VEZZOSO X36 Balanced DAC ES9039PRO
This X36 DAC from Vezzoso is a high-fidelity DAC that incorporates quality components such as an XMOS XU216 USB interface, an ESS Technology ES9039PRO DAC chip and a Qualcomm QCC5125 Bluetooth receiver chip. This DAC is capable of accepting high-resolution PCM 32bit 768kHz and DSD128 streams. It also features a beautiful matrix display on the front panel, as well as elegant curves and beautiful finishes.
Reference : 18798
690,00 €tax incl.
575,00 € tax excl.
Shipping date: 06-05-2025.
VEZZOSO X36 Balanced DAC ES9039PRO HDMI I2S SPDIF USB XMOS AES 32bit 768kHz DSD512
VEZZOSO X36 picture
This X36 DAC from Vezzoso is a high-fidelity DAC that incorporates quality components such as an XMOS XU216 USB interface, an ESS Technology ES9039PRO DAC chip and a Qualcomm QCC5125 Bluetooth receiver chip. This DAC is capable of accepting high-resolution PCM 32bit 768kHz and DSD128 streams. It also features a beautiful matrix display on the front panel, as well as elegant curves and beautiful finishes. A variety of digital inputs mean you can integrate it into a wide range of configurations, thanks to a USB-B input, an HDMI I2S port and 3 SPDIF inputs: AES/EBU, coaxial and Toslink optical. Output is via stereo RCA or balanced stereo XLR. A 6.35mm Jack headphone output lets you listen to your tracks through headphones. This headphone output is amplified by a TI TPA6120A2 chip.
Photo de l'intérieur du Vezzoso X36
Vezzoso X36: ES9039PRO DAC and XMOS XU216 USB interface
The Vezzoso DAC is equipped with an ES9039PRO DAC chip and an XMOS USB interface, enabling it to support high-resolution PCM 32bit 768kHz and DSD512 codecs via the USB-B and HDMI I2S inputs. So you can enjoy high-resolution streams via your favourite music streaming platforms or your personal library. Two Crystek CCHD clocks ensure reliable signal processing.
Photo de la puce DAC ES9039SPRO et de l'interface USB XMOS XU216 du VEZZOSO X36
Photo de la sortie casque du VEZZOSO X36
Vezzoso X36: TI TPA6120A2 headphone amplifier
The 6.35mm jack headphone output is amplified by a Texas Instrument TPA6120A2 amplifier chip. This headphone amplifier chip is a high-efficiency chip specially designed for high-power output applications. It has an A/B architecture and good measurements with a wide bandwidth, low noise and a dynamic range of 128dB.
Vezzoso X36 : Bluetooth 5.1
The Vezzoso X36 is equipped with Bluetooth 5.1 functionality thanks to a QCC5125 Bluetooth receiver chip offering the possibility of wireless transmission with high fidelity codecs: SBC, AAC, aptX, adaptive aptX and LDAC. To pair your source device with the Vezzoso X36, select the BT source and search for the device [NMW5125].
Logo Bluetooth
Photo de l'étage de sortie du VEZZOSO X36
Vezzoso X36: an output stage with 11 OPA1612
The sound signal output stage incorporates no fewer than 11 OPA1612 AOPs to process the line signal before it is output to the RCA and XLR connectors.
Vezzoso X36: a clean power supply
The Vezzoso X36 incorporates two toroidal transformers and LM117S, LM337D2T and LM317BT voltage regulators. It accepts an input voltage of 240V AC and then distributes a clean current to all its internal components.
Photo des transformateurs toriques du VEZZOSO X36
Vezzoso X36: HDMI I2S input
An HDMI input port allows direct reception of an I2S signal.
HDMI connection diagram for VEZZOSO X36
Vezzoso X36 overview
VEZZOSO X36 connection diagram
1IEC power supply
2Toslink optical input
3USB-B input
4SPDIF coaxial input
5HDMI I2S input
6AES/EBU input
7Balanced stereo XLR output
8RCA stereo output
Product typeDAC
DAC chipES9039PRO
USB interfaceXMOS XU216
Bluetooth chipQualcomm QCC5125
Inputs1x USB-B
1x HDMI I2S
1x SPDIF coaxial
1x Optical Toslink
1x AES/EBU
Outputs1x XLR balanced stereo output
1x RCA stereo output
1x 6.35mm headphone output
Supported sample ratesUSB, HDMI I2S : PCM 32bit 768kHz, DSD512
SPDIF Coaxial, AES/EBU : 24bit 384kHZ, DSD DOP128
Optical Toslink : PCM 24bit 96kHz, DSD64
Supported Bluetooth codecsSBC, AAC, aptX, aptX adaptative et LDAC
Bluetooth range10m without obstacles
Volume control
Power supply220V AC power supply
Dimensions268 x 68 x 318mm
Net weight6.5kg
ColorGreen Blue
Package1x Vezzoso DAC
1x USB-A to USB-B 3.0 cable
1x Mains power cable
1x Remote control (AAA batteries not included)
InputAES/EBU
InputI2S via HDMI
OutputJack 6.35mm
DAC / ADC ChipES9039MPro / ES9039MSPro
Max sampling rateDSD512
Max sampling rate768kHz
ColorBlue
ColorGreen
Remote ControlYes
OMNI (Objet Musical Non Identifié)
Ne cherchez pas VEZZOSO sur la toile, vous ne trouverez ni site dédié ni test, au mieux une poignée de modèles vendus sur un grand site de E-commerce asiatique.
Cette marque chinoise semble spécialisée dans la production de DAC et sa diffusion principalement limitée au marché intérieur.
Il faut donc faire avec une notice en chinois (merci Google Translate) très succincte et une mise en route un peu atypique. En effet lors du premier allumage l'appareil se met en veille forcée et affiche un compte à rebours de 66 minutes.
Dixit le fabricant ce délai est destiné à reformer les condensateurs et stabiliser l'alimentation. Il indique également que ses produits sont pré-rodés en usine durant 72 h et qu'il en faut encore autant pour que l'appareil atteigne son plein potentiel.
Pour le prix d'un TOPPING ou d'un SMSL milieu de gamme le VEZZOSO délaisse les alimentations à découpage habituelles et offre un couple de transformateurs toroîdaux suivi d'un filtrage sérieux. Le reste des circuits est à l'avenant avec des composants de belle qualité et une implantation exemplaire.
A l'écoute les résultats ne se font pas attendre. Ce DAC délivre un son de haute volée digne d'appareils valant le double.
Ici la précision ne se fait pas au détriment de la douceur et les timbres sont d'une grande fidélité aussi bien sur les instruments acoustiques que sur les voix. La séparation est impeccable dans le sens de la largeur mais aussi en profondeur révélant parfois des effets de studios jusque là masqués. Enfin les signaux de faible amplitude sont parfaitement restitués et insufflent une belle respiration à la musique.
Ce DAC "exotique" présente donc une superbe sonorité doublée d'un rapport qualité/prix exceptionnel.
This review has been posted for VEZZOSO X36 Balanced DAC ES9039PRO HDMI I2S SPDIF USB XMOS AES 32bit 768kHz DSD512
This X36 DAC from Vezzoso is a high-fidelity DAC that incorporates quality components such as an XMOS XU216 USB interface, an ESS Technology...
