neutral sound with very good stock tubes, rolled nos RFT 12au7 from 1960 east germany made. more relaxed sound with more extended highs.
Tube Headphone Amplifier 2x 12AU7 DAC 2x ES9038Q2M Bluetooth 5.0 aptX HD LDAC 32bit 384kHz DSD256 MQA
xDuoo unveils with its TA-22 a beautiful headphone amplifier and DAC combo with a neat design. This one embeds quality components in order to provide a sound restitution both musical and detailed. It also offers a complete connectivity to meet the vast majority of needs, as well as a convenient Bluetooth connectivity.
Using a pair of 12AU7 tubes and a Class A transistor buffer, the TA-22 is capable of developing a power of 3000mW in balanced output and 1500mW in single-ended output, offering a soft and warm sound reproduction, characteristic of this type of amplification. It is thus able to drive both high sensitivity headphones and high impedance headphones while ensuring a beautiful musicality.
The TA-22's converter stage features a balanced architecture with two ES9038Q2M chips, ensuring high precision and clarity, perfectly complementing the tube amplifier system. These chips also allow the TA-22 to support high-resolution audio streams, up to 32bit 384kHz PCM and DSD256, as well as to render MQA files. The conversion circuitry is also equipped with a pair of low phase noise oscillators to provide a clean clock signal to minimize jitter.
In addition to a complete connectivity, the TA-22 offers a Bluetooth 5.0 reception thanks to its Qualcomm 5125 chip, so it is possible to broadcast and control your music remotely, from a smartphone or a tablet for example. This receiver supports aptX HD and LDAC codecs for high quality wireless playback.
The TA-22 also provides a stereo RCA pre-out. It is thus possible to connect an amplifier or active speakers in order to take advantage of the sound signature of the TA-22 tubes.
| Specifications | |
| Product type | Tube headphone amplifier and DAC |
| Tubes | 2* 12AU7 |
| DAC chip | 2* ES9038Q2M |
| S/PDIF interface | AK4118 |
| Inputs | Bluetooth 5.0 1* USB-B 1* Coaxial 1* Optical Toslink 1* Balanced stereo XLR 1* Balanced Jack 4.4mm 1* Stereo RCA |
| Outputs | 2* Stereo RCA 1* Balanced Jack 4.4mm headphone output 1* Balanced XLR 4 pins headphone output 1* Single-ended Jack 3.5mm headphone output |
| Screen | OLED 3.12" |
| USB compatibility | Windows Mac OS Linux Android iOS |
| Supported sampling rates | USB : PCM up to 32bit 384kHz, Native DSD up to DSD256, MQA up to 384kHz Optical / Coaxial : PCM up to 24bit 384kHz, DSD DoP up to DSD128 |
| Supported Bluetooth codecs | SBC, AAC, aptX, aptX LL, aptX HD, LDAC |
| Single-ended headphone output parameters | |
| Output power | 1500mW @ 32Ω |
| Frequency response | 20Hz~60kHz (±0.5dB) |
| THD+N | ≤ 0.02% |
| SNR | 113dB |
| Crosstalk | ≥ 70dB |
| Balanced headphone output parameters | |
| Output power | 3000mW @ 32Ω |
| THD+N | ≤ 1% |
| SNR | 118dB |
| Crosstalk | ≥ 96dB |
| AUX output parameters | |
| Output level | 2Vrms |
| Frequency response | 20Hz~20kHz (±0.5dB) |
| THD+N | 0.001% |
| SNR | 113dB |
| Crosstalk | ≥ 113dB |
| General | |
| Dimensions (W*D*H) | 260*190*70mm |
| Weight | 3kg |
| Color | Gray |
| Power cable | Included |
| Input | USB |
| Input | XLR |
| Input | Optical |
| Input | Jack 4.4mm |
| Input | RCA |
| Input | SPDIF |
| Input | Bluetooth |
| Output | RCA |
| Output | XLR |
| Output | Jack 3.5mm |
| Output | Jack 4.4mm |
| DAC / ADC Chip | ES9038Q2M |
| Max sampling rate | DSD256 |
| Max sampling rate | 384kHz |
| Max sampling rate | MQA |
| Color | Gray |
| Class | Class A / AB |
| Class | Tube amp |
| Networking | No |
| Remote Control | No |
Average votes 5.0 / 5 4 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Leonas J.
Jose l.
Jose l.
Damir D.
