By buying this product you get 37 loyalty points
The FiiO CLASS A is a headphone amplifier and desktop preamplifier with a fully discrete Class A circuit. Its balanced architecture delivers up to 4,000 mW + 4,000 mW into 32 Ω , to drive a wide variety of headphones.
Designed to fit into a desktop Hi-Fi system, it combines several analog inputs, headphone and line outputs, and five adjustable gain levels. This versatility allows it to be matched to different headphones and sources, while ensuring its integration into a system including a power amplifier or active speakers.
The FiiO CLASS A is a desktop headphone amplifier and preamplifier designed around a fully discrete Class A amplification circuit. Each channel combines selected transistors, resistors and capacitors, with matched and manually adjusted components to maintain coherent reproduction. This architecture aims for a balance between smooth timbres, solid bass and natural vocals, for extended listening with an analog character.
The output stage uses Toshiba complementary pairs, Toshiba dual transistors and Sanken audio transistor pairs. This combination of components supports the manufacturer's reproduction goal: combining high resolution with a warm and fluid presentation, without sacrificing signal control.
To meet the current requirements of Class A amplification, the CLASS A integrates a 60 W toroidal transformer designed specifically for this device. Its silicon steel strip core aims to reduce magnetic losses, while its enameled copper wire winding promotes low internal resistance and high current capacity. External silicon steel shielding and copper foil shielding around the windings help limit magnetic and electromagnetic interference.
The separate power supply for the different amplification stages provides them with independently regulated voltage. After rectification, the 20,000 pF Nichicon filter capacitors smooth the current and store energy for fast dynamic variations; a resettable thermal switch also protects the transformer in case of overheating. This design aims to maintain a stable power supply during demanding passages, such as drum hits or orchestral tutti.
The fully balanced differential circuit is designed to reject interference and reduce distortion, while providing a power reserve suited to demanding headphones. On the balanced output, the amplifier delivers up to 4,000 mW + 4,000 mW into 32 Ω, allowing it to drive a wide variety of headphones.
Component selection extends to the audio stage, which notably includes eight WIMA film capacitors, twenty ELNA audio capacitors and twenty high-precision MELF resistors. A DC servo circuit continuously monitors and corrects the DC component at the output to maintain zero offset; it thus helps protect the headphones and preserve transparency as well as bass control.
Five gain levels, Low, Medium, High, Super High and Ultra High, allow the amplification to be matched to the sensitivity and impedance of the headphones. The CLASS A also integrates independent bass and treble controls, with a stated correction of up to +10 dB. These controls allow the tonal balance to be adjusted according to the headphones used or listening preferences.
Four inputs accept sources via unbalanced or balanced connection: 3.5 mm jack, RCA, 4.4 mm jack and XLR. For line output, the RCA and XLR connectors allow the CLASS A to be connected to a power amplifier or active speakers, while the 6.35 mm jack, 4.4 mm jack and 4-pin XLR headphone outputs cover the main connection formats.
The bidirectional 12 V trigger inputs and outputs allow coordinated power on or off of upstream and downstream devices. This function facilitates the integration of the amplifier into a desktop system or a more complete Hi-Fi system.
Several circuits monitor the operation of the device and react in case of anomaly. They notably cover DC output, power supply, headphone amplifier and transformer temperature, overvoltage and output overload. These protections help preserve both the amplifier and the connected headphones.
Technical specifications
| Specifications | |
| Product type | Headphone amplifier Preamplifier |
| Inputs | 1x Stereo RCA 1x Stereo XLR 1x 3.5mm Jack 1x 4.4mm Jack |
| Outputs | 1x RCA line output 1x XLR line output 1x 6.35mm Jack headphone output 1x 4.4mm Jack headphone output 1x 4-pin XLR headphone output |
| Input level | Unbalanced: 4.4Vrms Balanced: 11.4Vrms |
| Input impedance | Unbalanced: >5kΩ Balanced: >8kΩ |
| Trigger | |
| Unbalanced headphone output (Ultra High gain) | |
| Output power | ≥2000mW+2000mW @16Ω, THD+N<1%, 5.7Vrms ≥2850mW+2850mW 32Ω, THD+N<1%, 9.6Vrms ≥350mW+350mW @300Ω, THD+N<1%, 10.3Vrms |
| Total harmonic distortion more noise (THD+N) | 0.0006% @1kHz/-0.6dBV@32Ω |
| Signal-to-noise ratio (SNR) | ≥121dB (A-weighted) |
| Dynamic range | ≥121dB (A-weighted) |
| Frequency response | 20Hz-95kHz (±0.4dB) 20Hz-20kHz (±0.1dB) |
| Input sensitivity | 1.9Vrms @16Ω, THD+N<1% 3Vrms @32Ω, THD+N<1% 3.2Vrms @300Ω, THD+N<1% |
| Output impedance | <1Ω @32Ω |
| Crosstalk | ≥67dB @32Ω, 1kHz |
| Noise | <8µV (A-weighted) |
| Peak output voltage | 29.4Vp-p |
| Unbalanced line output | |
| Total harmonic distortion more noise (THD+N) | 0.00058% @1kHz/0dBV@10kΩ |
| Crosstalk | ≥110dB |
| Noise | <2.7µV (A-weighted) |
| Frequency response | 20Hz-95kHz (±3dB) 20Hz-20kHz (±0.1dB) |
| Signal-to-noise ratio (SNR) | ≥123dB (A-weighted) |
| Dynamic range | ≥123dB (A-weighted) |
| Output level | 3.8Vrms @10kΩ, 1kHz |
| Input sensitivity | 4.2Vrms @10kΩ, THD+N<1% |
| Balanced headphone output (Ultra High Gain) | |
| Output power | ≥2000mW+2000mW @16Ω, THD+N<1%, 5.7Vrms ≥4000mW+4000mW @32Ω, THD+N<1%, 11.4Vrms ≥1360mW+1360mW @300Ω, THD+N<1%, 20.2Vrms |
| Total harmonic distortion more noise (THD+N) | 0.0006% @1kHz/-3.2dBV@32Ω |
| Signal-to-noise ratio (SNR) | ≥119dB (A-weighted) |
| Dynamic range | ≥119dB (A-weighted) |
| Frequency response | 20Hz-95kHz (±1.4dB) 20Hz-20kHz (±0.1dB) |
| Input sensitivity | 1Vrms @16Ω, THD+N<1% 1.9Vrms @32Ω, THD+N<1% 3.1Vrms @300Ω, THD+N<1% |
| Output impedance | <1.5Ω @32Ω |
| Crosstalk | ≥114dB @1kHz@32Ω |
| Noise | <13uV (A-weighted) |
| Peak output voltage | 57.7Vp-p |
| Balanced line output | |
| Total harmonic distortion more noise (THD+N) | 0.00046% @1kHz/-2dBV@10kΩ |
| Crosstalk | ≥120dB |
| Noise | <3.7uV (A-weighted) |
| Signal-to-noise ratio (SNR) | ≥126dB (A-weighted) |
| Dynamic range | ≥126dB (A-weighted) |
| Output level | 7.6Vrms @1kHz@10kΩ |
| General | |
| Supply voltage | 100-120V AC / 220-240V AC ~ 50/60Hz |
| Dimensions | 213 x 239 x 67mm |
| Weight | 3.5kg |
| Color | Silver |
| Package | 1x FiiO CLASS A 1x Fuse 1x Power cable 1x RCA cable |
| Input | Jack 3.5mm |
| Input | Jack 4.4mm |
| Input | RCA |
| Input | XLR |
| Output | RCA |
| Output | Jack 6.35mm |
| Output | XLR |
| Output | Jack 4.4mm |
| Color | Silver |
| Class | Class A / AB |
| Remote Control | No |
