By buying this product you get 81 loyalty points
Here is the new DAP from Opus, the OPUS # 3! The newest solution for audiophiles that have high demands on the sound quality and audio performance of their playeref = "https://www.audiophonics.fr/fr/haute-fidelite-c-1325.html" target = "_ blank">HiFi. The OPUS 3 will allow you to enjoy your favorite music via streaming services and enjoy the benefits of 2.4GHz WiFi and Bluetooth 4.0.
OPUS # 3 has exceptional performance for playing native DSD files as well as Hi-Res files up to 24Bit / 192kHz. Its rare and sought-after PCM1792A (Burr-Brown) DAC provides a clear and brilliant sound in all circumstances.
This DAP has recovered all the advantages of the previous models and has been added all the necessary characteristics in order to be a modern portable audio player. It is designed to become the ultimate mobile HiFi solution, even for the most demanding Hi-Res enthusiasts. All this thanks to the expertise and professionalism of the OPUS engineers.
You pyou can also use it in PAC DAC, thanks to its PCM1792A conversion chip and its microUSB input with XMOS technology, and thus connect it directly to your amplifier via a cablee 3.5mm Jack - RCA Stereo .
Test, test of OPUS 3 by AUDIOPHILE HEAVEN
Main Features :
Audio Features:
Connectors:
Dimensions / Packaging:
Input | Micro SD |
Output | Optical Toslink |
Output | Jack 2.5mm |
Output | Jack 3.5mm |
DAC / ADC Chip | PCM1792A |
Max sampling rate | 192kHz |
Max sampling rate | DSD256 |
Color | Silver |
Color | Black |
