Utilisé pour convertir un signal analogique provenant de ma platine vinyle vers ma barre de son en optique ! Fonctionne sans aucun problème, très bonne qualité sonore et de fabrication.
The miniDSP PocketADC is an analog-to-digital converter featuring a stereo RCA analog input and two digital outputs : a Toslink optical output and a coaxial output. Thanks to a DIP switch on one of the front panels, it can convert at several sampling rates up to PCM 24bit 192kHz. Conversion is carried out in such a way as to take advantage of optimal signal digitization for low-noise rendering. Finally, the miniDSP PocketADC is supplied with 12V via DC jack, and also has a secondary power supply output for powering a third-party device.
| Specifications | |
| Product type | ADC converter |
| ADC Chip | ES9821Q |
| Input | 1x RCA |
| Outputs | 1x Optical Toslink 1x Coaxial |
| Compatible sample rates | 24bit 48kHz / 96kHz / 192kHz (selection via DIP switch) |
| Frequency response | 20Hz-20kHz (±0.1dB) |
| Max. input level | 2Vrms |
| Input impedance | 100KΩ |
| SNR (Signal to Noise Ratio) | 118dB |
| THD+N @1kHz | -114dB (0.0002%) |
| Crosstalk | -130dB |
| General | |
| Power supply | 12V DC via DC jack (power supply included) |
| Power consumption | 2W (idle) |
| Dimensions | 13 x 40 x 62mm |
| Package | 1x miniDSP PcketADC 1x Power adapter 12V 1.6A 2x DC jack connection cable |
| Input | RCA |
| Output | Coaxial SPDIF |
| Output | Optical Toslink |
| DAC / ADC Chip | ES9821Q |
| Max sampling rate | 192kHz |
| Color | Silver |
Average votes 5.0 / 5 3 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
JONATHAN R.
Aurelijus S.
Svilen I.
