HIDIZS AP200 Digital Audio Player DAC HiFi 2x ES9118C 32bit / 384kHz DSD128 32Go Black
By buying this product you get 31 loyalty points
Reference : 12276
319,00 €tax incl.
265,83 € tax excl.
This is the Black version of the Hidizs AP200.
Hidizs AP200
DAP DAC 2x ES9118C 32bit/384kHz DSD128 32Go Noir
Hidizs AP200
With its AP200, Hidizs offers a Hi-Res-certified Hi-Res HAP with outstanding performance under Android for an unparalleled music experience.
Double ESS ES9118 DAC
The AP200 is the first high resolution DAP using two ES9118C ESS DACs, one for each channel. Thus, this perfect separation of the channels allows the sound to gain considerably in amplitude. The reproduction of voices and instruments is much more precise, allowing the Hidizs player to retransmit accurately and effortlessly all types of music, from pop to classical music. These DACs will allow you to enjoy your music in high resolution because they support PCM 32bits 384kHz and DSD128 files and allow you to achieve a 126dB SNR (Signal Noise Signal Ratio) and a -113dB THD (Total Harmonic Distortion).
hidizs ap200
DACs and a 24k gold shielded 3.5 Jack
If the integration of a double DAC is already a real step forward, the AP200 goes even further since they are armoured with a 24k gold plating. This allows converters to eliminate interference that could interfere with your listening experience by producing noise. Likewise, the 3.5mm output jack connector is gold-plated to increase conductivity and provide better oxidation resistance, all the more important for a mobile device.
hidizs ap200
A magnificent screen
Hidizs has also chosen to offer a more enjoyable user experience by including a superb 3.5" 960x640px 325ppi touch screen. This is an IPS slab, which allows bright and vivid colours to be obtained while offering very wide viewing angles to increase legibility. A screen that fits into a case of 5.8 x 1.8 x 10.6cm, designed to fit perfectly in your hand.
Double Quartz Oscillators
The AP200 uses two separate Quartz oscillators. The first one deals with 44.1kHz / 88.2kHz / 176.4kHz / 352.8kHz / DSD sampling rates and the second one with 48kHz / 96kHz / 192kHz / 384kHz sampling rates. The result is a significantly lowered jitter, improving clock accuracy, and more stable information processing, resulting in flawless, high-quality sound reproduction.
hidizs ap200
A fast DAP
While the AP200 incorporates high quality audio components, the processor, which processes the data, is no exception. This is a Rockchip RK3188 28 SoC Rockchip containing 4 Cortex-A9 cores allowing DAP to increase its processing speed by 35% compared to the previous model. A processor supported by 1GB of RAM and an Android OS 5.1.
hidizs ap200
Full compatibility
The DAP is also very versatile as it allows you to read the vast majority of current file formats: FLAC, APE, WMA, ALAC, Apple Lossless, DSF, DSDIFF. It also includes native support for DSD64 and DSD128, and can play PCM files up to 32bits 384kHz.
hidizs ap200
A total connectivity
The Hidizs AP200 takes audio playback to the next level with advanced and complete connectivity. Thus, it supports Bluetooth 4.0 aptX Lossless as a receiver and transmitter. So you can enjoy your high-quality files from any source (Smartphone, PC...) and on any listening device (Headphones, headphones, Car Audio system...), always enjoying the two DAC ESS ES9118 of the AP200 and their musicality.
Note that to enjoy Lossless aptX transmission, your Bluetooth listening device must also support aptX protocol.
For Wifi, the AP200 uses an IEEE 802.11 b/g/n 2.4GHz Wifi module. So you can enjoy your favorite online audio streaming services or install third-party music applications like Qobuz, Spotify, Deezer or Tidal and more.
hidizs ap200
DAC and Digital interface
Just as the Bluetooth of the AP200 works as a receiver and transmitter, its USB works in both directions. Thus, DAP can be used as DAC when connected to a computer or smartphone (support Windows, Mac and Android smartphone with OTG). The AP200 can also act as a digital interface when connected to an external DAC, such as the Chord Mojo or the IFI Micro iDSD. In this case, the 3.5mm jack can be used to connect headphones or headphones, but also as a line output to an external amplifier and amplified speakers.
hidizs ap200
Android and Hiby: two modes of operation
The AP200 offers two modes of operation to suit your preferences. You can either run with the Android OS in a classic way and enjoy all the apps and related features, or switch to Pure Music Mode and have an intuitive player only dedicated to playback of audio files, for smoother use and purer sound.
hidizs ap200
More than 10 hours of listening time
The DAP AP200 incorporates a 3100mAh lithium battery coupled with a Japanese protection system. This will allow you to listen to your music for more than 10 hours without interruption.
Type-C USB and SD Card
The AP200 uses a Type-C USB connector, the latest USB standard to date. This allows for increased transfer speed, faster charging but also a gain in ergonomics since the connector will connect in both directions. In addition, to allow you to expand the original 32GB memory of your DAP and thus be able to store more music, you can add a Micro SD memory card up to 256GB (not included).
hidizs ap200
A case designed to follow you everywhere
Hidizs has taken particular care with the case of its AP200 by offering a CNC machined aluminium structure thanks to an ultra-precise machine, in a single piece of metal. It is thus no less than 120 minutes that will allow this case to take shape. A structure that wants to be both robust and design, to accompany you in all your movements, but also ergonomic, with a placement of buttons designed to be as intuitive and simple as possible.
Comparative tests
To better understand the performance of the AP200 compared to a smartphone, a comparative test was carried out. On one side, the AP200 on the other, an iPhone 6. To perform the tests, professional Audio Precision APX512 Audio Precision equipment was used.
Frequency response & channel separation
The AP200 achieves the 40kHz Hi-Res standard where the iPhone 6 is limited to 20kHz. The first one will allow a more detailed reproduction of your music. In addition, the very low crosstalk of the Hidizs DAP ensures a better sound image and a much clearer sound.
hidizs ap200
SNR & THD+N
The signal-to-noise ratio is defined as the ratio of signal power (containing important information) to background noise power. In our case, the AP200 has a higher SNR than the iPhone 6, which means that the DAP will be able to provide a purer sound reproduction. This data is all the more important since some supra-aural headsets require a certain SNR to operate at their maximum performance.
On the THD+N side (Total Harmonic Distortion + Noise), the AP200 represents almost half the THD+N of the iPhone 6. Thus, a weaker THD+N allows you to obtain a more accurate reproduction of your audio file.
hidizs ap200
Hardware
CPURockchip RK31884 x Cortex-A9 1.4Ghz
DACx2 ESS ES9118, one per channel
DSDHBC3000
DAC Shield24K Gold
AmplififierTPA6120A2
RAM1Go
Storage32Go
Storage extension typeMicro SD
Max. storage extension capacity256Go
Connectivity
Wifi2.4GHz IEEE 802.11 b/g/n
BluetoothBluetooth 4.0 aptX
USB InterfaceUSB Type-C, two-way USB DAC
Hiby AppLAN, Dropbox, DLNA Support
Design
UIAndroid 5.1
Hiby Music
DisplayTactile screen 3.54" 960x640px IPS
Case materialAluminium
Rear panelVerre trempé
ButtonsOn the sides for volume and playback control
JackGold plated 24K
USB Audio (DAC)
DSD Support64/128
PCM Support32bit 384kHz
Output
Headphone outputJack 3.5mm
Headphone with microphoneOui
Output power130W @ 32Ω
Frequency response20Hz - 40kHz
SNR115dB
Channel separation75dB (1kHz)
Output impedance4.8Ω (32Ω chargé)
Power supply / Charge
Charge connectorUSB Type-C
USB charge adapterDC 5V 2A recommanded
Battery3100mAh Li-Polymer
Charge time4h
AutonomyMore than 10h
Gain controlLow / High
DSD gain compensation0 / +1dB / +2dB / +3dB / +4dB / +5dB / +6dB optionnal
S/PDIF SupportYes
Equalizer8 profiles + customizable profile, up to 48kHz
System resetMaintain Power Button
Firmware upgradeVia Micro SD (Only FAT32 systems) or via internet
Data transferUSB 3.1 High speed
Dimensions106.5 x 60.5 x 15.7mm
Weight145g
Lossless audio formats supported
DSDDSD64/128 (.iso, .dsf, .dss)
DXD352.8kHz
APE FAST/High/Normal24bit 384kHz
APE Extra High24bit 192kHz
APE Insane24bit 48kHz
Apple Lossless24bit 384kHz
AIFF24bit 384kHz
FLAC24bit 384kHz
WAV32bit 384kHz
WMA Lossless24bit 96kHz
Audio formats xith losses supported
MP3-
AAC-
WMA-
OGGOGG
InputMicro SD
OutputJack 3.5mm
DAC / ADC ChipES9118C
Max sampling rate384kHz
Max sampling rateDSD128
