SMSL SU-1 DAC AK4493S XMOS XU316 32bit 768kHz DSD512 MQA MQA-CD
Compact and powerful, the SMSL SU-1 DAC represents an affordable and efficient digital to analog conversion solution. Taking advantage of a careful design, it offers a great versatility while allowing a sound restitution of great quality.
4.9 / 5
Reference : 17619
79,90 €tax incl.
66,58 € tax excl.
Shipping date: 16-12-2025.
SMSL SU-1
AKM AK4493S DAC
The SMSL SU-1 is based on the use of the AKM AK4493S 32bit DAC chip, using the proprietary VelvetSound™ technology. This one allows a quality digital / analog conversion with a low level of distortion and a wide dynamic range. The result is a sound reproduction that is as rich as it is accurate for a beautiful listening experience.
XMOS XU316 USB Interface
The SU-1's USB-C input is combined with a powerful XMOS XU316 interface, efficiently processing the received audio signal. In combination with the AK4493S DAC, it allows the SMSL SU-1 to support high resolution audio streams up to PCM 32bit 768kHz and DSD512.
MQA Decoder
The SU-1 also features an MQA (Master Quality Authenticated) decoder. This format offers a very high sound quality, as close as possible to the studio recording, each file being authenticated by the artist, the producer or the copyright holder. SMSL's DAC also supports MQA-CD.
1MQA indicator
2USB indicator
3Optical indicator
4Coaxial indicator
5Stereo RCA output
6Coaxial input
7Optical Toslink input
8USB input
SMSL SU-1 review by Audio Science Review (Amir)
" SMSL cuts the functionality to minimum many need to have high quality conversion of digital to analog from multiple inputs. Performance is superb for the cost as it provides full transparency to the source. I am happy to recommend the SMSL SU-1. "
Test du SMSL SU-1 par Audio Science Review (Amir)
Product typeDAC
DAC chipAK44933S
Inputs1* USB-C
1* Optical Toslink
1* Coaxial
Outputs1* Stereo RCA
Output level2Vrms
THD+N0.00013% (-117dB)
Dynamic range121dB
SNR121dB
USB TransmissionAsynchronous
USB CompatibilityWindows 7/8/8.1/10/11
Mac OSX 10.6 or later
Linux
Supported sampling ratesUSB : PCM up to 32bit 768kHz, Native DSD up to DSD512, MQA 384kHz
Optical / Coaxial : PCM up to 24bit 192kHz, MQA 384kHz
Consumption< 5W
Standby consumption< 0.1W
Dimensions (L*P*H)96*78*27mm
Weight195g
Package1x SU-1
1x USB-A to USB-C cable 1m
DAC / ADC ChipAK4493S
Max sampling rate768kHz
Max sampling rateDSD512
Max sampling rateMQA
29 reviews
Ne vous privez pas
Le rapport qualité prix de ce dac est incroyable. Il me plaît beaucoup. Pour le prix pas moyen d'être déçu.
This review has been posted for SMSL SU-1 DAC AK4493S XMOS XU316 32bit 768kHz DSD512 MQA MQA-CD
Correct
Fait son job mais pas de quoi se relever la nuit, non plus. Le grave manque de modulation et les voix sont très larges. Pas très crédible. Mais c’est ok comme petit Dac de dépannage.
Dac SU-1
Quand même ça marche bien, sous Linux, rien à installer en bit perfect .
Après quelques mois, à l'écoute les basses sont charpentées avec un medium exaltant et un aiguë très naturel.
- Essai avec hiface 1 (que je n'arrive pas à me séparer) sous XP et oui... en kernel streaming, écoute engageante.
Mais une préférence pour l'usb ...
Fabuleux !
J'utilisais un tda1541 dans mon lecteur de CD et un ess 9018 dans mon Audiolab 6000a.
Et bien ce petit dac les enterre tous les deux !
Le son est plus détaillé que le tda1541 et beaucoup plus vivant que le ess 9018 !
La différence est époustouflante surtout avec le ess9018.
Basses profondes, bas medium charnu, medium clair mais ayant du corps, aigu filé et aéré.
Écouter la musique à bas volume ne change pas la qualité du son ni sa réponse en fréquence.
DAC MERITANT TOUTE VOTRE ATTENTION . . .
Derrière ce petit DAC de quat’sous qui ne paye pas de mine se cache un vrai potentiel musical. Je possède 5 DACs différents (Fostex HPA8, Rod RainD1, Akliam D1, Aiyima A05 pro, SMSL SU-1). Et ce dernier tient la dragée haute aux précédents. Question qualité de fabrication on ne peut bien sûr pas comparer le coûteux Fostex HPA8 avec le petit SMSL mais franchement côté musical le petit SU-1 tient la comparaison. Mon premier conseil sera d’utiliser l’entrée USB C exclusivement pour l’alimentation 5V cc et d’injecter vos fichiers musicaux sur l’entrée COAX, de loin la meilleure. Pour ma part j’utilise de SU-1 connecté sur un lecteur CD car je reste et resterai fidèle à cet excellent format (Wave codé sur 16 bits) qui est un format authentiquement haute définition capable de retranscrire les timbres instrumentaux et vocaux dans leurs plus fins détails ; le streaming dit HD (96, 192, 384 kHz) étant à mon avis un non-sens n’apportant pas de plus-value musicale, ces formats devant plutôt leur existence à des considérations commerciales. Mais revenons au SMSL SU-1 ; par rapport aux DACS à puce(s) ESS 9038 que je possède, le SU-1 est plus doux dans le haut du spectre, excluant toute fatigue auditive, et cette douceur n’est pas le résultat d’un manque de résolution, les contours instrumentaux restant d’une très grande netteté. C’est par l’équilibre spectral que le SU-1 étonne le plus: je ne ressens aucun registre prenant le dessus sur un autre, le grave est consistant, sans traînage, le médium expressif et bien timbré et l’aigu ne vrille pas les tympans. La dynamique est bien contrôlée, sans exagération artificielle mais sans nonchalance non plus, tout est expressif et musical. Les atmosphères des lieux d’enregistrement sont admirablement reproduites et l’image stéréo bien développée en largeur et aussi en profondeur à condition bien sûr qu’aucun des maillons de votre chaîne ne la limite (soignez vos câbles !). Ce SMSL Su-1 est vraiment étonnant et révèle les progrès constants en matière de conversion numérique/analogique et la compétition que se livrent les deux fondeurs en vogue (Sabre et Asahi Kasei). Mes seuls doutes iront à la fiabilité, car d’expérience, ces petits systèmes chinois peu coûteux ont la fâcheuse tendance à ne pas dépasser leur deuxième anniversaire ( ?).
Mon système : Ampli (classe D) Aiyima A70, câble num coax Canare, câbles de modulation Sommercable Stratos, câbles enceintes Sommercable Magellan, enceintes : Q acoustics 3030i et Davis Olympia One.
Compact and powerful, the SMSL SU-1 DAC represents an affordable and efficient digital to analog conversion solution. Taking advantage of a careful...
