ROSESELSA RT-5000 DAC Headphone Amplifier Black
New
The RT-5000 from Roseselsa is a DAC and amplifier for headphones using a pair of SABRE ES9038Pro chips and JRC MUSES01 transistors for digital/analogue conversion up to PCM 32bit 384kHz and DSD256 and an output power of 1600mW at 32Ω. These top-of-the-range components ensure quality sound reproduction that's both warm and soft, all housed in a beautiful enclosure.
By buying this product you get 59 loyalty points
Reference : 20737
599,00 €tax incl.
499,17 € tax excl.
Shipping date: 10-06-2025.
Roseselsa RT-5000 DAC Headphone Amplifier ES9038Pro MUSES01 Bluetooth 5.1 32bit 384kHz DSD256 Black
Roseselsa RT-5000 : Front view
Roseselsa RT-5000 : ESS DAC chip
Roseselsa RT-5000: ES9038Pro DAC chips
The RT-5000 features two ES9038Pro DAC chips using HyperStream II technology to deliver exceptionally accurate, jitter-free conversion. Thanks to ESS's SABRE chips, the RT-5000 is capable of supporting a high-resolution stream of up to 32bit 384kHz PCM and DSD256 while boasting a signal-to-noise ratio (SNR) of 125dB and a harmonic distortion rate (THD) of -112dB.
Roseselsa RT-5000: 10 OPA1612
The RT-5000 also incorporates a total of 10 Texas Instrument OPA1612s. Eight of these are responsible for the I/V circuit and the remaining two act as LPF amplifiers, perfectly complementing the ESS DAC chips to produce HiFi sound reproduction with ultra-low distortion and impressive dynamics.
Roseselsa RT-5000 : OPA1612
Roseselsa RT-5000 : MUSES01 transistors
Roseselsa RT-5000: J-FET JRC MUSES01 transistors
The RT-5000's amplifier stage is based on a pair of J-FET JRC MUSES01 transistors capable of delivering 1600mW of power at 32Ω balanced and 800mW at 32Ω single-ended. This top-of-the-range pair of transistors delivers warm, smooth sound with powerful bass and a wide soundstage.
Roseselsa RT-5000: QCC5125 Bluetooth chip
To provide high-quality Bluetooth connectivity, the RT-5000 is equipped with Qualcomm's QCC5125 chip, which supports the high-definition LDAC, aptX Low Latency and aptX Adaptive protocols.
Roseselsa RT-5000 : Bluetooth chip
Roseselsa RT-5000: Classy aesthetics
Furthermore, in addition to its excellent sound, the RT-5000 is as pleasing to the eye as it is to the ear. Its chassis skilfully combines a CNC-machined aluminium structure with a wooden front panel, leather covering for the upper part and gold plating for the interactive elements, offering a finish that is both classy and elegant.
Aperçu du Roselsa RT-5000
16.35mm jack headphone output
23.5mm jack headphone output
3Balanced 4.4mm jack headphone output
4Gain adjustment
5Mute
6EQs preset
7Operating indicator
8Volume potentiometer
9USB-B input
10Toslink optical input
11Coaxial input
12Bluetooth antenna / Pairing
13RCA line output
14XLR line output
15Power on
16DC power port
Technical specifications
Type of productDAC
Headphone Amplifier
Inputs1x Coaxial
1x Optical Toslink
1x USB-B
Bluetooth
Outputs1x Single-ended 3.5mm jack headphone output
1x Balanced 4.4mm jack headphone output
1x Single-ended 6.35mm jack headphone output
1x Single-ended stereo RCA line output
1x Balanced stereo XLR line output
DAC chips2x ES9038Pro
Amplification chips2x JRC MUSES01
LPF2x OPA1612
I/V circuit8x OPA1612
Bluetooth chipQualcomm QCC5125
Output powerSingle-ended: 800mW @ 32Ω
Balanced: 1600mW @ 32Ω
DSD up to DSD256
THD-112dB (0.0005%)
SNR125dB
Channel separation-115dB
Supported Bluetooth codecsLDAC, aptX Adaptive, aptX HD, aptX, AAC, SBC
Supported formatsMP3, WMA, FLAC, WAV, AAC, HE-AAC, Apple Lossless, AIFF, DSD, DXD, APE, MQA
Power supply15V DC 3A
Weight825g
Package1x Roseselsa RT-5000
1x Mains adapter
1x USB-B to USB-C cable
1x USB-B to USB-A cable
OutputJack 3.5mm
OutputJack 6.35mm
OutputJack 4.4mm
DAC / ADC ChipES9038PRO
Max sampling rate384kHz
Max sampling rateDSD256
ClassN/A
ROSESELSA RT-5000 DAC Headphone Amplifier ES9038Pro MUSES01 Bluetooth 5.1 32bit 384kHz DSD256 Black
The RT-5000 from Roseselsa is a DAC and amplifier for headphones using a pair of SABRE ES9038Pro chips and JRC MUSES01 transistors for...
