TOPPING E30 II LITE DAC AK4493S XMOS XU208 32bit 768kHz DSD512 Black
Topping is back with the compact E30 II LITE DAC, a slimmed-down version of the excellent E30 II, featuring a number of technical improvements over the E30. With an AK4493S DAC chip, a XMOS XU208 USB interface and an optimised power supply, Topping's newcomer will give you an excellent DAC at an extremely affordable price.
4.5 / 5
Reference : 17919
99,00 €tax incl.
82,50 € tax excl.
Shipping date: 20-05-2025.
Topping E30 II LITE
TOPPING E30 II LITE DAC AK4493S XMOS XU208 32bit 768kHz DSD512 Noir
Topping is back with the compact E30 II Lite DAC, a slimmed-down version of the excellent E30 II, featuring a number of technical improvements over the E30. With an AK4493S DAC chip, a XMOS XU208 USB interface and an optimised power supply, Topping's newcomer will give you an excellent DAC at an extremely affordable price.
Differences between the E30 II LITE and the E30 II
E30 II LITE
E30 II
DAC
1x AK4493S
2x AK4493
Digital input receiver chip
CS8416
Digital processing: more stable and better compatibility
SINAD
117dB
119dB
SNR
121dB
123dB
DYnamic range
121dB
123dB
Noise
< 1.9µV
< 1.5µV
Internal power supply
Discrete LNRD: noise suppression and stability
AKM AK4493S DAC
The main change in the E30 II Lite is its digital/analog conversion stage. This uses a single AKM AK4493S DAC chip. This is itself an improvement on the AK4493 chip. It also benefits from proprietary Velvet Sound technology, ensuring sound reproduction as precise as it is rich in detail.
XMOS XU208 USB Interface
The USB-B input on the E30 II Lite makes using the DAC simple and powerful. This is combined with an XMOS XU208 interface and a particularly stable and reliable Thesycon custom driver. In addition, this input ensures extremely low jitter. Combining this interface with the AK4493S DAC also means that the E30 II Lite can support high-resolution audio streams, up to PCM 32bit 768kHz and DSD512.
Simple and effective connectivity
When it comes to connectivity, the E30 II Lite doesn't overdo it, but it does offer a range of connections just as complete as the E30 II, making it easy to integrate into the vast majority of audio systems. Inputs include USB-B, Toslink optical and coaxial. The output is simply stereo RCA.
Topping E30 II LITE DAC AK4493S XMOS XU208 32bit 768kHz DSD512 Noir
1LED Display screen
2IR receiver
3Multifunction touch button
4Right channel RCA output
5Left channel RCA output
6Coaxial input
7Optical Toslink input
8USB-B input
9Jack DC power connector (5VDC 1A)
5V power supply
The E30 II Lite uses a practical 5VDC power supply. This means it can be used almost anywhere and can be connected to a computer, a phone charger or a powerbank. The built-in protection circuit protects the E30 II Lite and will display an error message in the event of a wrong power supply.
Discrete LNRD circuit
To solve the problem of noise that can be caused by the 5V power supply, the E30 II Lite includes a discrete LNRD (Low Noise Reference Driver) circuit. This filters out the noise from the power supply to provide an ultra-low-noise, perfectly stable electrical signal to the audio circuits. As a result, the background noise of the E30 II Lite is less than 1.9µV.
PCM & DSD Filters
The E30 II Lite provides six PCM filters and two DSD filters. These allow you to adjust the sound reproduction of the device according to your preferences and your audio system.
Auto ON/OFF function
With its Auto ON/OFF function, the E30 II Lite switches on and automatically selects the input receiving a valid audio signal. Similarly, if the device receives no signal for one minute, it switches off automatically.
Pure DAC mode
The E30 II Lite has a function that locks its maximum output level. This means it can operate in pure DAC mode. In pure DAC mode, DSD signals bypass the DATT Soft Mute and Delta Sigma modulator to deliver optimum sonic performance.
Volume control
Topping's DAC also incorporates a volume control, allowing the volume to be adjusted over a range from -99dB to 0dB using the remote control. The E30 II Lite can therefore be connected directly to a power amplifier or active loudspeakers.
Product typeDAC
DAC chip1* AKM AK4493S
Inputs1* USB-B
1* Optical Toslink
1* Coaxial
Output1* Stereo RCA
Supported sample ratesUSB: PCM up to 32bit 768kHz, native DSD up to DSD512, DSD DoP up to DSD256
Coaxial / Optical: PCM up to 24bit 192kHz
THD+N @1kHz (A-weighted)< 0.0002%
THD @90Bw (Not-weighted)< 0.0004%
SNR (A-weighted)121dB @ 1kHz
Dynamic range (A-weighted)121dB @ 1kHz
Frequency response20Hz - 20kHz (+/-0.3dB)
20Hz - 40kHz (+/-0.8dB)
Output level2.1Vrms @ 0dBFS
Noise (A-weighted)< 1.9µVrms
Crosstalk @ 1kHz-137dB
Channel balance< 0.3dB
Ouput impedance20Ω
Dimensions100*125*32mm
Package1* Topping E30 II LITE
1* Remote control
1* USB-A male to USB-B male cable
1* USB-A male to DC jack power cable
DAC / ADC ChipAK4493S
Max sampling rate768kHz
Max sampling rateDSD512
Remote ControlYes
6 reviews
Fantastic DAC
This an absolute huge sounding dac! This small and budget dac it's a true bargain. The sound is warm, pure and a joy. I use it with an fiio br 13 streamer with ldac and it sounds great, with an cd player and greater. It is crystal clear sound ... absolutely amazing in treble and mids ... not basier but you'll notice the bass. In terms of soundstage is also very good. I simply love this dac. My small and budget system sound much better with it: Fiio Br 13 streamer, xduuo 605 tube amp, and Roth Audio speakers. So If you need an budget dac with great, warm, rich, controlled sound buy this one, and you will ear the diference in sound as soon as you turn it on.
This review has been posted for TOPPING E30 II LITE DAC AK4493S XMOS XU208 32bit 768kHz DSD512 Black
Crystal clear
Pretty well implemented cute basic DAC with a nice display and crystal clear sound. Jitter performance through spdif could be better though.
Bon petit appareil très complet
Alors chez moi il remplace un D10S + Sabaj A10h
En effet le E30 II Lite dispose de 3 entrées et d'un réglage de volume je peux donc retirer un appareil de la chaîne.
Niveau qualitatif je dirais que j'y gagne même si j'aimais beaucoup aussi le D10S. Il s'agit d'un remplacement pour disposer d'entrées numériques optique et coaxiale manquantes sur le D10S.
Le E30 est donc plus complet et moins cher que le D10S c'est donc lui qu'il faut logiquement privilégier.
Je note aussi des différences à l'écoute mais elles sont subtiles et difficiles à décrire.
Dans la configuration E30II + sabaj A10H le son a quelque chose de vraiment fatiguant en écoute de musique, pas de soucis pour la bande sonore de films.
Alors que dans la configuration E30II directement sur le bloc ampli stéréo tout se passe au mieux et tout est à sa place et procure beaucoup de plaisir à l'écoute. Peut-être même plus équilibré que A10h + D10S.
Petite précision concernant un autre commentaire posté en avis sur cet appareil par un autre acheteur: le DAC dispose bien d'un mode sans réglage de volume, celui est simplement bloqué à 0DB sans action possible de la télécommande. Pour cela il faut faire une manipulation décrite dans le manuel afin de passer d'un mode à l'autre.
Au final on dispose donc pour une centaine d'€ d'un appareil très complet et abouti. Manque un peu de souplesse d'usage de la télécommande qui est fort directive mais pas de problème majeur quand on a repéré la zone réactive.
Vu le tarif je donne 5 étoiles sans hésiter!
Très bien mais attention à l'alimentation
Coté son, c'est impec.
Par contre coté alimentation, j'ai été déçu : je pensais pouvoir l'alimenter avec le 5V de mon "préampli/Volume/sélecteur de sources" DIY, mais non... Le DAC ne supporte pas que le 0V de son alim soit relié à la masse analogique, et le fait entendre par un buzz à 200Hz et ses harmoniques. Insupportable. Il faut absolument l'alimenter avec une alimentation flottante... Depuis mon PC portable, ça va. Un adaptateur pour téléphone de qualité fait aussi l'affaire, mais le rapport signal/bruit est meilleur avec une alim linéaire. Cela fait des frais supplémentaires non prévus...
Très bon produit.
Le son est très détaillé, beaucoup de présence. Manque d'"aération" par rapport aux meilleurs DAC, mais le rapport qualité prix est excellent. J'ai préféré l'entré SPDIF, l'optique est un peu en retrait (faiblesse de ma source peut être !), L'USB est détaillée mais manque de relief comme souvent. J'ai enlevé une étoile car le mode DAC pur n'existe pas sur le E30II Lite (Audiophonics, attention aux copiés/collés). C'est bien dommage, je privilégiais ce fonctionnement. Très bon produit dans l'ensemble. Testé sur un système à haut rendement (101 dB) actif. Utilisé pour sonoriser un bureau.
Topping is back with the compact E30 II LITE DAC, a slimmed-down version of the excellent E30 II, featuring a number of technical...
