LAIV HARMONY R2R Balanced DAC Black
Laiv's Harmony DAC combines a neat, elegant minimalist design with discrete, balanced R2R digital/analogue conversion. With support for sampling rates up to DSD256 and PCM 768kHz and its internal CCHD-957 FEMTO clock, this DAC offers sound reproduction as close as possible to the original. Furthermore, the modular design of the Harmony DAC provides unrivalled flexibility, simple upgrades and easy maintenance.
By buying this product you get 299 loyalty points
Reference : 19276
2 999,00 €tax incl.
2 499,17 € tax excl.
Shipping date: 19-06-2025.
LAIV HARMONY DAC Balanced Discrete R2R DAC OS/NOS 768kHz DSD256 Black
LAIV HARMONY DAC : 3/4 view
Laiv DAC Harmony: resistance networks
Laiv DAC Harmony : Discrete balanced R2R architecture
The Harmony DAC benefits from an R2R digital/analogue conversion stage. This advanced audio technology is based on a ladder network of individual resistors arranged with a tolerance of 0.05% to achieve superior sound quality. With its emphasis on precision and quality, this technology enables clear and accurate sound reproduction, delivering an immersive listening experience with exceptional detail and fidelity.
Laiv DAC Harmony : Top-quality components
The Harmony DAC incorporates first-class components to support its R2R conversion. The internal clock is handled by a Crystek CCHD-957 oscillator, offering incredibly low phase noise of just -100dBc/Hz. The power supply for the various modules is delegated to Audio Note Kaisei and Rubycon ZLH capacitors, eliminating any impact that the electrical supply might have on sound reproduction. These high-end components are carefully integrated into every vital part of the Harmony DAC, guaranteeing superior performance and exceptional audio quality. Expect an immersive listening experience, rich in clarity and precision.
Laiv DAC Harmony: CRYSTEK clock
Laiv DAC Harmony : Flexible and easy-to-use
The Harmony DAC is designed to be as easy to use and flexible as possible. In fact, during its design, particular attention was paid to the user experience. All useful information is permanently visible on the device's OLED screen, furthermore, the dials are positioned in such a way that you won't accidentally push your DAC while using it. The same care has been taken with the remote control, which has the dual advantage of having fully customisable buttons and being able to control two devices simultaneously by flicking a simple switch. Finally, if you wish for the Harmony DAC to be synchronised with an external clock, this is perfectly possible thanks to the I2S input.
Laiv DAC Harmony: Diagram
6
1Power button
2Power LED
3Menu button
4Navigation dial
5RCA output
6Coaxial input
7USB-B input
8Fuse holder
9Power outlet
10XLR output
11I2S input
12Optical input
13Chassis grounding
Product typeDAC R2R
Inputs1x USB-B
1x Optical
1x Coaxial
1x I2S
Output1x Stereo XLR
1x Stereo RCA
ProcessorIntel Altera Cyclone FPGA
Supported sampling ratesUSB : Up to PCM 768kHz DSD256
Optical : Up to PCM 192kHz
Coaxial : Up to PCM 192kHz
I2S : Up to PCM 768kHz DSD256
Screen3.83’ monochrome OLED screen
Internal clockCRYSTEK CCHD-957
Frequency response20Hz-20kHz ± 0.25dB
Total harmonic distortion (THD)0.0035%
Crosstalk110 dB
Signal-to-noise ratio (SNR)123dB
Dynamic range110dB
Output impedanceXLR : 1200 Ω
RCA : 600 Ω
Power supply100V - 127V AC / 220V - 240V AC
Power consumptionStandby: 4W
On without music: 8W
With music: 10W
Weight4.3kg
Dimensions75x250x255mm
Package1x Laiv DAC Harmony
3x Speaker spikes with alignment card
1x Remote control (Batteries not included)
1x Power cable
1x Cleaning Cloth
InputI2S
DAC / ADC ChipR2R LADDER DAC
Max sampling rate768kHz
Max sampling rateDSD256
Remote ControlYes
LAIV HARMONY DAC Balanced Discrete R2R OS/NOS 768kHz DSD256 Black
Laiv's Harmony DAC combines a neat, elegant minimalist design with discrete, balanced R2R digital/analogue conversion. With support for...
