HIFIMAN EF499 Headphone Amplifier R2R DAC
Hifiman's EF499 is a DAC and amplifier for headphones. It offers warm sound from R2R digital/analogue conversion and an output level of 4.35W at 32Ω, enabling it to drive a wide range of headphones. Its extensive connectivity makes it a highly flexible device, capable of fitting into a wide range of configurations.
By buying this product you get 34 loyalty points
Reference : 19847
349,00 €tax incl.
290,83 € tax excl.
HIFIMAN EF499 : 3/4 view
HiFiMAN's EF499 is a DAC and headphone amplifier. It offers warm sound from R2R digital/analogue conversion and an output level of 4.35W at 32Ω, enabling it to drive a wide range of headphones. Its extensive connectivity makes it a highly flexible device, capable of fitting into a wide range of configurations.
HiFiMAN EF499: R2R conversion
For the EF499's digital/analogue conversion stage, HiFiMAN has chosen an R2R ladder resistor network. This 100% analogue conversion method produces a naturally warm sound, very close to the Hymalaya DAC, and as such, very close to the brand's characteristic sound. You can also choose whether or not to activate a NOS (Non-oversampling) mode.
HIFIMAN EF499 : R2R DAC
HIFIMAN EF499 : Device and headphones
HiFiMAN EF499: Headphone amplification
Moreover, in addition to R2R conversion, the EF499 offers amplification of 4.35W into 32Ω in balanced output and 1.28W into 32Ω in single-ended output. Furthermore, two gain settings are also available, enough to drive the vast majority of headphones on the market, including the most demanding high-impedance ones.
HiFiMAN EF499: Excellent connectivity
The EF499 from HiFiMAN offers a range of connections for great flexibility in use, thanks in particular to the digital inputs available. In addition to a coaxial input, the EF499 offers a USB-B and USB-C input as well as an RJ45 input, allowing you to connect a router, for example. On the output side, in addition to the 4-pin XLR and 6.35mm jack headphone outputs available on the front panel, a 3-pin stereo XLR and stereo RCA output are also available on the rear panel, allowing you to use it as a DAC and preamplifier in conjunction with a power amplifier.
HiFiMAN EF499: Ethernet RJ45 Port
The HiFiMAN EF499 features an RJ45 Ethernet network port. Thanks to this, you can connect the EF499 to a NAS connected to your network to enjoy your favorite audio files. Thanks to its wireless streaming function, you can also enjoy your music directly from your portable players. You can also enjoy your music from your favorite applications by connecting them to your router and then to the amplifier.
Type of productHeadphone amplifier
DAC
Inputs1x Coaxial
1x USB-B
1x USB-C
1x RJ45
Outputs1x Balanced XLR 4-pin headphone output
1x Single-ended 6.35mm jack headphone output
1x Balanced stereo XLR
1x Single-ended stereo RCA
DACR2R
THD+N0.008%
Channel separation95±3cB
Signal-to-noise ratio (SNR)99dB
Output powerBalanced output : 4.35W @ 32Ω
Single-ended output : 1.28W @ 32Ω
Power supply100V-120V AC 60Hz
210-230V AC 50Hz
Weight3.3kg
Package1x HIFIMAN EF499
1x Power cable
InputRJ45
OutputJack 6.35mm
DAC / ADC ChipR2R LADDER DAC
Max sampling rateNC
ClassN/A
Hifiman's EF499 is a DAC and amplifier for headphones. It offers warm sound from R2R digital/analogue conversion and an output level of 4.35W...
