SHANLING ONIX WALTZ XM10 LTD DAP
The Shanling Onix Waltz XM10 LTD is a high-performance DAP, first introduced by the brand in its Onix Miracle package. However, this version benefits from numerous improvements, such as an AKM AK4191+AK4499EX chip combo and an AD8397 headphone amplifier chip for exceptional audio performance. Indeed, this DAP is capable of handling sampling rates up to PCM 32bit 768kHz and DSD1024, while achieving output power of up to 877mw under 32 ohm.
By buying this product you get 89 loyalty points
Reference : 20442
899,00 €tax incl.
749,17 € tax excl.
Shipping date: 01-07-2025.
Shanling Onix Waltz XM10 LTD DAP AK4191+AK4499EX WiFi Bluetooth 5.0 aptX HD LDAC 32bit 768kHz DSD1024
SHANLING ONIX Waltz XM10 LTD picture
The whole thing is based on an Android 13 interface, powered by a Qualcomm Snapdragon 665 processor. Like a smartphone, it boasts a 6-inch color touchscreen, with Full HD 2160x1080px resolution. A host of features complete the package, including two-way Bluetooth 5.0, WiFi 2.4G/5G connectivity, and compatibility with DLNA and AirPlay protocols.
On the connectivity side, there's a USB-C DAC/charge input, a microSD port, and a 3.5mm jack output, which can be used as a balanced 4.4mm jack thanks to a special adapter supplied. Power is provided by a 4300mAh battery, offering up to 9 hours of autonomy, making the Shanling Onix Waltz XM10 LTD an ideal companion for everyday use or travel.
SHANLING ONIX Waltz XM10 LTD benefits
Shanling Onix Waltz XM10 LTD: Exceptional audio performance
The Onix Waltz XM10 LTD DAP features high-quality audiophile components, an XMOS XU316 USB interface, an AKM AK4191+AK4499EX chip combo and an AD8397 headphone amplifier, all implemented in the brand's proprietary “Brighton” architecture, taken from the Onix Miracle.
This combination of components enables the DAP to deliver exceptional performance. In fact, it supports sampling rates up to PCM 32bit 768kHz and DSD1024 (DAC USB PCM 32Bit 384kHz and DSD256), while offering the output power to drive a large number of headphones on the market:
3.5mm jack output
  • 19mW @ 32 ohm (Low gain, 1.3V @ 32 ohm, THD+N <0.002%)
  • 227mW @ 32 ohm (High gain, 2.7V @ 32 ohm, THD+N <1%)
  • 24mW @ 32 ohm (High gain, 2.7V @ 300 ohm, THD+N <1%)
4.4mm jack output (with adapter)
  • 227mW @ 32 ohm (Low gain, 1.3V @ 32 ohm, THD+N <0.1%)
  • 877mW @ 32 ohm (High gain, 5.3V @ 32 ohm, THD+N <1%)
  • 93mW @ 300 ohm (High gain, 5.3V @ 300 ohm, THD+N <1%)
Shanling Onix Waltz XM10 LTD: Android 13
Thanks to its Snapdragon 665 processor, the Shanling Onix Waltz XM10 LTD runs Android 13, offering a fluid, intuitive user experience. Its 6-inch touchscreen and format are reminiscent of smartphone ergonomics. It comes with 6GB of RAM, 128GB of internal storage, and a microSD slot to expand storage capacity.
Android 13 interface for SHANLING ONIX Waltz XM10 LTD
SHANLING ONIX Waltz XM10 LTD connectivity
Shanling Onix Waltz XM10 LTD: Extensive connectivity
This DAP offers full connectivity, with support for WiFi 2.4G/5G, as well as AirPlay 2, DLNA and SyncLink protocols. Its bidirectional Bluetooth 5.0 supports several codecs:
  • Reception: SBC, LDAC
  • Transmission: SBC, AAC, aptX, aptX HD, LDAC
These options allow great flexibility in terms of broadcasting and receiving audio streams.
Shanling Onix Waltz XM10 LTD: An everyday ally
The Shanling Onix Waltz XM10 LTD is equipped with a 4300mAh battery, offering up to 9 hours of autonomy for full enjoyment of high-resolution audio files. It recharges via a USB-C port, compatible with QC and PD charging protocols for fast, efficient recharging.
SHANLING ONIX Waltz XM10 LTD battery
Shanling Onix Waltz XM10 LTD overview
SHANLING ONIX Waltz XM10 LTD overview
1Touch screen
2Micro SD slot
3USB-C DAC / Charge port
4Output jack 3.5mm / 4.4mm with adapter
5Volume -
6Volume +
7Power button
Product typeDAP
DAC chipCombo AKM AK4191+AK4499EX
Amplification chipAD8397
CPUQualcomm Snapdragon 665
OSAndroid 13
Memory6GB RAM +128GB ROM
Inputs1x USB DAC
1x Micro SD slot (up to 2TB)
Outputs1x Jack 3.5mm
1x Jack 4.4mm avec adaptateur (via le jack 3.5mm)
Supported sample ratesPCM 32bit 768kHz, DSD1024
DAC USB : PCM 32bit 384kHz, DSD256
Bluetooth 5.0Bidirectionnal
Supported bluetooth codecsReception : SBC, LDAC
Transmission : SBC, AAC, aptX, AptX HD, LDAC
SUpported audio formatDSD (iso, dsf, dff), ISO, DXD, APE, FLAC, WAV, AIFF, AIF, DTS, MP3, WMA, AAC, OGG, ALAC, MP2, M4A, AC3, M3U, M3U8, OPUS
Display6" touch screen (2160x1080px)
3.5mm jack output specifications
Output power19mW @ 32 ohm (Low gain, 1.3V @ 32 ohm, THD+N <0.002%)
Frequency response20Hz-40kHz (-0.5dB)
THD+N0.0009% @ 32 ohm (A-WT @ 0.25V, high gain)
Dynamic range122dB @ 32 ohm
Channel separation72dB @ 32 ohm
SNR122dB @ 32 ohm (A-WT, High gain)
Noise113dB
Output impedance0.6 ohm
4.4mm jack output specifications (with adapter)
Output power227mW @ 32 ohm (Low gain, 1.3V @ 32 ohm, THD+N <0.1%)
THD+N0.0007% @ 32 ohm (A-WT @ 0.5V, high gain)
Dynamic range124dB @ 32 ohm
CGannel separation100dB @ 32 ohm
SNR124dB @ 32 ohm (A-WT, High gain)
Noise110dB
Output impedance1.0 ohm
Power supplyVia USB-C port
BatteryLithium 4300mAh
Autonomy9h
Dimensions157.7 x 76.8 x 11.5mm
Weight338g
Package1x Shanling Onix Waltz XM10 LTD DAP
1x Adapter jack 3.5mm male to jack 4.4mm female balanced
InputMicro SD
InputWiFi
OutputJack 3.5mm
OutputBluetooth
OutputJack 4.4mm
DAC / ADC ChipAK4191
DAC / ADC ChipAK4499EX
Max sampling rate768kHz
Max sampling rateDSD1024
SHANLING ONIX WALTZ XM10 LTD DAP AK4191+AK4499EX WiFi Bluetooth 5.0 aptX HD LDAC 32bit 768kHz DSD1024
The Shanling Onix Waltz XM10 LTD is a high-performance DAP, first introduced by the brand in its Onix Miracle package. However, this version...
