FOSI AUDIO Q6 DAC
New
The Fosi Audio Q6 is a small, minimalist, high-performance desktop DAC based on an AKM AK4493SEQ solution and an XMOS XU316 USB interface. It supports high-fidelity sampling rates up to PCM 32bit 768kHz and DSD512, with clean, uncolored conversion for the most balanced sound reproduction.
Reference : 20773
109,00 €tax incl.
90,83 € tax excl.
Fosi Audio Q6 DAC AK4493SEQ XMOS XU316 PCM 32bit 768kHz DSD512
Photo of FOSI AUDIO Q6
The Fosi Audio Q6 is a small, minimalist, high-performance desktop DAC based on an AKM AK4493SEQ solution and an XMOS XU316 USB interface. It supports high-fidelity sampling rates up to PCM 32bit 768kHz and DSD512, with clean, uncolored conversion for the most balanced sound reproduction. In terms of performance, it offers ultra-low distortion with a THD+N of 0.00012%, a noise figure of just 2.8uV and an SNR of up to 121dB. It also features a combination of DIP8-mounted AOP OPA1612 + NE5532DR. Control of the device is simple and efficient. Connectivity includes three digital inputs: USB-C, Toslink optical and coaxial, as well as an RCA output and a subwoofer output for setting up a 2.1-channel system with an active subwoofer.
FOSI AUDIO Q6 highlights
Fosi Audio Q6 DAC overview
1Switch ON-OFF
2Sampling rate indicator
3Input switch
4USB-C input / USB 5V 2A power port
5Toslink optical input
6Coaxial input
7RCA output
8Subwoofer output
Product typeDAC
DAC chipAK4493SEQ
USB interfaceXMOS XU-316
OPAOPA1612 + NE5532DR
Inputs1x USB-C
1x Optical Toslink
1x Coaxial
Outputs1x RCA output
1x Subwoofer output
Supported sample ratesUSB: PCM up 32bit 768kHz, DSD up to DSD512
Toslink optical / Coaxial: PCM up to 32bit 192kHz
THD< 0,00012%
SNR≥ 121dB
USB-compatible OSXP/W7/W8/W10/W11/MAC/Linux
Power supply5V 2A via USB-C
Dimensions105 x 142 x 37mm
Weight410g
Package1x DAC Q6
1x USB-C to USB-C/A cable
OutputSubwoofer
DAC / ADC ChipAK4493SEQ
Max sampling rate768kHz
Max sampling rateDSD512
ColorGray
FOSI AUDIO Q6 DAC AK4493SEQ XMOS XU316 32bit 768kHz DSD512
The Fosi Audio Q6 is a small, minimalist, high-performance desktop DAC based on an AKM AK4493SEQ solution and an XMOS XU316 USB interface. It...
