FIIO WARMER R2R DAC R2R Tube Buffer Silver
New
The FiiO Warmer R2R is a DAC combining discrete R2R conversion, a JJ E88CC tube stage and a linear power supply, all housed in a retro-style chassis equipped with a mechanical VU meter. It aims to deliver both accurate and warm sound reproduction with a typically analogue tone.
By buying this product you get 37 loyalty points
Reference : 21501
379,00 €tax incl.
315,84 € tax excl.
FiiO Warmer R2R DAC R2R 32bit 384kHz DSD256 Tube Buffer E88CC Silver
FiiO WARMER R2R : Front view
FiiO Warmer R2R: 24-bit DAC R2R
The FiiO Warmer R2R is based on a 24-bit R2R converter designed around a network totalling 192 precision resistors, divided into four channels of 48 resistors each. This entirely discrete architecture ensures conversion without a traditional DAC chip and emphasises warmer sound reproduction. The device also offers a choice of NOS (Non-Oversampling) or OS (Oversampling) modes, allowing for either a more raw and natural sound or a more detailed and cold sound, using oversampling up to 384kHz.
FiiO WARMER R2R : R2R circuit
FiiO WARMER R2R : Tubes
FiiO Warmer R2R: Tube buffer
The analogue section features four JJ Electronic E88CC tubes, used as a buffer stage to give the sound reproduction a warmer, more organic texture. These tubes, renowned for their stability and consistency, contribute to the deliberately soft, analogue sound signature of the Warmer R2R.
FiiO Warmer R2R: Mechanical VU meter
The Warmer R2R features a backlit mechanical stereo VU meter, providing immediate visual feedback on output levels. Beyond its aesthetic appeal, this choice provides a clear indication of the signal's dynamic behaviour, in a decidedly retro style.
FiiO WARMER R2R With FiiO K15
FiiO WARMER R2R : Transformateur
FiiO Warmer R2R: Linear power supply
The power supply is based on a 46W toroidal transformer. This linear approach ensures a clean power supply to the digital, analogue and tube stages, limiting interference and contributing directly to the overall stability of the device.
FiiO Warmer R2R: UAC Mode 1.0 and 2.0
Finally, the Warmer R2R offers a choice between UAC 1.0 and UAC 2.0 modes. This choice maximises compatibility with a wide variety of devices, including computers, consoles, media players, and USB sources, not all of which support the UAC 2.0 standard.
FiiO WARMER R2R : NOS / OS mode
Product typeDAC
Buffer
Inputs1x USB-C
1x Coaxial
1x Optical Toslink
1x Balanced stereo XLR
DACR2R 24bit
Supported sampling ratesUSB: PCM up to 32bit 384kHz / Native DSD up to DSD256
Coaxial: PCM up to 24bit 192kHz
Optical: PCM up to 24bit 96kHz
Buffer4x JJ Electronic E88CC
Output levelRCA: ≥ 1.8Vrms + 1.8Vrms
XLR: ≥ 3.8Vrms + 3.8Vrms
Frequency response20Hz-45kHz
Signal-to-noise ratio (SNR)≥ 114dB
Noise Floor≤ 7μV
Total harmonic distortion more noise (THD+N)≤ 0.053%
Power supply200-240V AC 50/60Hz
Dimensions223.5 x213 x 66.8mm
Weight2.9kg
Package1x FiiO Warmer R2R
1x Power cable
1x USB-A to USB-C cable
DAC / ADC ChipR2R LADDER DAC
Max sampling rate384kHz
Max sampling rateDSD256
ColorSilver
correspond parfaitement à mes objectifs
Je cherchais avant tout à réduire la fatigue d’écoute, à adoucir les voix féminines et à pouvoir écouter de la musique classique, notamment les violons, sans sensation d’agression.
Ce DAC FiiO R2R Warmer répond parfaitement à mes attentes. L’écoute est devenue plus douce, plus naturelle et surtout beaucoup plus agréable sur la durée. Je peux désormais écouter de longues sessions sans fatigue, avec des voix et des instruments mieux maîtrisés.
Seul petit bémol purement personnel : j’aurais préféré une façade plus sobre, sans vu-mètres, mais cela reste un détail esthétique.
This review has been posted for FIIO WARMER R2R DAC R2R Tube Buffer E88CC 32bit 384kHz DSD256 Silver
The FiiO Warmer R2R is a DAC combining discrete R2R conversion, a JJ E88CC tube stage and a linear power supply, all housed in a retro-style...
