TINYSINE DC-DC Converter 8-52V to 5V Micro USB / USB-A
This particularly practical DC-DC converter accepts a wide voltage range from 8V Dc to 52V DC at the input. This current is then converted to 5V DC and the converter has both a Micro USB connector and a USB-A to allow you to do your wiring.
Reference : 13854
10,90 €tax incl.
9,08 € tax excl.
Shipping date: 01-07-2025.
Tinysine DC-DC Converter
8V-52V DC to 5V DC USB-A / Micro USB
Tinysine Convertisseur DC-DC 8V-52V vers 5V USB-A / Micro USB
This particularly practical DC-DC converter accepts a wide voltage range from 8V Dc to 52V DC at the input. This current is then converted to 5V DC and the converter has both a Micro USB connector and a USB-A to allow you to do your wiring. The components are placed in a waterproof plastic case.
Product typeDC-DC Converter
Input voltage8V-52V DC
Output voltage5V DC
Max output current3A
Efficiency90%
Output connectors1x Micro USB
1x USB-A
Dimensions46 x 32 x 18mm
Weight70g
Output voltage (V)5.0
Input voltage (V)17.0
Input voltage (V)34.0
Input voltage (V)48.0
Input voltage (V)10.0
Input voltage (V)26.0
Input voltage (V)41.0
Input voltage (V)19.0
Input voltage (V)33.0
Input voltage (V)50.0
Input voltage (V)12.0
Input voltage (V)28.0
Input voltage (V)43.0
Input voltage (V)52.0
Input voltage (V)21.0
Input voltage (V)36.0
Input voltage (V)14.0
Input voltage (V)30.0
Input voltage (V)45.0
Input voltage (V)23.0
Input voltage (V)38.0
Input voltage (V)16.0
Input voltage (V)32.0
Input voltage (V)47.0
Input voltage (V)9.0
Input voltage (V)25.0
Input voltage (V)40.0
Input voltage (V)18.0
Input voltage (V)49.0
Input voltage (V)11.0
Input voltage (V)27.0
Input voltage (V)42.0
Input voltage (V)51.0
Input voltage (V)20.0
Input voltage (V)13.0
Input voltage (V)29.0
Input voltage (V)44.0
Input voltage (V)22.0
Input voltage (V)37.0
Input voltage (V)15.0
Input voltage (V)31.0
Input voltage (V)46.0
Input voltage (V)8.0
Input voltage (V)24.0
Input voltage (V)39.0
This particularly practical DC-DC converter accepts a wide voltage range from 8V Dc to 52V DC at the input. This current is then converted to 5V DC...
