SHANLING M3 PLUS Digital Audio Player DAP Copper
New
With the M3 Plus, Shanling presents a high-definition digital audio player, the direct successor to the M3 Ultra, featuring an improved analogue/digital conversion stage, greater output power and an operating system updated to Android 13.
Reference : 20786
469,00 €tax incl.
390,83 € tax excl.
Shipping date: 22-07-2025.
Shanling M3 Plus Digital Audio Player DAP Bluetooth 5.0 WiFi 32bit 768kHz DSD512 Copper
Shanling M3 Plus : Vue de face
Shanling M3 Plus: Revamped aesthetics
The M3 Plus has a new look compared to its predecessor, with a gracefully curved CNC-machined aluminium chassis and a magnificent 4.7-inch screen, slightly larger than its predecessor but still small enough to fit comfortably in the palm of your hand.
Shanling M3 Plus : 3 colours available
Shanling M3 Plus : CS43198 chips
Shanling M3 Plus: Quad DAC CS43198
For its digital/analogue conversion stage, the M3 Plus takes a giant leap forward compared to its predecessor and lines up 4 Cirrus Logic CS43198 DAC chips working in parallel to deliver a result of rare cleanliness. As a result, the M3 Plus is capable of supporting a signal up to 32bit 768kHz PCM and native DSD512.
Shanling M3 Plus: 800mW amplification
The amplification stage of the M3 Plus is based on a combo of OPA1612 to reduce output distortion to a minimum and a dual SGM8262 chip, providing amplification of up to 800mW at 32Ω, more than enough power to drive the majority of headphones and earphones on the market.
Shanling M3 Plus : OPA1612 chips
Shanling M3 Plus : KDS Clocks
Shanling M3 Plus: FPGA signal processing
The digital signal processing part of the M3 Plus is no slouch either, using an FPGA coupled to KDS crystal oscillators to reduce jitter, delivering an exceptionally accurate signal to its DAC array.
Shanling M3 Plus: 3500mAh battery
To keep up with you wherever you go, the M3 Plus is equipped with a 3500mAh battery capable of providing 14 hours of uninterrupted wired listening, and up to 61 hours when connected via Bluetooth.
Shanling M3 Plus : Snapdragon 665 processor
Shanling M3 Plus: Snapdragon 665 processor
As well as offering excellent sound reproduction, the M3 Plus is also pleasant and fluid to use. It's powered by a Qualcomm Snapdragon 665 octa-core processor and 4GB of RAM, so you can be sure of smooth operation.
Shanling M3 Plus: Excellent connectivity
For maximum flexibility of use, the M3 Plus is equipped with two-way Bluetooth connectivity compatible with LDAC, aptX HD, LHDC and SBC codecs. What's more, it's also compatible with DLNA, Airplay and SyncLink network protocols, allowing you to access files on your local network and play a music library on a NAS, for example.
Shanling M3 Plus : DAP with speaker and headphones
Shanling M3 Plus: Android 13
Another notable difference with its predecessor is that the M3 Plus is running an operating system that has been updated to Android 13, ensuring stability and compatibility with the majority of applications for many years to come. In addition, as an open Android system, this new version still includes Shanling's AGLO (Android Global Lossless Output) data processing system.
Shanling M3 Plus: LED indicator
To check playback status at a glance, the M3 Plus is equipped with an LED around the volume control, the colour of which indicates the sampling rate in use, or the codec in the case of a Bluetooth connection.
  • Blue : 44.1-48kHz / ACC SBC
  • Yellow : 88.2-196kHz / LDAC
  • Purple : 352.4-768kHz
  • Green : DSD / aptX
  • Red : MQA
Shanling M3 Plus : Colored LED
Product typeDAP
Outputs1x Jack 3.5mm
1x Jack 4.4mm
Bluetooth
OSAndroid 13
ScreenSHARP 720x1280 4.7"
Supported sampling ratesPCM 32bit 768kHz
DSD512
Supported audio formatsDSD (".iso", ".dsf", ".dff") / ISO / DXD / APE / FLAC / WAV / AIFF / AIF / DTS / MP3 / WMA / AAC / OGG / ALAC / MP2 / M4A / AC3 / M3U / M3U8 / OPUS
Storage64Gb ROM
MicroSD slot up to 2TB
DAC chips4x Cirrus Logic CS43198
Amplification chips2x SGM8262
Bluetooth version5.0
Supported codecsEmission: LDAC / aptX HD / aptX / AAC / SBC
Reception: LDAC / SBC
3.5mm jack output
Output powerLow gain : 12.5mW @32Ω
Medium gain : 50mW @32Ω
High gain : 200mW @32Ω
Frequency response20Hz - 40kHz (±0.2dB)
Total harmonic distortion more noise (THD+N)0.0007%
Channel separation75dB @32Ω
Dynamic range127dB
Signal-to-noise ratio (SNR)127dB
Noise<1.1μV
Output impedance>1Ω
Output level lineout mode2.58Vrms
4.4mm jack output
Output powerLow gain : 50mW @32Ω
Medium gain : 200mW @32Ω
High gain : 800mW @32Ω
Channel separation110dB @32Ω
Dynamic range130dB
Signal-to-noise ratio (SNR)130dB
Noise<1.6μV
Output impedance>1.5Ω
Output level lineout mode5.16Vrms
Dimensions115 x 70.5 x 18mm
Weight205g
ColorCopper
Package1x Shanling M3 Plus
1x USB-A to USB-C cable
InputNC
OutputJack 3.5mm
OutputBluetooth
OutputJack 4.4mm
DAC / ADC ChipCS43198
Max sampling rateDSD512
Max sampling rate768kHz
ColorCopper
SHANLING M3 PLUS Digital Audio Player DAP Bluetooth 5.0 WiFi 32bit 768kHz DSD512 Copper
With the M3 Plus, Shanling presents a high-definition digital audio player, the direct successor to the M3 Ultra, featuring an improved...
