XDUOO DM-01 Headphones Amplifier DAC
10%
The xDuoo DM-01 is a DAC and headphone amplifier based on the use of audiophile components integrated within a most singular form factor. It is based on a CS43131 DAC / headphones amplifier chip, an XMOS XU316 USB interface and a 12AU7 tube. It is therefore able to support sampling rates up to PCM 32bit 384kHz, DSD256 and MQAx8, while offering output power up to 2x1500mW under 32 ohm.
Reduced price!
Reference : 20745
Limited time offer:
289,00 €tax incl.
-10%
260,10 €tax incl.
216,75 € tax excl.
Last items in stock !
Shipping date: 05-05-2026.
xDuoo DM-01 Headphones Amplifier DAC CS43131 XMOS XU316 Bluetooth 5.4 32bit 384kHz DSD256 MQA
Photo du xDuoo DM-01
The xDuoo DM-01 is a DAC and headphone amplifier based on the use of audiophile components integrated within a most singular form factor. It is based on a CS43131 DAC / headphones amplifier chip, an XMOS XU316 USB interface and a 12AU7 tube. It is therefore able to support sampling rates up to PCM 32bit 384kHz, DSD256 and MQAx8, while offering output power up to 2x1500mW under 32 ohm. Added to this is Bluetooth 5.4 for reliable, stable reception thanks to codecs such as SBC, AAC, aptX, aptX Adaptive, aptX HD and LDAC. In terms of appearance, xDuoo offers us a most astonishing form factor with a robot-shaped device.
Circuit du xDuoo DM-01
xDuoo DM-01 overview
Aperçu du xDuoo DM-01
1Tube 12AU7
2Volume control
3Status LED
4Microphone (Bluetooth)
5Power
63.5mm jack headphone output
7Input selection
8Screen
9AUX jack 3.5mm output
10USB-C input
1112V DC power supply via DC jack
Product typeDAC / headphones amplifier
DAC/amp chipCS43131
Tube12AU7
Inputs1x USB-C
Bluetooth
Outputs1x 3.5mm headphones output
1x 3.5mm AUX output
Supported sample ratesPCM up to 32bit 384kHz
DSD up to DSD256
MQAx8
Frequency response20Hz-20kHz (+/-0.5dB)
Supported Bluetooth codecsSBC, AAC, aptX, aptX Adaptive, aptX-HD, LDAC, LE Audio (LC3, aptX-Lite)
OS compatibilityWindows, Linux, Mac OS X, IOS
3.5mm jack headphones output specifications
Output power1500mW @ 32 ohm
THD+N≤ 0.3% @ 1 kHz
SNR116dB
Crosstalk≥ 67dB
AUX jack 3.5mm output specifications
Output level6Vrms
THD+N≤ 0.2% @ 1 kHz
SNR116dB
Crosstalk≥ 70dB
Power supply12V DC via jack DC
Dimensions17.5 x 6 x 8.6cm
Weight0.73g
Package1x xDuoo DM-01
1x Mains adapter
OutputJack 3.5mm
DAC / ADC ChipCS43131
Max sampling rateDSD256
Max sampling rate384kHz
Max sampling rateMQA
ColorBlue
ClassTube amp
ClassClass A / AB
Ne pas se fier aux apparences.....
Je tien à remercier Audiophonics d'avoir ajouté cet ampli casque a leur catalogue suite à ma demande.
Avant de l'essayer j'ai viré le tube d'origine pour le remplacé par un ELECTRO-HARMONIX GOLD 12AU7/ECC82!! Puis enfin trouver le temps pour l'écouter avec un MEZE AUDIO CLASSIC 99. Mes premières impressions sont : a wouhais quand même!! Sous ces apparences de jouet retro c'est du sérieux, l'écoute est très agréable tout y es, précision, équilibre tonal et cette petite chaleur dans les voix sans exagération. Je n'irais pas dans le lexical audiophile, mais perso il me convient pleinement.
La liaison Bluetooth est qualitative en plus d'être très stable, en USB-C avec un câble permettant les hauts débits l'écoute en HI-RES sur QOBUZ est vraiment excellente!!!
Concernant le produit en lui même la qualité de fabrication est superbe, tout comme le soin apporté au packaging. Pour la couleur selon les photos des sites il peut paraitre plus bleu que vert.. il et bien vert! Personnellement je n'ai pas mis de sticker sur son ventre car ce dernier s'allume de couleur différente en fonction du débit audio, car ils sont a peine translucide.
Bref une petite folie que je me suit faite & que je ne regrette pas!!
This review has been posted for XDUOO DM-01 Headphones Amplifier DAC CS43131 XMOS XU316 Bluetooth 5.4 32bit 384kHz DSD256 MQA
The xDuoo DM-01 is a DAC and headphone amplifier based on the use of audiophile components integrated within a most singular form factor. It is...
