Headphone amplifier 2x1.3W 32Ω
The SMSL SH-6 is a compact, affordable and powerful desktop headphone amplifier. The sturdy aluminum chassis hides many high quality components, allowing to deliver a beautiful musicality and sound richness. The SH-6 also benefits from a comfortable power reserve, allowing it to adapt to a wide range of headphones, even high-impedance ones, with an output power of 2x1.3W under 32Ω. A gain control also allows to take advantage of power boost for the most demanding headphones. On the connectivity side, the SH-6 is simple and efficient. It has a stereo RCA input, a 6.35mm headphone output and a pre-out RCA output.
Product type | Headphone amplifier |
Input | 1x Stereo RCA |
Outputs | 1x Stereo RCA Pre-out 1x Jack 6.35mm headphone output |
Output power | 2x 2.6W @ 16Ω 2x 1.3W @ 32Ω |
SNR | 134dB |
Output noise | 1.3µV |
THD+N | -123dB, 0.00006%% (1kHz, 32Ω) -118dB, 0.00012% (20-20kHz, 32Ω, 0dB) |
THD | < -125dB, 0.00006% |
Input impedance | 47kΩ |
Output impedance | Amplifier : Near 0Ω Pre-out : 22kΩ |
Frequency response | 20Hz - 500kHz (-3dB) |
Gain | Low : 0dB High : 15.5dB |
Consumption | < 30W |
Standby consumption | < 0.1W |
Dimensions | 140 x 115 x 28mm |
Weight | 380g |
Color | Black |
Power cable | Included |
