SMSL SU2 DAC ES9039Q2M 24bit 192kHz DSD DoP64
The SMSL SU2 is a compact DAC built around audiophile-grade components. The digital-to-analog conversion is handled by an ESS ES9039Q2M DAC chip, allowing it to support streams up to PCM 24bit 192kHz and DSD DoP64 while delivering excellent technical performance, including a 130dB dynamic range and THD+N as low as 0.00006%.
Reference : 21526
109,00 €tax incl.
90,83 € tax excl.
Shipping date: 17-11-2026.
Photo of the SMSL SU2
The SMSL SU2 is a compact DAC built around audiophile-grade components. The digital-to-analog conversion is handled by an ESS ES9039Q2M DAC chip, allowing it to support streams up to PCM 24bit 192kHz and DSD DoP64 while delivering excellent technical performance, including a 130dB dynamic range and THD+N as low as 0.00006%. A set of four OPA1612 op-amps enables the SU2 to deliver an output level of 4.7Vrms via balanced XLR and 2.3Vrms via its RCA output. In terms of inputs, it offers a full range of optical connectivity including Toslink optical, coaxial, and AES/EBU, ensuring perfect compatibility with many sources such as a CD player or digital transport.
Key features of the SMSL SU2
SMSL SU2
SMSL SU1
DAC Chip
ESS ES9039Q2M
AKM AK4493S
USB Interface
XMOS XU-316
Inputs
Toslink Optical, Coaxial SPDIF, AES/EBU
USB, Toslink Optical, Coaxial SPDIF
Outputs
RCA, XLR
RCA
MQA
Not supported
Supported
MQA-CD
Not supported
Supported
DSD
DSD DoP64
Supported
Op-Amps
4x OPA1612
1x OPA1612
Jitter Elimination Technology
CK-03 Clock Module
CK-03 Clock Module
Power Supply
AC
USB-C
SMSL SU2: LED operating indicator
On the front panel of the SMSL SU2 DAC, there is an intelligent LED indicator system that displays real-time operating information such as selected input type, sampling rate, left and right channels, and more.
SMSL SU2 LED operating indicator system
SMSL SU2 Overview
SMSL SU2 overview
1Power / Source selector
2LED indicator
3Balanced XLR output
4Single-ended RCA output
5Coaxial input
6Toslink optical input
7AES/EBU input
8AC power input
Test of the SMSL SU2 by Audio Science Review
"This is a high performing DAC. I loved the fact that it is brainless, real plug&play device. I'm old, I know, and I like my good old SPDIF. I'm really happy to see the type of performances we can get from it, more than 40 years after it was released, especially on jitter perspective.
My use case is very simple, I connect it to a CD player and my preferred one has an AES SPDIF out. I don't have anything to think about, again, plug and play. I saw some pictures of the SU-2 with the SMSL PL200T and I used it as a DDC feeding the SU-2 for some of the above tests (Jitter Test with AES and Coax). It also helped me to verify gapless playback."
Technical Specifications
Product TypeDAC
DAC ChipESS ES9039Q2M
Op-Amps4x OPA1612A
Inputs1x Coaxial
1x Toslink optical
1x AES/EBU
Outputs1x Balanced XLR
1x Single-ended RCA
Output LevelXLR: 4.7Vrms
RCA: 2.3Vrms
THD+NXLR: 0.00006% (-123.5dB)
RCA: 0.00008% (-121.5dB)
Dynamic RangeXLR: 130dB
RCA: 126dB
SNRXLR: 130dB
RCA: 126dB
Supported Sampling RatesPCM 24bit 192kHz
DSD DoP64
Power Supply100-240V AC
Power Consumption< 2.3W
Standby Power Consumption< 0.1W
Dimensions150 x 42.5 x 133.1mm (W x H x D)
Weight532.6g
Package Contents1x SMSL SU2
1x AC power cable
InputAES/EBU
DAC / ADC ChipES9039Q2M
Max sampling rate192kHz
2 reviews
Final Invoice
Dear,
Thank you for the product I received. Everything is fine. However, I would like to request a final invoice. The one available on your website is a proforma invoice – I can't settle it. I would also like to request that your company details include your VAT number. I would be grateful if you could send me the invoice.
Gregory
Invoice details
EUROZET Radio sp. z o.o.
ul. Czerska 8/10
00-732 Warszawa
NIP 5252208814
This review has been posted for SMSL SU2 DAC ES9039Q2M 24bit 192kHz DSD DoP64
DAC orienté Batteur
A peu près deux jours qu'il tourne sur des enceintes de monitoring en classe D sur sorties symétriques.
L'écoute reste très analytique sur le haut du spectre qui reste plus concernée. Concernant des Adam audio T7V modestes mais avec un couplage intéressant, l'extension sur les infra fréquences ne sont pas ressentie, pour le moment, mais suffisante pour se faire une idéé du potentiel après rodage.
J'écoute Ethnicolor de JM Jarre en version remastérisé, Voila.
Il y a de la chaleur dans les voix, les samples, avec une certaine étroiteté qui demande de pousser son amplificateur en abaissant la part logicielle ou de la norme EBU R 128 dans mon cas.
La séparation stéréo et la distinction des instruments est bluffante, mais pique parfois, dans mon cas une section differente ou d'une différente impédance pour mes cables de modulations reste nécessaire.
Les transitions entre séquences rythmiques, nappes peuvent parfois surprendre, avec un retentissement plutôt froid uniquement dans le bas registre où l'on demanderait plus de rondeur mais il doit s'agir d'une limitation de mes enceintes.
Les caisses claires sont propres manquant toutefois "d'épaisseur" pour encore une fois revenir sur le maillon a améliorer.
Le suivi et la rondeur des basses sont très lisibles avec parfois une très belle extension emportant le local d'écoute entier !!
Concernant Ethnicolor part I, on redoute la deuxième section du titre qui se veut plus explosive, fracassante, ou bouleversante... autour du crescendo à partir de la 7 minutes,
L'exercice reste, ici, bien maitrisé avec une certaine douceur globale ressentie dans l'ensemble sur les basses slappés sans heurter.
Dans l'ensemble, Il mérite une attention vraiment particulière, le tout ayant été testé sur entrée optique pour moi suffisamment polyvalente pour concerner beaucoup, beaucoup de disques.
The SMSL SU2 is a compact DAC built around audiophile-grade components. The digital-to-analog conversion is handled by an ESS ES9039Q2M DAC chip,...
