AUDIO-GD SINGULARITY 19 WARMER DAC R2R 4x DA-M1 32Bit / 384KHz USB AMANERO Silver
Sale
By buying this product you get 79 loyalty points
Reference : 11853
799,00 €tax incl.
665,83 € tax excl.
AUDIO-GD SINGULARITY 19 WARMER - Money -
DAC R2R / 4x DAC DA-M1 / DSP / 384kHz / AMANERO
Very High Fidelity ...
The DAC-19 returns to the R2R SINGULARITY 19 version (in NOS mode set by default), with a DSP update and an additional TCXO clock dedicated to asynchronous transfer management. Thegreat novelty comes from its 4 DAC DA-M1 R2R working together to offer you performances still above expectations. This NEUTRAL version has been designed on the stage image of the Master 7, a more neutral, more detailed, perforated, dynamic and sound. To achieve this result, only analog filters have been set differently than the WARMER version of the same model. This wormNEUTRAL can get a slightly warmer sound with a change of power cable and / or modulation cable, while the WARMER version will not be able to return to a neutral sound. Mr. Kingwa, the technical engineer in charge of all Audio-GD devices, has made this Singularity 19 fully programmable at the software level. That is, it can improve the audio performance of the device without affecting the hardware, but only by modifying the DSP software part. It iscapable of handling record sampling rates: up to 32Bit / 384kHz. Even if Audio-GD had already given it its nobility since 2005, the best technicians of the firm offer it here in its most accomplished form with outstanding performances.
Fashion without Oversampling "NOS"
The big onenovelty concerns the mode without Oversampling "NOS". The DSP 1 includes two distinct operating modes. This new DSP makes it possible to get rid of the noise problems related to the NOS mode while keeping its advantages in terms of musical pleasure thanks to a non-destructive -6dB filter. Mode 1 favors the speed of data transfer, the second allows processing on DSP FIFO with algorithm.This DAC Neutral is delivered and set by default in NOS mode.
A particularly efficient connection
The built-in R2R DA-M1 DACs allow you to manage sources up to 32 Bit / 384kHz via its USB port, and up to 24Bit / 192kHz via the SPDIF. The SINGULARITY 19 has 4 inputs: BNC, Coaxial SPDIF, Optical Toslink, and USB AMANERO, as well as 2 analog outputs: RCA and ACSS. Its SPDIF interface is extremely powerful in terms of data processing for better audio quality.
Great musicality and exceptional dynamics
R2R / 384kHz / USB AMANERO / TCXO / ACSS
Every product of the brand is scrupulously tested in all seams with one of the most powerful systems in the world: the Audio Analyzers 2700 Series from Audio Precision. The SINGULARITY 19 is equipped with an R-Core transformer, WIMA capacitors, and Date resistors. It is designed around 4 DAC R2R DA-M1 and Altera Cyclone DSPs working in parallel, as well as a Class A ACSS discrete circuit without any PDO with separate power supply.
TCXO - 100MHz
Audio-GD devices are equipped with the standard 80MHz clock, except this Audio-GD SINGULARITY 19 includes 2 TCXO Ultra Low Jitter 100MHz clocks. These TCXO (Crystal Oscillator) clocks are more accurate and significantly lower the jitter.
4x DAC R2R DA-M1
The DAC moduleAudio-GD DA-M1 R2R is based on the same technology as a "Ladder DAC R2R" digital analogue-to-digital converter type Burr Brown PCM1704. The R2R technology is recognized for its qualities subjectively related to a musical sense of dynamics and timbres of instruments closer to reality, more natural. Each SMD resistor (24bit x 2 = 48bit) handles a digital bit (0 or 1) to translate it into analog electrical information.
<tbody>
Characteristics :
THD + N: 109dB (22Hz - 22kHz)
THD: <0.0008% (20Hz - 20kHz)
Frequency response: 20Hz - 20kHz (-1dB)
Output Level Max: 2mA (ACSS) / 2.5V (RCA)
Output Impedance: 10 Ohm (RCA) /> 1000
Input Sensitivity: 0.5Vp-p (Coaxial, 75 Ohm) / 19dBm (Optical)
Supported Sampling Rates: I2S USB (44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz, 352kHz, 384kHz) / Coaxial (44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz 192kHz)
Inputs: BNC / Coaxial SPDIF / Toslink optics / I2S via USB Outputs: RCA / ACSSUSB compatible iPhone and iPad via Apple Camera Kit
Power Consumption: 15WDimensions: 320x240x80mmChassis 100% aluminum, black anodized Weight: 5kgIncluded Accessories: Power cord / USB cableThis DAC Warmer is shipped and set to NOS mode by default.
ColorSilver
