Connector
Max sampling rate
DAC / ADC Chip
Class
Input voltage (V)
V
V
Output voltage (V)
Connectic
Length
1 m - 2 m
Conductors material (Cable)
Contacts Plating (Connector)
Input
Output
Remote Control
Networking
Transmission / Reception protocol
Streaming services
Color
Conductors Plating (Cable)
Shielding
Krzysztof K.
Good HDMI Cable, indeed!
Hey, folks!
Urtsua R.
Fine
Ruben P.
Audiophile grade +
DAC
The term DAC (Digital to Analog Converter) designates a digital to Analog converter, ideal to embellish and sublimate your music pieces in digital format. Find here all our DAC Audio USB and/or SPDIF selected and selected for you, while being on the quality and the sound rendering that they offer.
There is something for every taste and budget, from DACs under 50€ to start in the audiophile world, to DACs at 3000€ and more to perfect a HiFi installation worthy of the name.
  • DAC with volume
    DAC with volume
    The term DAC (Digital to Analog Converter) refers to a digital-to-analog converter.
    Here is a selection of DACs with digital or analog volume. By design, these High Definition DACs are true digital HUBs, with digital inputs on AES EBU, SPDIF coaxial, I2S, Toslink optical and other connectors. Internet BOXes, multimedia servers and audiophile digital sources can all be centralized on a single volume-controlled device.
    These are the digital preamps of the 21st century.
  • DAC without volume
    DAC without volume
    Le terme DAC (Digital to Analog Converter) désigne un convertisseur numérique vers analogique. Retrouvez une sélection de nos DAC Audio USB, SPDIF, I2S, AES/EBU choisis pour vous, capables de sublimer vos fichiers audio Haute Définition 24bit et 32bit.
    Des DAC à moins de 50€ pour débuter dans le monde audiophile, aux DAC à 3000€ et plus pour parfaire une installation HiFi digne de ce nom. Vous trouverez facilement dans cette sélection drastique un convertisseur audio à la mesure de votre système Haute Fidélité.
  • Portable DAC
    Portable DAC
    The term DAC (Digital to Analog Converter) refers to a digital to analog converter. Find a selection of our USB, SPDIF, I2S, AES/EBU Audio DACs chosen for you, capable of sublimating your 24bit and 32bit High Definition audio files.
    Portable DAC let you enjoy your high-definition music wherever you are, anytime.
