By buying this product you get 409 loyalty points
This is the MK3 2023 version, equipped with a new chassis and screen.
Audio-GD is developing its HE range, composed of its most top-of-the-range products. They benefit from the longest design and testing period since the brand's inception. This R-7HE model is an updated version of the R2R-7-HE. It thus takes up everything that made the success of its predecessor, namely 4 Ladder DAC DA-7 R2R fully symmetrical and discreet, allowing support of the DSD512 and PCM 32Bit 384kHz in the best way. It adds to this an improvement in the isolated Class A power supply for the Amanero module, a larger display with new buttons on the front panel to be able to change the settings without opening the device and finally a Mini USB port on the rear panel to be able to easily perform firmware updates.
It also features a Field-Programmable Gate Array (FPGA) processor identical to those used in very high-end DACs, such as the popular ROCKNA WAVEDREAM DAC. On the restitution side, we also find the performances of the previous model, namely a sound rich in details, a great dynamics, and a wide and deep sound scene.
The 2023 version of the Audio-GD R-27 features the same design and functions as the MKII, but with new improvements.
AUDIO-GD R-7 HE MKIII 2023 EDITION
Version FULL UPGRADE
AUDIO-GD R-7 HE MKII 2021 EDITION Version UPGRADE
AUDIO-GD R-8 standard version
Clocks
Accusilicon Clocks
Accusilicon Clocks
TCXO Clocks
USB Interface
Amanero USB interface Galvanic isolation Separate power for USB
New Chassis
New display screen
Like its predecessor and many Audio-GD products, the R-7HE uses the brand's Amanero USB technology supporting resolutions up to 32bit 384kHz. The R-7HE has 6 inputs: BNC, RCA Coaxial, Optical, HDMI I2S, RJ45 I2S, USB. These each have interfaces adapted to provide the highest sound quality. On the output side, the R-7HE offers XLR, RCA and ACSS.
The R-7HE is a DAC R2R, a design that has become popular thanks to its undeniable sound qualities, especially when integrated into high-end products. While there are several methods for designing a DAC R2R that impact both performance and design complexity, Audio-GD continues to choose the highest quality as usual.
The design chosen by the brand switches the ultra-low tolerance resistors in parallel and an ultra-fast FPGA chip corrects the R2R scale. This design allows you to control and correct each bit distinctly to achieve incredible performance. In addition, with this parallel structure, a single clock cycle allows all the data to be processed, where a series connection would require 8 to 24. Thanks to this architecture, Audio-GD allows its R-7HE to correct imperfections in basic R2R assemblies, i.e. those caused by resistance tolerance.
Main advantages of the DAC R2R Ladder discrete:
FPGA chips, now widely used in the audio world, allow full control of the hardware by a software layer. One of the major advantages of this technology is the ability to easily perform updates, thus allowing the device to be improved without necessarily having to replace components. It is therefore both an efficient and flexible solution.
In the R-7HE, the FPGA is responsible for 3 major points:
After the Digital to Analog conversion by the dedicated modules, the analog signal is transported to the discrete balanced output stages using paired FET Class A transistors. The analog sections have no surface components, only discrete components. This diagram allows to obtain a system without any feedback (non-feedback) and a very low output impedance. From a sound point of view, this translates into an absolutely disconcerting neutrality. This output stage also has ACSS analog outputs for even higher detail and definition.
Audio-GD has its own technological signature called ACSS for "Audio-GD Current System Signal". Thanks to the firm's expertise and know-how, this technology offers a less colourful, more detailed sound, and unparalleled neutrality. Each of the brand's technical engineers is, in addition to being experienced, a Hi-Fi and Audio enthusiast like you and us.
Si la marque nous a pendant un temps habitué à des réglages de filtres se faisant grâce à des switch se trouvant sous le capot de ses appareils, elle offre maintenant une ergonomie améliorée en proposant d'effectuer ces réglages directement depuis la façade de l'appareil. En effet, des boutons permettent de choisir simplement le filtre actif, sans aucun besoin de démonter l'appareil. Le R-7HE propose 4 filtres en mode NOS et 3 filtres en mode Oversampling. Dans cette même optique de simplifier l'utilisation du DAC, Audio-GD intègre un port Micro USB à l'arrière de l'appareil permettant d'effectuer simplement les mises à jour du firmware.
The integrated regenerative power supply is an electrical generator integrated directly into the unit and avoids any noise from the main power supply and thus provides an ultra-low noise AC signal to power the preamplifier. It regenerates the main power supply and blocks the noise of the electrical signal to obtain the most neutral sound.
First, a transformer converts the main voltage. DC conversion is carried out by Class A power supplies. A discrete symmetrical regenerative wave generator produces an ultra-low distortion wave at 50Hz.
Symmetrical amplifiers with powerful output stages drive regenerative transformers to produce extremely clean alternating current. This totally clean signal is then routed to separate Class A power supplies for the left and right channels.
The Class A DC power supply with a high input impedance will avoid any noise and allow the amplification stages to have a low output impedance.
In addition, the 4 R-Core transformers provide 295W of power to the system and NOVER capacitors of more than 95000µF are used to ensure a fluid current.
The R-7HE offers several Oversampling or NOS (Non-Oversampling) modes. If you wish to choose Oversampling, simply select the value "O". If you want to choose the NOS then you have to choose the value "N". You can then select one of the following modes to adapt the playback to your listening experience.
| Oversampling Filters | |
| Mode 0 | NOS Mode |
| Mode 2 | 2x Oversampling |
| Mode 4 | 4x Oversampling |
| Mode 8 | 8x Oversampling |
| NOS Filters | |
| Mode 1 | Simplest data processing |
| Mode 2 | FIFO data |
| Mode 3 | Fastest data processing |
| Specifications | |
| Product type | DAC R2R |
| SNR | > 120dB |
| Output impedance | < 5 Ohm (XLR, RCA) |
| Output level | RCA: 2.5V XLR: 5V ACSS: 2+2MA |
| Frequency response | 20Hz - 100kHz |
| THD | < 0.0005% |
| Input sensitivity | Coaxial 75 Ohm : 0.5Vp-p Optical : 19dBm |
| Supported OS (USB) | Windows, OSX, Linux, ISO |
| Sampling rate | USB, I2S: 32bits 44.1kHz - 384kHz / DSD 64-512 Coaxial, Optical: 24bits 44.1kHz - 192kHz |
| Inputs | 1* Coaxial RCA SPDIF 1* Coaxial BNC SPDIF 1* Optical Toslink 1* I2S LVDS via HDMI 1* USB Amanero 1* XLR |
| Outputs | 1* Balanced ACSS 1* Balanced XLR 1* Single-Ended RCA |
| General | |
| Consumption | 73W |
| Dimensions | 430*430*125mm |
| Housing material | 100% Aluminium |
| Color | Noir |
| Accessories | 1* Power cable 1* USB cable |
| Input | SPDIF |
| Input | BNC |
| Input | XLR |
| Input | Optical |
| Output | ACSS |
| Output | XLR |
| Output | RCA |
| DAC / ADC Chip | NC |
| Max sampling rate | 384kHz |
| Color | Black |
| Networking | No |
| Remote Control | No |
