BURSON AUDIO PLAYMATE 2 Class A 3W Headphone Amplifier / DAC ES9038Q2M / Preamplifier DSD512 32bit 768kHz
With the Playmate 2, Burson Audio is unveiling an improved version of its versatile Playmate 1 Hi-Fi system. The Playmate 2 incorporates an ES9038 Dac chip and an XMOS USB interface input, as well as a Class A headphone amplifier function and a stereo preamplifier function.
By buying this product you get 65 loyalty points
Reference : 17917
659,00 €tax incl.
549,17 € tax excl.
With the Playmate 2, Burson Audio unveils an improved version of its versatile Playmate 1 Hi-Fi device, featuring an ESS ES9038 DAC chip, USB input with XMOS interface, Class A headphone amplifier function and stereo preamplifier. Its amplification stage is made up of DIP8-mounted NE5532 OPAs. The playmate 2 is capable of decoding up to PCM 32bit 768kHz and DSD up to DSD512. It can also accompany a wide range of headphones, thanks to its 3W output power. What's more, its new CNC-machined aluminum chassis acts as an integral heatsink to dissipate heat efficiently.
A high-performance ES9038Q2M DAC and a USB XMOS input
The highlight of the Playmate 2 is its high-performance ESS ES9038Q2M DAC. This ESS-designed chip performs extremely high-quality digital-to-analog conversion. Based on ESS HyperStream technology, it ensures excellent dynamic range, very low distortion and, of course, rich, accurate sound reproduction. The Playmate 2 can therefore handle files up to PCM 32bit 768kHz and DSD up to DSD512.
Coupled with a USB-C input and a USB XMOS interface, the Playmate 2 lets you enjoy your digital audio sources such as a computer or your smartphone.
BURSON AUDIO PLAYMATE 2 Amplificateur Casque Class A 3W / DAC ES9038Q2M / Préamplificateur 32bit 768kHz DSD512
A quality amplification stage
Burson Audio's Playmate 2 incorporates four NE5532 dual AOPs, featuring very low noise and distortion, as well as high slew rate. Mounted on DIP8 brackets, they are easily replaceable if you wish to integrate Burson Audio's own V6 VIVID or V6 CLASSIC AOPs (sold separately), for example.
Class A 3W SE headphone amplifier
The Playmate 2's two front-panel headphone outputs (Jack 6.35mm and Jack 3.5mm), combined with high power output, enable the device to be used with a wide range of headphones. It's equally at home with low-impedance headphones or more demanding high-impedance models.
The Jack 3.5mm output is compatible with microphones, a considerable advantage especially for those wishing to use the Playmate 2 for PC gaming. An optical Toslink input on the rear of the case also makes it easy to connect a console, for example.
Playmate 2 can be used as a preamplifier
With its stereo RCA pre-out, the Playmate 2 transforms itself into a preamplifier, so it can accompany active loudspeakers incorporating their own amplification system, or allow you to benefit from an external amplifier.
Burson Audio's own "MCPS" power supply technology
The Playmate 2 circuit is powered by the Burson Audio Max Current Power Supply (MCPS), which corrects the problems of conventional power supplies. The MCPS uses transistors rather than transformers to greatly reduce circuit resistance. As a result, the Playmate can draw instantaneous current at any time to power the circuit as required. The result is a real gain in detail and dynamics. What's more, the MCPS power supply, rather than using numerous capacitors, increases the operating frequency from 50-60Hz to 170kHz, a frequency inaudible to the human ear, to considerably limit noise.
A new aluminium case
Burson Audio's Playmate 2 case, with its sober design, is easy to integrate into your Hi-Fi system. Its design makes it the perfect ally for placement on a desk, for example. What's more, its casing acts as an integral radiator, enabling it to dissipate heat very efficiently. In addition, the front panel features a screen showing volume level, selected input and sampling rate of the file being played.
Product typeDAC
Headphone amplifier
Preamplifier
Amplification typeClass A
Amplifier output power3W
Input impedance38kΩ
Frequency response0Hz - 35Khz ±1dB
THD< 0.002%
Output impedance (headphone amplifier)< 2Ω
Output impedance (pre-out)15Ω
Inputs1* USB-C (XMOS)
1* Optical Toslink
1* Jack 3.5mm (headphones & microphone)
Outputs1* RCA pre-out
1* Jack 6.35mm
OPANE5532
DAC
DAC chipESS ES9038Q2M
Channel separation128dB @ 1KHz, 121dB @ 20KHz
THD+N0.0018% @ 1kHz, 0dBFS
USB interfaceXMOS
USB compatibilityWindows XP / 7 / 8 / 10
Mac OS X
iOS
Android (OTG support)
Supported sample ratesPCM up to 32bit 768kHz
Native DSD up to DSD256
DoP up to DoP256
Headphone amplifier
Impedance (Jack 6.35mm headphone output)PowerSNRSeparation
16Ω3.5W96dB99%
32Ω2.5W97dB99%
100Ω600mW98dB99%
150Ω400mW96dB99%
300Ω150mW95dB99.5%
Power supply24V DC 3A
Body materialAluminum
ColorSilver
Dimensions190*150*60mm
WeightApprox. 3kg
Package1* Burson Audio Playmate 2
1* Power adapter 24V
InputJack 3.5mm
OutputJack 6.35mm
OutputJack 3.5mm
DAC / ADC ChipES9038Q2M
Max sampling rate768kHz
Max sampling rateDSD512
ColorSilver
ClassClass A / AB
With the Playmate 2, Burson Audio is unveiling an improved version of its versatile Playmate 1 Hi-Fi system. The Playmate 2...
