The Fosi Audio Q6 is a small, minimalist, high-performance desktop DAC based on an AKM AK4493SEQ solution and an XMOS XU316 USB interface. It supports high-fidelity sampling rates up to PCM 32bit 768kHz and DSD512, with clean, uncolored conversion for the most balanced sound reproduction. In terms of performance, it offers ultra-low distortion with a THD+N of 0.00012%, a noise figure of just 2.8uV and an SNR of up to 121dB. It also features a combination of DIP8-mounted AOP OPA1612 + NE5532DR. Control of the device is simple and efficient. Connectivity includes three digital inputs: USB-C, Toslink optical and coaxial, as well as an RCA output and a subwoofer output for setting up a 2.1-channel system with an active subwoofer.
1 | Switch ON-OFF |
2 | Sampling rate indicator |
3 | Input switch |
4 | USB-C input / USB 5V 2A power port |
5 | Toslink optical input |
6 | Coaxial input |
7 | RCA output |
8 | Subwoofer output |
Product type | DAC |
DAC chip | AK4493SEQ |
USB interface | XMOS XU-316 |
OPA | OPA1612 + NE5532DR |
Inputs | 1x USB-C 1x Optical Toslink 1x Coaxial |
Outputs | 1x RCA output 1x Subwoofer output |
Supported sample rates | USB: PCM up 32bit 768kHz, DSD up to DSD512 Toslink optical / Coaxial: PCM up to 32bit 192kHz |
THD | < 0,00012% |
SNR | ≥ 121dB |
USB-compatible OS | XP/W7/W8/W10/W11/MAC/Linux |
Power supply | 5V 2A via USB-C |
Dimensions | 105 x 142 x 37mm |
Weight | 410g |
Package | 1x DAC Q6 1x USB-C to USB-C/A cable |
Input | USB |
Input | Optical |
Input | SPDIF |
Output | Subwoofer |
Output | RCA |
DAC / ADC Chip | AK4493SEQ |
Max sampling rate | DSD512 |
Max sampling rate | 768kHz |
Color | Gray |
Networking | No |
Remote Control | No |
