The SMSL SU2 is a compact DAC built around audiophile-grade components. The digital-to-analog conversion is handled by an ESS ES9039Q2M DAC chip, allowing it to support streams up to PCM 24bit 192kHz and DSD DoP64 while delivering excellent technical performance, including a 130dB dynamic range and THD+N as low as 0.00006%. A set of four OPA1612 op-amps enables the SU2 to deliver an output level of 4.7Vrms via balanced XLR and 2.3Vrms via its RCA output. In terms of inputs, it offers a full range of optical connectivity including Toslink optical, coaxial, and AES/EBU, ensuring perfect compatibility with many sources such as a CD player or digital transport.
SMSL SU2
SMSL SU1
DAC Chip
ESS ES9039Q2M
AKM AK4493S
USB Interface
XMOS XU-316
Inputs
Toslink Optical, Coaxial SPDIF, AES/EBU
USB, Toslink Optical, Coaxial SPDIF
Outputs
RCA, XLR
RCA
MQA
Not supported
Supported
MQA-CD
Not supported
Supported
DSD
DSD DoP64
Supported
Op-Amps
4x OPA1612
1x OPA1612
Jitter Elimination Technology
CK-03 Clock Module
CK-03 Clock Module
Power Supply
AC
USB-C
On the front panel of the SMSL SU2 DAC, there is an intelligent LED indicator system that displays real-time operating information such as selected input type, sampling rate, left and right channels, and more.
| 1 | Power / Source selector |
| 2 | LED indicator |
| 3 | Balanced XLR output |
| 4 | Single-ended RCA output |
| 5 | Coaxial input |
| 6 | Toslink optical input |
| 7 | AES/EBU input |
| 8 | AC power input |
Technical Specifications
| Specifications | |
| Product Type | DAC |
| DAC Chip | ESS ES9039Q2M |
| Op-Amps | 4x OPA1612A |
| Inputs | 1x Coaxial 1x Toslink optical 1x AES/EBU |
| Outputs | 1x Balanced XLR 1x Single-ended RCA |
| Output Level | XLR: 4.7Vrms RCA: 2.3Vrms |
| THD+N | XLR: 0.00006% (-123.5dB) RCA: 0.00008% (-121.5dB) |
| Dynamic Range | XLR: 130dB RCA: 126dB |
| SNR | XLR: 130dB RCA: 126dB |
| Supported Sampling Rates | PCM 24bit 192kHz DSD DoP64 |
| General | |
| Power Supply | 100-240V AC |
| Power Consumption | < 2.3W |
| Standby Power Consumption | < 0.1W |
| Dimensions | 150 x 42.5 x 133.1mm (W x H x D) |
| Weight | 532.6g |
| Package Contents | 1x SMSL SU2 1x AC power cable |
| Input | AES/EBU |
| Input | Optical |
| Input | SPDIF |
| Output | XLR |
| Output | RCA |
| DAC / ADC Chip | ES9039Q2M |
| Max sampling rate | 192kHz |
| Color | Black |
| Networking | No |
| Remote Control | No |
