By buying this product you get 27 loyalty points
The MKII version of this product offers Bluetooth 5.0 function, as well as a Jack 3.5mm port for SPDIF Coaxial and Optical Toslink.
To use it, you can use an Optical Mini-Toslink cable, or a Jack 3.5mm to male mono RCA adapter for coaxial cable.
DAC AKM AK4497 XMOS Dual NDK Clock 32bit 768kHz DSD512 Red
SMSL's M300 MKII is a high-performance and compact DAC in an atypical format. Integrating high quality components as well as a Bluetooth 5.0 connection, it is the perfect ally to offer to your HiFi audio system a digital/analog converter able to restitute your audio files with a beautiful transparency but also an astonishing sound richness.
The M300 is equipped with a high-end AK4497EQ DAC chip from AKM. This supports high sample rates in PCM up to 32bit 768kHz and in DSD up to DSD512. In addition, the chip uses the proprietary Velvet Sound architecture to ensure high SNR (128dB) and very low distortion (THD+N -116dB) for a neutral and accurate reproduction with a beautiful sound image.
This chip is associated with many quality components such as a second generation XMOS USB interface, two Japanese NDK ultra low phase noise clocks to considerably limit jitter on 44.1kHz / 48kHz and multiple frequencies, and finally a series of resistors and capacitors specially designed for audio use.
All the components are integrated within a beautiful CNC machined Aluminium housing, which is both robust and allows to limit the interferences that could degrade the audio signal. The front panel is covered with a tempered glass plate and a 1.54" IPS screen to display all the information related to the playback of your files (input, filter, sampling rate, format read...). The control is simply done thanks to the two buttons on the front panel, allowing you to switch on / off the device, select an input, change the display color or choose an audio filter.
The back of the device contains all the connectors. We find in input of the Optical / Coaxial SPDIF via Jack 3.5mm, the Micro USB (XMOS), as well as the Bluetooth antenna. On the output side, the M300 offers balanced XLR or unbalanced RCA.
" We really liked the fullness of the sound reproduction of the DAC S.M.S.L M300. The contribution of its various digital filters is interesting while preserving the excellent musical quality of this device. "
This is a test of the previous version of the SMSL M300 (not the MKII version). The test is therefore available here for reference, but the MKII version is an improved version of the one presented in the test.
| Specifications | |
| Product type | DAC |
| Inputs | 1x Micro USB XMOS 1x Bluetooth 5.0 Apt-X 1x S/PDIF Coaxial / Toslink via Jack 3.5mm |
| Sorties | 1x Single-ended RCA 1x Balanced XLR |
| Output level | RCA : 2Vrms XLR : 4Vrms |
| THD+N | 0.0004% |
| Dynamic range | RCA : 120dB XLR : 123dB |
| SNR | 116dB |
| USB Compatibility | Windows 7 / 8 / 8.1 / 10 Mac OSX 10.6 or later Linux |
| Sampling rate / Bit depth | USB : Up to 32bit 768kHz / DSD512 Optical / Coaxial : Up to 24bit 192kHz |
| General | |
| Consumption | 1.8W |
| Standby consumption | < 0.1W |
| Dimensions (LxHxP) | 70 x 70 x 160mm |
| Weight | 500g |
| Included power supply | Yes |
| Package | 1x SMSL M300 MKII 1x Power supply 1x Remote control 1x Antenna 1x Optical cable 1x Jack 3.5mm to RCA cable 1x Micro USB to USB-A cable |
| Input | Optical |
| Input | S/PDIF |
| Output | RCA |
| Output | XLR |
| DAC / ADC Chip | AK4497EQ |
| Color | Red |
| Networking | No |
| Remote Control | Yes |
