Parfait. Facile à installer . Correspond bien à mon besoin.
USB DAC 32Bit/384kHz SA9227 / ES9018K2M V3 TCXO with optical output
The famous Audiophonics U-SABRE DAC has been upgraded to a PRO version, with an update of its main components. The decoding is now done thanks to a SABRE ES9018K2M chip, as well as a new USB SA9227 chip accepting sampling rates up to 32bit / 384kHz, and native DSD64.
This U-SABRE PRO DAC can be self-powered via USB with any smartphone or computer. However, if the amperage of your device is not sufficient, a DC 5.5 / 2.1mm jack input allows you to power it with an external 5V DC power supply.
This version features a 24bit/96kHz Mini Toslink digital output paired with the 3.5mm analogue jack output.
This U-SABRE PRO features an excellent SABRE ES9018K2M DAC chip capable of reading high resolution files, up to 32bit 384kHz PCM and native DSD64, for true high-fidelity listening.
The SA9227 chip is a high performance 32bit USB receiver, allowing high resolution audio files. Furthermore, this receiver is plug & play and is natively recognized by Windows, Linux, OS X, and is even OTG.
Compatibility | Native Plug & Play on Windows, Linux and OS X / OTG |
DAC chip | ESS Sabre ES9018K2M |
USB chip | SAVIAUDIO SA9227 (We recommend the use of a quality USB cable with a length of less than 1.5m) |
Power supply | Via USB port (external 5V DC power supply possible on 5.5 / 2.1mm jack) |
Clock | Very high precision TCXO 100Mhz (0.5ppm) |
ASIO support | Yes (driver in the "Download" tab) |
Supported sampling rates | 32bit / 384kHz / DSD64 |
Output level | 3V RMS / 12 Ohm |
Power supply | Jack DC 5V (+ = center pin / - = outer pin) |
Input | USB |
Output | RCA |
Output | Optical Mini-Toslink |
Output | Jack 3.5mm |
DAC / ADC Chip | ES9018K2M |
Max sampling rate | DSD64 |
Max sampling rate | 384kHz |
Color | Black |
Networking | No |
Remote Control | No |
Interface chip | SA9227 |
Average votes 5.0 / 5 5 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Dominique L.
Stefano D.
Lennart H.
Alexandre p.
Ghislain B.
