TOPPING DX7s 2xES9038Q2M DAC / Preamplifier / Headphone ampli DSD 32bit / 768kHz Balanced Black
The Topping DX7s is a versatile device that will serve you both DAC, preamplifier and headphone amplifier. It incorporates a symmetrical design based on two DAC ES9038Q2M for exceptional playback.
By buying this product you get 39 loyalty points
Reference : 12599
399,00 €tax incl.
332,50 € tax excl.
Topping DX7 2XEs9038Q2M
Versatility and efficiency
The Topping DX7s with its "form factor" and its 32bit 768kHz capabilities offers many configuration possibilities. Combining the functions of DAC, digital preamplifier and high impedance headphone amplifier, it will meet most needs with a high-performance balanced headphone output.
USB Dual XMOS ES9038Q2M
The fully symmetrical design of this DAC based on Es9018Q2M 2 chips gives it high technical qualities with crosstalk and insignificant floor noise. Each conventional PCM SPDIF digital input has a galvanic isolation transformer. The Topping Dx7s offers at a studied price of the services rarely reached.
Dual-stage analog real symmetric
Topping DX7s
The analog placement of this DAC is symmetrical to the output of Both ES9038Q2M. The analog portion features separate OP amps For Each left and right audio quality original Texas Instrument channel.
A Balanced HiFi Headphone section
Topping DX7s balanced output
The DAC headphone Topping DX7s offers optimum performance thanks to two TPA6112A2 amps. In addition to Supporting the DSD / DXD and sampling rates of up to 32bit / 768kHz, it benefits from a similar course PARTICULARLY output neat That can attack the market-leading audiophile headphones was 4 pin XLR symmetrical output.
This Allows the DX7 to offer a lower color tone and consequently a faithful reproduction, has very low distortion and a great linearity. You gain in dynamics, details and neutrality.
Topping DX7 Connectiques
CONNECTORS: INPUTS
1x USB XMOS16 - 32bits DSD64 to DSD512 (DOP) 768kHz
1x Coaxial75Ω 16 - 24bits 44.1kHz - 192kHz
1x Toslink Optical16 - 24bits 44.1kHz - 192kHz
1x AES/EBUBalanced 110Ω 16 - 24bits 44.1kHz - 192kHz
Connectors: Outputs
1x RCA-
1x XLR Symmetry-
1x Coaxial Digital75Ω 16 to 24 bits 44.1kHz to 192kHz
1x Headphone OutJack 6.35mm
1x balanced XLR headphone output4 pins
Report ifgnal noise114dB
crosstalk-130dB to 1kHz
Headphone output level 6.3516Vpp
Balanced headphone output level31Vpp
Fixed2V RMS
Headphone output impedance10Ω (20Ω symmetrical)
Line output impedance DAC100Ω
Line output impedance XLR200Ω
Coaxial Input Sensitivity0.5V pp (75Ω)
Frequency Response20Hz - 20kHz (-0.2dB)
Headphone output power
Asymmetrical Jack 6.35mm690mW to 32Ω, 110mW to 300Ω (16 to 300Ω)
Symmetrical XLR 4 pins420mW to 300Ω, 210mW to 600Ω (16 to 600Ω)
CompatibilityWindows, Mac
Consumption12W
Weight1.95kg
Dimensions250 x 205 x 50mm
Accessories3.5mm Jack, 1x USB Cable, 1x Power Cable / Remote control available as accessories
InputXLR
OutputJack 6.35mm
Remote ControlYes
5 reviews
very good product and great supply
I received the goods in time, following the tracking in 3 days.
I contacted the support for some info and they replay to me in few hours. very good service. I appreciate Audiophonics customer service .
This review has been posted for TOPPING DX7s 2xES9038Q2M DAC / Preamplifier / Headphone ampli DSD 32bit / 768kHz Balanced Black
Big positive surprise
I was really surprised how good does my Dali Ikon 2 and custom amplifier perform with this DAC. For this price, it does not have any competition.
A great experience
First days trying to extract bests from this DAC:but first, thanks to Audiophonics for its professional cast to answers, shipment time and accuracy in all particulars
Max
best amplifier in 1500+ euro range , for only 500 eur:)
better what gustard a20h.
im using it with HD800S headphones +balanced cable
awesome combo !!! no need for tube amps... this amplifier delivers smooth midrange, clear highs, bass a little weak, boot acceptable,and 3D soundstage is very good. My best invested 500 euros :)
Une proposition très sérieuse et détaillée.
Froid et sans relief à la mise en route, ce DAC se révèle au bout d'une dizaine de jours d'utilisation.
Il devient alors très équilibré et homogène. Il "fait le job" avec beaucoup probité pour son prix. Il est très bien construit et sa fabrication respire le sérieux à l'image de la sonorité qu'il délivre. Sérieux ne voulant pas dire ennuyeux, ce convertisseur s'efface devant la musique.
C'est une très bonne alternative aux marques plus connues du grand public souvent plus coûteuses. Sa technologie embarquée et sa fabrication lui permettent de satisfaire les demandeurs d'un super ampli-casque respectueux des prises de son qui sont traitées avec rigueur, intégrité et détails qui permettent à chacun de redécouvrir sa musique préférée.
il faut lui adjoindre à l'achat sa télécommande qui n'est pas comprise dans le pack.
Comme pour tous ces appareils de milieu de gamme à prix serré; il faut prendre avec attention la proposition de Topping avec ce petit DAC/ampli-casque qui ne prétend pas faire mieux que les monstres du High end dont il n'a pas l'ampleur mais qui donne beaucoup de plaisir pour chaque centimes dépensés.
 (4)
The Topping DX7s is a versatile device that will serve you both DAC, preamplifier and headphone amplifier. It incorporates a symmetrical design...
