DENAFRIPS PONTUS 15TH DAC R2R NOS Balanced Black
The Denafrips Pontus 15TH NOS R2R balanced dual-mono DAC represents an excellent high-end digital-to-analog conversion solution, offering ececption sound performance. Here, each channel is equipped with an independent high-speed FPGA to facilitate digital signal decoding by means of 4 sets of high-precision R-2R networks.
By buying this product you get 230 loyalty points
Reference : 19439
2 300,00 €tax incl.
1 916,67 € tax excl.
Shipping date: 07-05-2025.
Denafrips Pontus 15TH DAC R2R NOS Balanced 1536kHz DSD1024 Black
Denafrips Pontus 15TH : front view
The Denafrips Pontus 15Th NOS R2R balanced dual-mono DAC represents an excellent high-end digital-to-analog conversion solution, offering ececption sound performance. Here, each channel is equipped with an independent high-speed FPGA to facilitate digital signal decoding by means of 4 sets of high-precision R-2R networks. The choice of such a design results in very low linearity error, high decoding speed and low digital noise, not only to ensure that the audio signal has very low distortion, but also to ensure very low background noise.
All digital inputs are buffered in FIFO memory and reclocked by integrated femtosecond oscillators. Excellent jitter rejection makes the Denafrips Pontus II 12Th-1 much less dependent on the quality of the source equipment's clock.
Points clés :
  • Proprietary R2R + DSD architecture
  • True balanced 24bit R2R + 6bit DSD (32-step FIR filters)
  • Precision resistors (0.005%)
  • Femtosecond clocks 45.1548MHz, 49.152MHz
  • Ultra-low-noise isolated power supply
  • Support for PCM streams up to 1536kHz and DSD up to DSD1024 (USB and I2S)
  • Proprietary USB interface via STM32F446 MCU
  • Thesycon USB driver
  • Dual AES/EBU input
  • I2S pinout configuration
  • Sharp / Slow filters
  • I2S DSD channel configuration
  • Power supply circuit in silver
Denafrips Pontus 15Th: A customized power stage
The Denafrips Pontus 15TH features a linear power supply stage specifically developed for this DAC and isolated by a 1.5mm-thick metal case to considerably limit interference.
Placed beneath the DAC board, this power supply circuit embeds two large 80VA O-Core transformers for the digital and analog sections, low ESR capacitors and a super-linear linear power supply to provide the conversion stage with a clean, stable electrical signal.
Denafrips Pontus 15Th: Comprehensive connectivity
The Denafrips Pontus 15TH features comprehensive connectivity for easy integration into the vast majority of audio systems. Inputs include USB-B, I2S via HDMI, Toslink optical, AES/EBU and coaxial. On the output side, the DAC provides unbalanced RCA and balanced XLR.
Denafrips Pontus 15Th: Connectors
1Balanced XLR output
2Single-ended RCA output
3Coaxial input (RCA)
4Coaxial input (BNC)
5 / 6AES/EBU input
7Optical input
8I2S input via HDMI
9USB-B input
10Power connector
Product typeBalmanced NOS R2R DAC
Inputs1x USB-B
1x I2S via HDMI
1x Optical Toslink
2x AES/EBU
1x Coaxial BNC
1x Coaxial RCA
Outputs1x Balanced stereo XLR
1x Single-ended stereo RCA
Supported sampling ratesUSB / I2S : PCM up to 24bit 1536kHz, DSD up to DSD1024
Optical / Coaxial / AES : PCM up to 24bit 192kHz, DSD DoP64
Output level / impedance2Vrms @ 625 Ohm
4Vrms @ 1250 Ohm
Sampling modesNon-oversampling (NOS)
Oversampling (OS)
Frequency response20Hz - 70kHz (-3dB)
THD+N0.0025%
SNR120dB
Dynamic range> 121dB
Crosstalk-110dB
Supply voltage100-240VAC 50/60Hz
Consumption<= 20W
Dimensions320 x 330 x 80mm
Weight12.5kg
Package1x Denafrips Pontus 15TH Black
InputI2S via HDMI
InputAES/EBU
DAC / ADC ChipR2R LADDER DAC
Max sampling rate1536kHz
Max sampling rateDSD1024
DENAFRIPS PONTUS 15TH DAC R2R NOS Balanced 1536kHz DSD1024 Black
The Denafrips Pontus 15TH NOS R2R balanced dual-mono DAC represents an excellent high-end digital-to-analog conversion solution, offering...
