HOLO AUDIO CYAN 2 Balanced DAC
Holo Audio presents the big brother of its CYAN DAC, the CYAN 2. Like its predecessor, this is a balanced R2R DAC, based on discrete resistor networks. In addition, it operates in NOS (Non-Over-Sampling) mode for very pure, authentic signal reproduction.
4.9 / 5
By buying this product you get 138 loyalty points
Reference : 18584
1 389,00 €tax incl.
1 157,50 € tax excl.
Shipping date: 17-06-2025.
HOLO AUDIO CYAN 2Balanced DAC R2R NOS 32bit 1536kHz DSD1024
Photo of HOLO AUDIO CYAN 2
Holo Audio presents the big brother of its CYAN DAC, the CYAN 2. Like its predecessor, this is a balanced R2R DAC, based on discrete resistor networks. In addition, it operates in NOS (Non-Over-Sampling) mode for very pure, authentic signal restitution. Here are the main improvements on version 2 of the CYAN DAC:
  • It is equipped with two independent R2R networks, the first of which handles the primary DA conversion of PCM streams, while the second (with vector stepping) handles the DA conversion of DSD streams.
  • A new, more efficient deglitching technology is integrated. It doesn't generate any unwanted noise or effects.
  • The CYAN 2 has better measurements, with a SINAD of over 106dB and a dynamic range of over 127dB.
  • It now supports sampling rates up to PCM 32bit 1536Mhz and native DSD up to DSD1024 via its USB port.
  • The USB interface uses proprietary software with ultra-low latency and a data transmission reliability rate 2 to 4 times higher than usual interfaces on the market.
Native DSD support
Holo Audio's CYAN 2 DAC is one of the first to support native DSD via its R2R ladder architecture. The CYAN 2 module has been specially optimized for this application, and runs on MAC (DOP), Linux (DOP), and Windows/PC (Direct Native and DOP).
Holo Audio CYAN 2: an Altera MAX II CPLD
The CYAN 2's Altera MAX II CPLD is used to process the clock signal and optimize the quality of the digital sound signal by considerably reducing the jitter rate.
Photo of CPLD Altera Max II
Holo Audio CYAN 2 DAC: I2S input via HDMI
Equipped with an I2S port via HDMI connector, the CYAN 2 lets you enjoy the very best in audio transmission. Please note that the pinout is proprietary to Holo Audio, although it is similar to the PS Audio standard. Left and right channels are inverted for DSD streams.
Please note that I2S is not the same as HDMI Audio/Video signals. Never connect an HDMI device to the CYAN 2's I2S port. Make sure your source device is I2S-compatible and has a similar pinout configuration.
HOLO AUDIO CYAN 2 I2S pinout diagram
R2R DAC Holo Audio CYAN 2 connectors
HOLO AUDIO CYAN 2 connector overview
1RCA analog output
2Balanced XLR analog output
3SPDIF Coaxial input
4I2S input via HDMI
5Toslink optical input
6USB-B input
7AES/EBU input
8Power socket / Fuse slot / Power switch
This product works with both 220V AC and 110V AC supply voltage. By default, however, it is set for use with 220V AC. For use on 110V AC, it is necessary to set the device to this supply voltage via an internal switch before use and connection.
Product typeBalanced DAC R2R
Inputs1x USB-B
1x AES/EBU
1x Optical Toslink
1x SPDIF Coaxial
1x I2S via HDMI
Outputs1x RCA
1x Balanced XLR
Supported sample ratesUSB (Galvanic isolation) : PCM 32Bit 1536MHz, DSD DOP64-512, DSD Native up to DSD1024
I2S: PCM 32Bit 1536MHz, DSD Native up to DSD1024
AES/EBU, Optical Toslink, SPDIF Coaxial: PCM 24bit 192kHz, DSD DOP64
Input selectionAutomatic
MEASUREMENT OF ANALOG OUTPUTS
PCM 48K NOSTHD +N : 0.0005% @ 1kHz (-106dB)
DNR : -127dB
Output voltages : 2.5Vrms (RCA), 5Vrms (XLR)
DSD128XTHD +N : 0.0002% @ 1kHz (-114dB)
DNR : -115dB
Output voltages : 1.25Vrms (RCA), 2.5Vrms (XLR)
general
Adjustable power supply220-230V 50/60Hz (fusible : 2A SB 5x20mm)
110-115 V 50/60 Hz (fusible : 4A SB 5x20 mm)
(power cable not included)
Energy consumption20W
Dimensions300 x 200 x 48mm
Weight3.5kg
Package1x DAC R2R Holo Audio CYAN 2
1x USB-A to USB-B cable
InputAES/EBU
InputI2S via HDMI
DAC / ADC ChipR2R LADDER DAC
Max sampling rateDSD1024
Max sampling rate1536kHz
7 reviews
Incroyable
En général les avis n'aiment pas le fait que le Cyan 2 ne laisse aucun choix de réglage, au contraire je trouve que c'est parfait vous avez le meilleur systématiquement sans passer par des menus et du bidouillage. En ce qui concerne la performance ce DAC est incroyable de pureté précision rapidité neutralité musicale! Il en coûte un peu mais le gain de qualité par rapport aux Teac Topping Marantz Gustard (de mes installations précédentes) est flagrant et jouissif. Merci Holo Audio
This review has been posted for HOLO AUDIO CYAN 2 Balanced DAC R2R NOS 32bit 1536kHz DSD1024
What a DAC!
After reading a lot of reviews and videos... I made the jump from my sub 1.000€ to this one. A friend of mine was so kind to give me for comparing a +/- 2.500€ R2R DAC.
Apart from the none existing input selection and the on/off button... the Cyan 2 is just better sounding.
It's clearer, deeper soundstage, more control and dryer punch in the Bass and more detailed (less laid back).
A fantastic device from Holo Audio!
Un rapport performance sur prix absolument fabuleux
En remplacement d’un Zodiac Gold Antelope Audio âgé de 10 ans, j’ai été tenté par un Topping ou un SMSL autour de 1000 €.
Mais je trouve que la gamme change trop rapidement chez ces deux constructeurs.
Pour l’écart de prix, les excellents commentaires et différentes revues + la qualité de fabrication, je pensais que ce choix était relativement raisonnable.
L’absence de sélecteur ne me dérange pas pour mon besoin
Je l’ai fait tourner H24 pendant 140 h en suivant son évolution.
Là il commence à vraiment s’exprimer.
Mes composants en aval, dont des enceintes actives pro de 22 ans d’âge m’ont permis de facilement constater l’énorme bond qualitatif à l’écoute, comme constaté dans les autres avis.
Incroyable
Petit retour après une semaine d'utilisation. Ce DAC est tout simplement incroyable, il me donne le sourire aux lèvres à chaque démarrage en procurant une texture à la musique que je n'avais pas encore connue. Je reviens sur la connexion I2S qui est finalement meilleure que l'USB, de plus j'utilise un streamer RED de la même marque qui a une sortie I2S native. Bon, 2 petits bemols quand même, les leds frontales sont trop vives à l'oeil et l'écoute en DSD est inférieure au PCM. Pour finir la qualité de fabrication est hors normes, un petit exemple, le fusible utilisé pour la partie alimentation est un fusible en céramique, fil d'argent avec connecteurs plaqué or ; Holo n'a pas lésiné sur les pièces de qualité. Bravo
Top DAC
Ce dac n'a pas usurpé sa réputation. Dès la sortie de la boîte, le son est déjà magnifique. Un dac comme je les aime, sans options, sans afficheurs, sans volume, sans filtre. Bien manufacturé, solide procurant une scène sonore incroyable avec beaucoup de dynamisme et un spectre bien en place. J'ai été surpris par les aigus arrondis et surtout les basses propres et profondes et il n'est même pas rôdé. Testé en USB et I2S, j'ai préféré l'USB. Alors si vous recherchez un DAC R2R NOS qui mérite son prix, je vous le conseille vivement.
Holo Audio presents the big brother of its CYAN DAC, the CYAN 2. Like its predecessor, this is a balanced R2R DAC, based on discrete...
