TOPPING E50 Balanced DAC ES9068AS XMOS XU216 MQA 32bit 768kHz DSD512 Black
Topping offers with its E50 a compact and very powerful DAC, using proven audio components widely recognized by audiophiles. This one is indeed based on an ESS ES9068AS digital/analog conversion chip as well as an XMOS XU216 USB interface, allowing it to read high resolution files but also to decode MQA files.
4.3 / 5
Reference : 15587
199,00 €tax incl.
165,83 € tax excl.
Shipping date: 28-05-2025.
Topping E50
DAC ES9068AS XMOS XU216 Symétrique MQA 32bit 768kHz DSD512 Black
Topping E50 DAC ES9068AS XMOS XU216 Symétrique MQA 32bit 768kHz DSD512
Topping offers with its E50 a compact and very powerful DAC, using proven audio components widely recognized by audiophiles. This one is indeed based on an ESS ES9068AS digital/analog conversion chip as well as an XMOS XU216 USB interface, allowing it to read high resolution files but also to decode MQA files. It also benefits from a balanced output on TRS connectors.
ESS ES9068ASDAC
The E50's digital-to-analog conversion stage uses the latest ESS ES9068AS DAC chip to deliver a transparent and richly detailed sound. The device ensures excellent performance with a very low distortion of 0.00009% or a dynamic range of 126dB.
USB XMOS XU216
The USB interface of the Topping E50 uses a second generation XMOS XU216 16-core chip with custom Thesycon driver. Associated with the ES9068AS DAC, this combination allows a perfect sound neutrality but also the support of high resolution files, up to PCM 32bit 768kHz, DSD512 and MQA. The USB input also uses a CPLD to process the clock signal and thus considerably reduce the jitter level.
Full connectivity & Balanced output
Topping's DAC benefits from a complete connectivity to adapt to all types of audio systems. We can find USB-B, Optical Toslink and Coaxial as inputs. On the output side, the E50 offers both single-ended RCA and a double 6.35mm TRS jack for balanced output.
The TRS output does not support an adapter to convert the signal to single-ended and cannot be connected directly to headphones.
Power supply & Auto ON/OFF
The Topping E50 is powered by 5VDC, either via its DC jack connector or directly on its USB-B input. It also benefits from an automatic on/off function. Thus, if the E50 receives a signal, it turns on automatically. In the same way, if it does not receive any signal on the selected input during 1 minute, then the E50 turns off.
Preamplifier function
The E50 has a preamplifier function. It is thus possible to control the volume level thanks to the remote control supplied. Ideal for association with a power amplifier or active speakers.
Product typeDAC
DAC ChipESS ES9068AS
Supported sampling ratesUSB : PCM up to 32bit 768kHz, Native DSD up to DSD512, DSD DoP up to DSD256, MQA
Optical, Coaxial : PCM up to 24bit 192kHz, DSD DoP up to DSD64, MQA
Entrées1x USB-B
1x Optical Toslink
1x Coaxial
Outputs1x Single-ended stereo RCA
1x Balanced stereo Jack 6.35mm TRS
Measurements @ USB, 96kHz
THD+N @ A-WeightingSingle-ended: < 0.0001% @ 1kHz
Balanced : < 0.00009% @ 1kHz
THD @ No-Weighting 90kBwSingle-ended: < 0.0003% @ 20Hz-20kHz
Balanced : < 0.0003% @ 20Hz-20kHz
SNR @ A-WeightingSingle-ended : 124dB @ 1kHz
Balanced : 126dB @ 1kHz
Dynamic range @ A-WeightingSingle-ended : 124dB @ 1kHz
Frequency responseSingle-ended : 20Hz-40kHz (±0.3dB)
Balanced : 20Hz-40kHz (±0.3dB)
Output levelSingle-ended : 2Vrms @ 0dBFS
Balanced : 4Vrms @ 0dBFS
Noise @ A-WeightingSingle-ended : < 1.3µVrms
Balanced : < 2.3µVrms
CrosstalkSingle-ended : -130dB @ 1kHz
Balanced : -139dB @ 1kHz
Output impedanceSingle-ended : 20Ω
Balanced : 100Ω
Supply voltage5VDC
Dimensions129 x 155 x 41mm
Package1x Topping E50
1x Remote control
1x USB-A to Jack DC power cable
1x USB-A to USB-B cable
Topping E50 DAC ES9068AS XMOS XU216 Symétrique MQA 32bit 768kHz DSD512 Topping E50 DAC ES9068AS XMOS XU216 Symétrique MQA 32bit 768kHz DSD512 Topping E50 DAC ES9068AS XMOS XU216 Symétrique MQA 32bit 768kHz DSD512
OutputJack 6.35mm
DAC / ADC ChipES9068AS
Max sampling rateDSD512
Max sampling rate768kHz
Remote ControlYes
6 reviews
beaucoup de détail mais...
beaucoup de détails mais malheureusement la scène sonore est étriqué.tous les instruments sont consentrés sur un même point,le centre des enceintes.dommage.
This review has been posted for TOPPING E50 Balanced DAC ES9068AS XMOS XU216 MQA 32bit 768kHz DSD512 Black
Incroyable à ce niveau de prix !
Sur les conseils avisés d'Audiophonics, j'ai changé mon ampli Yamaha WXA 50 pour un SMSL AO200 MkII. Cet ampli symétrique est absolument incroyable de pureté, puissance et neutralité ... mais associé au Topping E50 c'est tout bonnement exceptionnel !!! C'est bien simple ... ce n'est plus la même musique que j'écoute ... On ne parle plus de pureté, de grave tendu etc - tout y est avec une neutralité exceptionnelle - mais d'une évidence sonore totale. Avec le Topping E50, vous écoutez le mixage tel que l'a prévu la production, un point c'est tout. Les accords sonnent plus fluides que jamais ... ils ont même une sonorité parfois légèrement différente de ce que je pouvais entendre avant. La scène sonore se déploie dans des direction qui m'étaient inconnues ... le Topping E50 apporte une présence et une proximité avec la musique (on est à 30 cm de la guitare par exemple) que j'espérais, depuis des années ... obtenir un jour ... !
Bon produit mais en-dessous d'un DAC même plus ancien avec puce AKM
Le DAC Topping E50 n'est pas mauvais, mais il reste en-deçà du DAC que je possédais déjà (Aune S6 équipé d'une puce AKM), L'élément manquant est la gestion des trémolos et des vibratos en particulier sur la voix ou la flûte traversière, insuffisamment fidèle avec ce DAC. J'envisage prochainement de commander un DAC Topping E70 Velvet qui lui est équipé d'une puce AKM me permettant de retrouver la musicalité manquante. Pour le reste, le dac Topping E50 est un bon DAC, avec une reproduction correcte des extrêmes basses aux quasi-ultrasons, sans distorsion repérable, même à haut niveau (proche du 0db, contrairement à ce que j'avais pu constater à haut niveau avec mon DAC précédent Aune S6 qui distorsionnait ponctuellement sur certaines hautes fréquences telles 13.7Khz bien avant d'avoir atteint le niveau maximum de 0db), Je suis donc en attente d'un changement de DAC et ne sait pas si je serais amené à utiliser mon Topping E50.
très bien
comparé un à un ancien petit DAC 24 bits, 192 kHz, la clarté est appréciable. Appréciable aussi le fait de pouvoir jouer sur le filtre de sortie, qui me semble (c'est subjectif) avoir une influence subtile mais audible sur la douceur de restitution ou au contraire une restitution définie mais un peu désincarnée. Testé en Jack TRS, pas en RCA. Télécommande pratique.
Gestion de la commande par Audiophonics: aucun souci.
Ce que je cherchais
Ce DAC vient en remplacement d'une carte USB Tascam US322, limitée au 24/96, et d'un dac Sanskrit mk2 pour l'ampli casque. Il me permet de n'avoir qu'un périphérique pour mes enceintes Présonus (Eris E5+sub8) en TRS, et en RCA pour mon little DOT MKII retubé. Le son est plus détaillé, plus precis que le sanskrit au casque, et sans comparaison par rapport a la Tascam qui datait de 10 ans.La découverte des fichiers DSD, et PCM 24 /384 Flac avec ce type de materiel est assez bluffant, La transparence et l'ouverture de scene que donnent ces fichiers est vraiment mise en valeur par ce DAC. A première vue, je l'ai trouvé un peu "montant"...mais en fait, il est juste comme il faut, de toute façon, le déséquilibre serait facile a compenser juste avec les contrôle des enceintes bi-amplifiées. Les mediums sont bien définis, sans aucun voile, les instruments ou les voix sont parfaitement distincts les uns des autres, comme détourés avec un bonne spatialisation, l'ensemble est coherent et très musical. Les basses sont precises, naturelles, bien a leur place, et donnent une belle assise , les infras descendent très bas, avec une belle profondeur sans prendre le dessus, sans trainage, et bien articulées: Les notes sont parfaitement séparée et audible, pas baveuses. Bref, un tres bon rapport qualité/prix
Topping offers with its E50 a compact and very powerful DAC, using proven audio components widely recognized by audiophiles. This one is indeed...
