SMSL SH-X Balanced Headphone Amplifier
-7%
The SMSL SH-X balanced headphone amplifier is a powerful, compact headphone amplifier featuring no less than 80 low-noise operational amplifiers. It features good measurements, with an SNR of 137dB and a THD+N < 0.00005%. The SH-X features three gain levels and an IPS color display on the front panel.
Reduced price!
Reference : 18709
699,00 €tax incl.
-7%
649,00 €tax incl.
540,83 € tax excl.
Photo of SMSL SH-X balanced headphone amplifier
The SMSL SH-X balanced headphone amplifier is a powerful, compact headphone amplifier featuring no less than 80 low-noise operational amplifiers. It features good measurements, with an SNR of 137dB and a THD+N < 0.00005%. The SH-X features three gain levels and an IPS color display on the front panel. In terms of connectivity, it features a stereo RCA and stereo balanced XLR input, as well as 3 headphone outputs: 6.35mm jack, 4.4mm balanced jack and 4-pin XLR. There are also two line outputs for use as preamplifiers: stereo RCA and balanced stereo XLR.
SMSL SH-X highlights
SMSL SH-X: a powerful headphone amplifier
SMSL's SH-X delivers power up to 2x11.5W at 16 ohms, and up to 2x5.5W at 32 ohms. This makes it compatible with the majority of headphones on the market. In fact, it can drive high-impedance headphones with 2x600mW of power at 300 ohm and 2x300mW at 600 ohm.
Photo du SMSL SH-X
Les niveaux de gain du SMSL SH-X
SMSL SH-X: 3 levels of gain
The SH-X features 3 gain levels. With -2dB (low), 6dB (Mid), and 23dB (High) for its balanced interface and -8dB (Low), 0dB (Mid), and 17dB (High) for its unbalanced interface. This allows you to optimize the output level in relation to your headphones or in-ear monitors, if required.
SMSL SH-X: quality components
Photo of SMSL SH-X AOPs
80 operational amplifiers
The SH-X features 40 OPAs per channel.
Photo of SMSL SH-X resistors and relays
Reliable resistors and relays
High-precision, low-temperature resistors and high-quality relays ensure high levels of performance and stability.
Photo of SMSL SH-X power supply system
A clean power supply
The SH-X power supply system is a low-noise, high-efficiency power supply.
SMSL SH-X overview
SMSL SH-X connection diagram
1IPS color display
2LED indicator
3Control window
4Balanced XLR headphone output
5Balanced 4.4mm headphone output
66.35mm headphone output
7Control knob
8Balanced XLR line output
9Balanced XLR input
10IEC power supply
11Floating ground/grounding switch
12USB update port
13RCA line output
14RCA input
Product typeBalanced headphone amplifier
Inputs1x RCA stereo input
1x XLR balanced stereo input
Outputs1x 6.35mm headphone output
1x 4.4mm balanced headphone output
1x XLR 4-pin headphone output
1x RCA stereo line output
1x XLR balanced stereo line output
Output power2x 11.5W @ 16 ohms
2x 5.5W @ 32 ohms
2x 600mW @ 300 ohms
2x 300W @ 600 ohms
SNR137dB
Dynamic range137dB
THD+N-123dB, 0.00006% (1kHz, 32 ohms)
Input impedance34Kohm
Headphone output impedanceClose to 0 ohm
Line output impedanceXLR balanced: 66 ohm
RCA unbalanced: 33 ohm
Frequency response20Hz-100KHz (-0.5dB)
GainBalanced: -2dB (Low), 6dB (Mid), et 23dB (High)
Unbalanced: -8dB (Low), 0dB (Mid), et 17dB (High)
Power consumption<50W
Standby power consumption< 0.5W
Dimensions250 x 51 x 192mm
Weight2.42kg
ColorSilver
Package1x SMSL SH-X balanced headphone amplifier
1x Power cable
SMSL SH-X measurements
InputXLR
OutputJack 6.35mm
OutputJack 4.4mm
ColorSilver
ClassN/A
The SMSL SH-X balanced headphone amplifier is a powerful, compact headphone amplifier featuring no less than 80 low-noise operational amplifiers....
