SMSL M300 MKII DAC AKM AK4497 XMOS 32bit 768kHz DSD512 Bluetooth 5.0 Apt-X Black
The SMSL M300 MKII is a powerful and compact DAC in an atypical format, now with a Bluetooth 5.0 connection. Integrating high quality components, it is the perfect ally to offer your HiFi audio system a quality digital/analog converter.
4.7 / 5
By buying this product you get 27 loyalty points
Reference : 14360
279,00 €tax incl.
232,50 € tax excl.
The MKII version of this product offers the Bluetooth 5.0 function, as well as a 3.5mm jack port for SPDIF Coaxial and Optical Toslink connection.
To use it, you can use a Mini-Toslink optical cable, or a 3.5mm Jack to RCA Male mono adapter for coaxial cable.
SMSL M300 MKII
DAC AKM AK4497 XMOS Dual NDK Clock 32bit 768kHz DSD512 Black
SMSL M300 DAC AKM AK4497 XMOS Double Horloge NDK 32bit 768kHz DSD512 Noir
The SMSL M300 MKII is a high-performance and compact DAC in an atypical format. Integrating high quality components as well as a Bluetooth 5.0 connection, it is the perfect ally to offer to your HiFi audio system a digital/analog converter capable of restoring your audio files with a beautiful transparency but also an astonishing sound richness.
AK4497 DAC & High-end components
The M300 is equipped with an AK4497EQ high-end DAC chip from AKM. The latter supports high sampling rates, in PCM up to 32bit 768kHz and in DSD up to DSD512. In addition, the chip uses the proprietary Velvet Sound architecture allowing it to provide a high SNR (128dB) and very low distortion (THD+N -116dB) for neutral and accurate reproduction, with a beautiful sound image.
This chip is combined with many quality components such as a second-generation XMOS USB interface, two ultra-low phase noise Japanese NDK clocks to significantly limit jitter on 44.1kHz / 48kHz and multiple frequencies, and finally a series of resistors and capacitors specially designed for audio use.
Design, Screen & Connectivity
All components are integrated into a beautiful CNC machined Aluminium housing, both robust and allowing to limit interference that could degrade the audio signal. The front panel is covered with a tempered glass plate of the most beautiful effect and a 1.54" IPS screen, allowing you to display all the information related to the reading of your files (input, filter, sampling rate, read format...). The control is done simply with the two buttons on the front panel, allowing you to turn the device on/off, select an input, change the display color or choose an audio filter.
The back of the device contains all the connectors. We find at the input of the SPDIF Optical / Coaxial via Jack 3.5mm, the Micro USB (XMOS), as well as the Bluetooth antenna. On the output side, the M300 offers balanced XLR or unbalanced RCA.
SMSL M300 review by Qobuz
" We really liked the fullness of the sound reproduction of the DAC S.M.S.L M300. The contribution of its various digital filters is interesting while preserving the excellent musical quality of this device. "
Test du SMSL M300 par Qobuz
This is a test of the previous version of the SMSL M300 (not the MKII version). The test is therefore available here for reference, but the MKII version is an improved version of the one presented in the test.
Product typeDAC
Inputs1x Micro USB XMOS
1x Bluetooth 5.0 AptX
1x S/PDIF Coaxial / Toslink via Jack 3,5mm
Outputs1x Single ended RCA
1x Balanced XLR
Output levelRCA : 2Vrms
XLR : 4Vrms
THD+N0.0004%
Dynamic rangeRCA : 120dB
XLR : 123dB
SNR116dB
USB compatibilityWindows 7 / 8 / 8.1 / 10
Mac OSX 10.6 or more
Linux
Sampling rate/ Bit depthUSB : Up to 32bit 768kHz / DSD512
Optique / Coaxial : Up to 24bit 192kHz
Consumption1.8W
Standby consumption< 0.1W
Dimensions (WxHxD)70 x 70 x 160mm
Weight500g
Power supply deliveredYes
Package1x SMSL M300 MKII
1x Power supply
1x Remote Control
1x Antenna
1x Optical cable
1x Jack 3.5mm to RCA cable
1x Micro USB to USB-A cable
DAC / ADC ChipAK4497EQ
Max sampling rate768kHz
Max sampling rateDSD512
Remote ControlYes
3 reviews
Avec son antenne il est parfait !
Dans un 1er avis j'avais critiqué la stabilité du Bluetooth, mais il me manquait l'antenne ! Problème aujourd'hui résolu, ce DAC me donne toute satisfaction.
This review has been posted for SMSL M300 MKII DAC AKM AK4497 XMOS 32bit 768kHz DSD512 Bluetooth 5.0 Apt-X Black
Ne lui manque qu'une bonne antenne
Un must pour audiophiles, qui dépoussière ma musique haute-définition comme jamais. Surtout lorsqu'on l'écoutait auparavant directement en sortie analogique de son PC ! Mais il y a un hic ... l'antenne Bluetooth est peu performante, essayée avec un PC et 2 smartphones qui fonctionnent pourtant très bien appairés avec d'autres périphériques. Coupures intempestives même à très courte distance, pertes de connexion difficiles à restaurer. Dommage avec plusieurs appareils nomades dans la maison.
Très bonne facture
Bonjour, ce Dac vaut bien un audio gd trois fois plus cher. Bonne dynamique et nécessite un rodage de 48 h. Meilleur rapport qualité prix et puce AKM. Pas de fonctions redondantes, mon système est bien optimisé avec ce Dac qui a bien progressé depuis sa première version. Très satisfait !
The SMSL M300 MKII is a powerful and compact DAC in an atypical format, now with a Bluetooth 5.0 connection. Integrating high quality components,...
