SMSL DO400 MK2 DAC Headphone Amplifier Preamplifier Black
New
The SMSL DO400 MK2 is a DAC featuring balanced headphone amplification and a preamplifier mode, designed to centralize digital-to-analog conversion and volume control in a Hi-Fi or desktop setup. Its ESS ES9039MSPRO chip and XMOS XU-316 USB interface support PCM streams up to 32 bits 768kHz and DSD512.
By buying this product you get 62 loyalty points
Reference : 22751
629,00 €tax incl.
524,17 € tax excl.
SMSL DO400 MK2 DAC Headphone Amplifier Preamplifier ES9039MSPRO 32bit 768kHz DSD512 Black
SMSL DO400 MK2: Front view
Intended for headphone listening as well as integration with an amplifier or active speakers, it combines extensive digital connectivity, Bluetooth 5.4 and several signal processing settings. This versatility allows it to take a central place in the system, handling conversion, headphone amplification or output level management.
SMSL DO400 MK2: ESS ES9039MSPRO DAC
The SMSL DO400 MK2 is based on an ESS ES9039MSPRO chip, configured for 8-channel parallel processing to reduce distortion. The third-generation XMOS XU-316 USB interface supports PCM streams up to 32 bits 768kHz and DSD512, while the USB, coaxial, optical and AES/EBU inputs also allow DSD transmission up to DSD64. Hardware MQA processing is supported via USB, optical, coaxial and AES, with decoding up to 8x, as well as MQA-CD playback.
SMSL DO400 MK2: DAC chip
SMSL DO400 MK2: OCXO clock
To stabilize data synchronization, the DO400 MK2 combines a 10MHz OCXO oscillator, rated at ±5ppb stability, with its CK-04 clock processing circuit. This circuit reclocks the inputs to limit jitter and phase noise, an approach intended to preserve playback regularity of high-resolution streams. DPLL digital processing, adjustable over 15 levels, allows jitter rejection to be tuned according to the source used.
SMSL DO400 MK2: Balanced headphone amplification
Its fully balanced PLFC circuit drives headphones of various impedances, with a rated power of 2x6W into 16Ω, 2x3W into 32Ω, 2x700mW into 300Ω and 2x350mW into 600Ω. This headroom allows the unit to be paired with planar or dynamic headphones, including high-impedance models. The headphone outputs include a 6.35mm jack, a 4.4mm balanced output and a 4-pin XLR socket.
SMSL DO400 MK2: DAC with headphone amplifier
SMSL DO400 MK2: Settings and listening modes
The DO400 MK2 offers 8 PCM filters and 4 DSD filters, as well as headphone gain adjustable over two levels. Nine sound coloration modes complete these options and allow the sound to be adapted to different headphones or listening preferences. Settings are made from the unit, whose display also allows selection of the I2S phase mode, brightness, function key and interface language: Chinese, English or Japanese.
SMSL DO400 MK2: Extensive connectivity
The USB, optical, coaxial, AES/EBU, I²S and Bluetooth inputs allow various digital sources to be connected. Bluetooth 5.4 supports the LDAC, aptX HD, aptX, AAC and SBC codecs; LDAC accepts streams up to 24 bits 96kHz. The RCA and XLR outputs are used to connect an amplifier or active speakers, while the preamplifier mode allows their level to be adjusted directly from the DO400 MK2, without a separate preamplifier. The unit thus combines the functions of DAC, headphone amplifier and preamplifier in a single system.
Technical specifications
Product typeDAC
Headphone amplifier
Preamplifier
Inputs1x USB-B
1x Coaxial
1x Optical Toslink
1x HDMI I2S
1x AES/EBU
Bluetooth 5.4
1x Balanced stereo XLR
1x Single-ended 6.35mm Jack headphone output
1x Balanced 4.4mm Jack headphone output
1x Balanced 4-pin XLR headphone output
DAC chipR2R
Supported sampling ratesPCM up to 32bit 768kHz
DSD up to DSD512
Output levelXLR: 5.2Vrms
RCA: 2.5Vrms
Output power2x 6000mW @ 16Ω
2x 3000mW @ 32Ω
2x 700mW @ 300Ω
2x 350mW @ 600Ω
THD+NXLR: 0.00005%
RCA: 0.00007%
HPA: 0.00009%
Dynamic rangeXLR: 133dB
RCA: 128dB
HPA: 126dB
SNRXLR: 133dB
RCA: 128dB
HPA: 126dB
Output impedanceLine output: 100Ω
HPA: →0Ω
GainBalanced: +20dB
Unbalanced: +14dB
Supported Bluetooth codecsWindows 7 / 8 / 8.1 / 10 / 11 (Driver required)
Mac OSX and later, Linux (Driverless)
USB compatibilitySBC, AAC, aptX, aptX HD, LDAC
Supply voltage100-240V AC
Dimensions245 x 186 x 42mm
Weight1.45kg
Package1x SMSL DO400 MK2
1x Remote control
1x Power cable
1x USB cable
InputAES/EBU
InputI2S via HDMI
OutputJack 4.4mm
OutputJack 6.35mm
ClassN/A
Remote ControlYes
The SMSL DO400 MK2 is a DAC featuring balanced headphone amplification and a preamplifier mode, designed to centralize digital-to-analog conversion...
