AUNE X1s 10TH ANNIVERSARY EDITION DAC ES9018K2M and Headphone Amplifier 32bit 384kHz DSD128 Silver
For the 10th anniversary of its excellent X1, Aune offers its headphone amplifier and DAC X1s in an updated version, with components of better quality, for a price unchanged. A versatile device designed for HiFi use as well as to be associated with a computer
Reference : 12755
249,00 €tax incl.
207,50 € tax excl.
AUNE X1S 10TH ANNIVERSARY EDITION
DAC ES9018Q2M and Headphone amplifier 32bit 384kHz DSD128
aune x1s 10th Anniversary
An improved 10th Anniversary Edition
For the 10th anniversary of its excellent X1, Aune offers its headphone amplifier and DAC X1s in an updated version, with better quality components, for an unchanged price. A versatile device designed both for HiFi use and to be associated with a computer.
An high-performance DAC
In this version 10th Anniversary the X1s keeps its excellent ESS ES9018K2M conversion chip with its 3 filtering modes (Fast Roll-Off / Slow Roll-Off / Minimum phase) and its ability to support high resolution audio files : PCM up to 32bit 384kHz and DSD128.
An enhanced version of the X1s
For this revision of the X1S, Aune makes significant modifications to its already excellent device. The brand proposes here a more precise clock for a weaker jitter and a more precise restitution, from new transistors bringing a new dynamic and a changed ECPU to offer a greater musicality. In addition, the modification of the output transistors allows the device to gain power in order to adapt to a wider variety of headsets.
Aune X1s 10th Anniversary Graphique THD+N
This design allows the device to largely limit its noise to a value of 2µV and a distortion to 0.0003%. Thus, this X1s is able to reproduce a pure and detailed sound. In addition, it also offers 126dB dynamics for impeccable responsiveness.
complete connectivity
The X1s offers a fairly complete standard connection system that will allow you to connect most of your HiFi devices without difficulty. On the inputs side, we mainly recommend the USB input, more powerful but we can also benefit from a Stereo RCA input, a Coaxial input and an Optical input. In addition, it should be noted that it is possible to connect an OTG compatible smartphone to the USB input. On the output side, there is of course a fixed level Stereo RCA and a Coaxial output.
aune x1s connectique
Front panel :
1.1Input selector
1.2Active source indicator
1.3Jack 6.35mm headphone output
1.4Volume knob
Rear panel :
2.1Power supply connector
2.2RCA Line input
2.3RCA Line output
2.4Coaxial output
2.5Optical input
2.6USB-B Input
2.7Coaxial input
2.8Power ON/OFF button
Original and ergonomic design
The X1s offers an original design by adopting a curved case on top and integrating curved lines on each side. Moreover, Aune succeeded in erasing all screws from the surface of its case giving it a monolithic appearance of the most beautiful effect.
Lhe DAC also offers simple and intuitive controls since the front panel potentiometer will allow both adjusting the volume of the digital outputs and selecting a DAC filter. The push button on the front will allow you to choose your source.
Reviews
Aune X1s 10th Anniversary Edition review by Headfonics (EN) test aune x1s par headfonics
Classical Aune X1s review by HeadFi (EN)
test aune x1s par headfi
Aune X1s review by Qobuz
" A beautiful device with first-class manufacturing quality, the DAC Aune X1s offers total compatibility with the digital audio files available today, in number or in homeopathic form, as well as very good sound performance that can be perfectly enjoyed thanks to its powerful and powerful headphone amplifier. "
Test Qobuz
DACES9018K2M
Headphone output power200mW @ 300Ω (0.1% @ 1kHz 0dB)
560mW @32Ω (0.1% @ 1kHz 0dB)
Sampling ratesUSB : 32 bit 384kHz / DSD128
Coaxial : 24bit 192kHz
24bit 192kHz
Output voltage @ 0dB (RCA)2.1Vrms
Frequency response (RCA)20Hz - 20kHz (±0.5dB)
Dynamic range (RCA)126dB
THD+N (RCA)-110dB @ 1kHz
IMD+N (RCA)-110dB @ 19kHz & 20kHz
Stereo crosstalk (RCA)-112dB
Connectors : Inputs
USB-B1x
Optical1x
RCA Stéréo1x
Coaxial1x
Connectors : Outputs
Stereo RCA1x (fixed level)
Coaxial1x
Power supply±12V 0.8A
Dimensions193 x 144 x 50mm
Poids910g
Housing material100% Aluminium
ColorSilver
Package1x Aune X1s 10th Anniversary Edition
1x sector adapter
1x USB cable
1x Jack 6.35 to Jack 3.5mm adapter
Aune X1s dimensions
Aune X1s RMS
Aune X1s RMS
OutputCoaxial SPDIF
OutputJack 6.35mm
ColorSilver
For the 10th anniversary of its excellent X1, Aune offers its headphone amplifier and DAC X1s in an updated version, with components of better...
