM AK4493S |
Input | 1x USB-B |
Outputs | 1x Stereo RCA line out (fixed volume) 1x Jack 3.5mm headphone output 1x Jack 6.35mm headphone output |
Supported sampling rates | PCM up to 32bit 384kHz Native DSD up to DSD256 DSD DoP up to DSD128 |
DAC Parameters (USB Input @ 44.1kHz) | |
THD+N @ 1kHz, A-Weighted | < 0.0002% |
THD @ 20Hz-20kHz, 90kBw | < 0.0006% |
SNR @ 1kHz, A-Weighted | 120dB |
Dynamic range @ 1kHz, A-Weighted | 120dB |
Frequency repsonse | 20Hz - 20kHz (±0.3dB) 20Hz - 40kHz (±0.7dB) |
Output level | 2.0Vrms @ 0dBFS |
Crosstalk @ 1kHz | -112dB |
Channel balance | 0.3dB |
Output impedance | 22Ω |
Headphone amplifier parameters | |
THD+N @ 1kHz, A-Weighted | < 0.0003% @ 200mW, 32Ω < 0.0002% @ 45mW, 300Ω |
THD @ 20Hz-20kHz, 90kBw | < 0.003% @ 200mW, 32Ω < 0.001% @ 45mW, 300Ω |
SNR @ Max Out, 1kHz, A-Weighted | 118dB |
Dynamic range @ 1kHz, A-Weighted | 118dB |
Frequency response | 20Hz - 20kHz (±0.3dB) 20Hz - 40kHz (±0.7dB) |
Output level | 2.2Vpp @ G=L 11Vpp @ G=H |
Noise @ A-Weighted | < 1.0µVrms |
Crosstalk @ 1kHz | -86dB |
Gain | -2dB (Vrms/FS) @ G=L 12dB (Vrms/FS) @ G=H |
Output impedance | < 0.7Ω |
Output power | 2x 280mW @ 32Ω, THD+N <0.1% 2x 190mW @ 64Ω, THD+N <0.1% 2x 51mW @ 300Ω, THD+N <0.1% |
Load impedance | > 8Ω |
Dimensions | 100 x 98 x 32mm |
Color | Silver |
Package | 1x Topping DX1 1x USB-B cable |
Input | USB |
Output | Jack 3.5mm |
Output | RCA |
Output | Jack 6.35mm |
DAC / ADC Chip | AK4493S |
Max sampling rate | DSD256 |
Max sampling rate | 384kHz |
Color | Silver |
Class | Class D / T |
Networking | No |
Remote Control | No |
