TOPPING DX7 PRO Balanced DAC Headphone Amplifier ES9038Pro Bluetooth 5.0 aptX HD LDAC 32bit 768kHz DSD1024 Black
The Topping DX7 Pro is a model of versatility and performance. This DAC embeds a particularly complete connectivity, covering the vast majority of possible integrations in a HiFi audio system, combined with an intelligent architecture supporting high sampling rates and offering rich and accurate audio reproduction.
4.9 / 5
By buying this product you get 64 loyalty points
Reference : 14103
649,00 €tax incl.
540,83 € tax excl.
This product is now replaced by the Topping DX7 Pro+.
Topping DX7 Pro
Balanced DAC Headphone Amplifier ES9038Pro Bluetooth 5.0 aptX HD LDAC 32bit 768kHz DSD512
Topping DX7 Pro DAC Amplificateur Casque Symétrique ES9038Pro Bluetooth 5.0 aptX HD LDAC 32bit 768kHz DSD512
Versatility & Performance
Review by Audio Science Review
The Topping DX7 Pro betters the DAC performance of all the produces Topping had produced. On SINAD measurement, it lands in the coveted range of near 120 dB, proving beyond a shadow of doubt that it is transparent to any content you attempt to play. This is a super challenging bar to reach and I congratulate Topping for getting there.
test by the measurement forum Audio Science Review
ES9038Pro DAC & USB XMOS XU208 Interface
A major difference between the DX7s Topping and the DX7 Pro, the DAC now includes an ES9038Pro ESS chip, which is more powerful than the ES9038Q2M duo of the DX7s. This new chip offers a better signal-to-noise ratio and a lower level of distortion for an ever more accurate, rich and faithful sound reproduction. In addition, this chip supports high sampling rates.
On the USB interface side, we find once again the XMOS XU208 chip, well known to audiophiles and offering an exceptionally transparent reproduction.
Interieur DX7 pro
Bluetooth 5.0 aptX HD / LDAC
Also new in this Pro version of the DX7 Topping, it is now equipped with a Bluetooth 5..0 Qualcomm CSR8675 chip. While this type of connectivity is particularly convenient by offering the possibility of remote transmission directly from a smartphone or tablet, it is also synonymous with audio quality since this chip supports the aptX, aptX LL, aptX HD and LDAC protocols. These protocols allow a faster, more stable signal transmission but also, especially in the case of LDAC, to support higher sampling rates since this protocol is able to decode PCM streams up to 24bit 96kHz (24bit 48kHz for aptX HD).
A particularly complete connection system
For its connectivity, the DX7 Pro offers a particularly complete panel. The rear panel reveals the input of USB-B (XMOS), I2S Optics, Coaxial, I2S, AES/EBU and Bluetooth antenna. On the output side, the DX7 Pro offers balanced XLR, single-ended RCA on its rear panel. The front panel of the unit features the headphone outputs amplified with 6.35mm jack, 4.4mm balanced jack and 4 pin XLR balanced jack.
Full Balanced
The DX7 Pro's circuits have been designed to be full balanced. Thus, the analog section includes separate OPA 1612 operational amplifiers for each channel and the headphone amplification of each channel is assigned to an independent TPA6120A2 chip.
High fidelity balanced headphone section
The DX7 Pro Topping provides optimal headphone output performance with two TPA6112A2 amplifiers. Thus, in addition to supporting up to DSD1024 and PCM 32bit 768kHz, it benefits from a particularly neat analog output stage that can drive a very large majority of audiophile headphones, on 4 pin balanced XLR output.
This allows the DX7 Pro to offer a lower sound colouring and therefore a more accurate reproduction, a very low distortion and a high linearity. You gain in dynamics, detail and neutrality.
Product typeDAC
Headphone amplifier
Inputs1x USB-B
1x Optical
1x Coaxial
1x I2S HDMI
1x AES/EBU
Bluetooth
Outputs1x Balanced XLR
1x Single-ended stereo RCA
1x Jack 6.35mm single-ended headphone output
1x Jack 4.4mm balanced headphone output
1x XLR 4 pins balanced headphone output
DAC ChipES9038Pro
Supported sampling rateUSB : PCM up to 32bit 768kHz, Native DSD up to DSD512, DSD DoP up to DSD256
I2S : PCM up to 32bit 768kHz, Native DSD up to DSD1024, DSD DoP up to DSD256
Optical / Coaxial / AES : PCM up to 24bit 192kHz, DSD DoP up to DSD64
Bluetooth Version5.0
Supported Bluetooth protocolsLDAC, aptX, aptX LL, aptX HD, AAC, SBC
THD+NDAC (XLR) : 0.0001%
Amplifier (Jack 6.35mm headphone output) : 0.0004%
Amplifier (Balanced output) : 0.0004%
SNRDAC (XLR) : 126dB
Amplifier (Balanced output) : 123dB
Housing materialAluminium
Dimensions22.2 x 17.8 x 4.5cm
Package1x DX7 PRO Black
1x Schuko power cable
1x Remote
1x USB-A to USB-B cable
1x Bluetooth antenna
1x Jack 3.5mm to Jack 6.35mm adapter
InputXLR
InputI2S
OutputCoaxial SPDIF
OutputJack 4.4mm
OutputJack 6.35mm
DAC / ADC ChipES9038PRO
Max sampling rateDSD1024
Max sampling rate768kHz
16 reviews
Great DAC with great features :-)
I received my Topping DX7 Pro a few days ago and could immediately hear more details than with my former mobile Fiio BTR5 DAC (which is great in itself). Initially, the sound is a little bit flat and somewhat unexciting, but I suspect the onboard op-amps need to be burned in for a few hundred hours before the DAC reveals itself fully. Also, I am thinking of replacing the stock op-amps with two Burson V6 Vivid op-amps as dozens of reviews on the internet suggest that this is the right thing to do. I especially like that this DAC is intuitive and logical. For instance, there's separate volumes for headphones and loudspeakers, and the DAC remembers your settings even after having been turned off.
This review has been posted for TOPPING DX7 PRO Balanced DAC Headphone Amplifier ES9038Pro Bluetooth 5.0 aptX HD LDAC 32bit 768kHz DSD1024 Black
Un très bon ampli dac !
J'ai pus comparer cet article avec mon:
-Audio-gd nfb-11.38 performance edition
J'ai passé la soirée à les comparer brancher à mon PC en USB.
Casque de test Meze 99.
L'Audui G a plus de peps, plus de dynamisme. Alors que le Topping est beaucoup plus neutre. Pour ce qui est des graves, aigue, médium c'est délicat de juger. La différence est pas difficile à Percevoir pour moi.
Mais le Topping à la sortie symétrique. Et là, ça fait la différence. On retrouve une bonne pêche et le dynamisme manquant.
J'ai branché le câble officiel Meze symétrique en 4.4.
Mais alors pourquoi pas toutes les étoiles ? La télécommande n'est vraiment pas pratique. Faut être pile en face pour changer les sources etc et elle fait pas solide du tout.
Surtout que impossible de changer via l'ampli lui même.
Un grand remerciement à David Aubert qui m'a beaucoup aidé.
dx7 pro
Branché sur mon node2i , la qualité est montée d'un bon cran .
Je l'ai acheté à l'aveugle sur la base des données d'Audio science review et je ne suis vraiment pas déçu .
Dac TOPPING DX7 PRO
Bonjour les amis audiophiles, je viens tout juste de déballer le TOPPING DX7 PRO, reçu en 2 jours, paramétré en DAC pur, pour écouter ma musique stockée sur QOBUZ (soit en USB ou en BLUETOOH sur mon smartphone, en se servant de la télécommande). D'entrée, très bonne surprise, sur le plan musicale, beaucoup de présence sur l'ensemble du spectre, l'équilibre tonal très bien respecté, je ressens déjà la supériorité sur mon ancien dac le Dangerous Source, coûtant le double! Le temps va permettre au TOPPING DX7 PRO, de libérer tout son potentiel, la HI-FI c'est comme le bon vin, plus il vieilli, meilleur il est!!!
Merci à l'équipe d'AUDIOPHONICS, site que je recommande encore une fois sans problème, ainsi que ce fameux TOPPING DX7 PRO!
Superb Experience
Ordering/Payment/Shipping:
- Intuitive, fast (next day), without any issues. Paypal used, again great experience.
Device
- Working as expected. Great sound and functionality.
The Topping DX7 Pro is a model of versatility and performance. This DAC embeds a particularly complete connectivity, covering the vast majority of...
