LITTLE DOT MKIII Tubes Headphone Amplifier / Preamplifier
The Little Dot MKIII is a very nice tube headphone amplifier, offering excellent audio performance. It is topped by two GE5654 tubes (United States GE) for its input circuit and two 6H6 tubes (Russia) for its output circuit.
4.7 / 5
Reference : 3441
249,00 €tax incl.
207,50 € tax excl.
Shipping date: 02-06-2026.
Little Dot MKIII
Little Dot MKIII Amplificateur casque à tubes
The Little Dot MKIII is a very nice tube headphone amplifier / preamplifier, offering excellent audio performance. It is topped by two GE5654 tubes (United States GE) for its input circuit and two 6H6 tubes (Russia) for its output circuit. Its meticulous internal design allows it to provide comfortable power to accompany many headphones, while revealing a beautiful soft and round signature, without neglecting precision. The components are integrated in a robust aluminium housing.
Underneath the device are settings to change the gain and the type of tubes that can be used. The table below shows the different possible settings.
Note: Make sure that the unit is not powered when making a change to any of these settings.
Gain setting
By default, the amplifier is delivered with a gain set to 3. Two DIP switches are used to adjust the amplifier gain:
LITTLE DOT MKIII Amplificateur Casque / Préamplificateur à Tubes
The gain setting diagram available in the paper manual supplied with this product is incorrect. Please refer to the table above to make these adjustments.
Tubes type setting
Two jumper under the unit allow you to change the type of tubes that can be used with it. Two possibilities:
  • If the contacts are not connected (no jumper), the following and equivalent tubes can be used: WE301A/B, GE5654, M8100, CV4010, EF95, 6J1, etc.
  • If the contacts are connected (jumper in place), the following and equivalent tubes can be used : EF92, EF91, CV138, CV131, etc.
Note: By default the amplifier is set to the first option.
Product typeTubes headphone amplifier / Preamplifier / Volume control
TubesInput : 2x GE5654 (United States GE)
Output : 6H6 (Russia)
Input1x Stereo RCA
Output1x Stereo RCA SEPP (Single-Ended Push Pull) Class A
Distortion0.15% @ 300 Ohm 80mW
Output power350mW @ 600-300 Ohm
300mW @ 120mW
100mW @ 32 Ohm
Variable gain3x, 4x, 5x ou 10x
Input impedance (4 tubes used)Output impedance: 600 Ohm
Gain : 3-10x adjustable via DIP switch
Voltage : 10Vrms
Consumption30W
Case materialAluminium
Dimensions175 x 270 x 123mm
Weight3kg
ColorSilver panel, Black body
Package1x Little Dot MKIII
1x RCA Cable
1x Jack 3.5mm to 6.35mm adapter
1x Power cable
1x User Manual (EN)
OutputJack 6.35mm
ClassTube amp
13 reviews
Des tubes qui caressent les oreilles
Au regard du prix, j'ai été surpris par la qualité de l'appareil. La rapidité du son est excellente et tous les registres offrent un plaisir d'écoute naturel.
This review has been posted for LITTLE DOT MKIII Tubes Headphone Amplifier / Preamplifier
Tres bon ampli
Avec ses tubes d'origine, cet ampli casque est excellent. Il alimente sans soucis mon Hifiman Sundara de 36 Ohms, ou mon K702 AKG de 32 Ohms, pourtant l'un et l'autre gourmand en courant. La signature sonore est bien sur typée, mais bien équilibrée, avec des basses naturelles, articulées , d'une puissance suffisantes a mes oreilles, avec de l'impact et des mediums et aigus bien détourés, assez précis, et sans agressivité, mais avec de bonnes attaques, rapides et dynamiques. J'ai d'autres tubes a tester dessus (6N30Pi, et 6ZH1P-EV) en réserve, mais pour le moment, ceux d'origine me conviennent.
Très satisfait après une bonne expérience déjà avec un Little DOT MK2, retubé en NOS...dont les CV 131 commencent a lâcher.....
What else
Je l’utilise uniquement en tant que preampli hifi et c’est une pépite.
J’ai entendu des preamp bien plus cher ne pas sonner comme ce little dot.Avec des tubes rtc par exemple il s’envole.
Ce preamp est vraiment à considerer meme avant achat de beaucoups plus hdg et peut s’intercaler dans des installes à pas de prix avec de très bon bloc de puissance derriere.
Excellent!
I bought this pre amp after reading a lot of positive reviews on the internet. I use it only for headphones (AKG 500, Beyer Dynamic DT 770 Pro and Sennheiser HD600). The amp was delivered as expected en well packed. The look and finish is beautifull, construction very solid and the potmeter feels very good and even on all volume setting. The sound is very good paired with the HD600! A touch of tube warmth and detailled sound with good space. I've orderd som Vosnek tubes to try. I also try it with HD 605 wich I expect soon. The unit is stille burning in (3 days now) but very happy so far. For this price very very good! If you have a HD 600 or Beyer DT 770 pro it is a serious upgrade compared to a standard headphone connection. Highly recommended!
Recherche désespérément casque adapté
Il y a 3 ans j'ai posté un avis élogieux sur cet ampli casque.
A cette époque je l'utilisais avec un AKG K 702 et un Sennheiser HD 650.
Le problème est que le Little Dot MK3 a du mal à alimenter correctement ces deux casques. Sur certains morceaux le volume est souvent à 7 ou 8.
J'ai enfin trouvé le casque qui convient parfaitement à cet ampli casque. Il s'agit du Sennheiser HD 560S. Ce casque est fantastique. Son impédance est de 120 ohms et sa sensibilité est de 110 db.
Le son est neutre et très détaillé (voir analytique).
Les timbres sont superbes, la spatialisation est impressionnante.
C'est aussi un casque très dynamique.
Avec un réglage de gain à 5, le volume d'écoute est entre 3 et 5.
J'ai gardé l'AKG K702 et le HD 650, mais je n'écoute plus que le HD 560S.
The Little Dot MKIII is a very nice tube headphone amplifier, offering excellent audio performance. It is topped by two GE5654 tubes (United States...
