FIIO QX13 Portable DAC Headphone Amplifier Carbon Fiber Black
-5%
With its QX13, FiiO offers us a relatively affordable portable DAC headphone amplifier based on quality components. Indeed, the QX13 is armed with an 8-channel ES9027PRO DAC chip, a USB XMOS-316 interface and no less than 6 AOPs. This chipset enables it to support high-definition sampling rates up to PCM 32bit 768kHz and DSD512, while offering up to 2x 900mW of output power under a 32-ohm load in desktop mode.
Reduced price!
Reference : 20968
209,01 €tax incl.
-5%
199,01 €tax incl.
165,84 € tax excl.
FIIO QX13 Portable DAC Headphone Amplifier ES9027PRO XMOS XU-316 32bit 768kHz DSD512 Carbon Fiber Black
Photo du FiiO QX13
With its QX13, FiiO offers us a relatively affordable portable DAC headphone amplifier based on quality components. Indeed, the QX13 is armed with an 8-channel ES9027PRO DAC chip, a USB XMOS-316 interface and no less than 6 AOPs. This chipset enables it to support high-definition sampling rates up to PCM 32bit 768kHz and DSD512, while offering up to 2x 900mW of output power under a 32-ohm load in desktop mode. In terms of inputs/outputs, the essentials are there, with a USB-C input and two headphone outputs: a 3.5mm jack/SPDIF headphone output and a balanced 4.4mm jack headphone output. The QX13 also boasts a robust carbon fiber body to limit external interference and regulate heat, and an attractive, scratch-resistant color display.
Photo du FIIO QX13
FiiO QX13: ES9027PRO DAC and XMOS-316 USB interface
The FiiO QX13 is blessed with a high-performance ES9027PRO 8-channel DAC chip based on Hyperstream IV architecture, and an XMOS-316 USB interface. ES9312 regulators support the DAC chip with a specific focus on jitter reduction. This chipset gives the QX13 the ability to support high-resolution sampling rates up to PCM 32bit 768kHz and DSD512, allowing you to enjoy the best of your streaming platforms or favorite local files. Furthermore, the USB interface also offers support for 10-band equalization via the FiiO Control App.
Interface USB du FIIO QX13
Les AOP du FIIO QX13
FiiO QX13: 6 AOP configuration
FiiO has chosen to integrate 4 INA1620 AOPs and 2 OPA1612 AOPs to ensure non-interference between the different channels and to bring wide dynamics to the final sound rendering, whatever the impedance load.
FiiO QX13: an audiophile architecture
The digital and analog parts are separated and isolated to limit interference and better manage heat dissipation. Each component is carefully selected to work in concert with its peers in the signal processing chain. The balanced architecture offers fine, clean signal processing for the most pleasing rendering at the QX13 output stage.
L'architecture du FIIO QX13
FiiO QX13: desktop mode for boosted power
In desktop mode, the QX13 benefits from a considerable gain in power, enabling it to drive a wide range of headphones and IEMs. In fact, it can deliver up to 2x 900mW of power at 32 ohms. This makes it possible to drive headphones with impedances ranging from 16 to 350 ohms.
Mode desktop du FIIO QX13
FiiO QX13: a 1.99-inch color screen
The QX13 features a 1.99-inch tempered glass color screen for easy viewing and configuration. Several UI interfaces are also available for complete customization.
L'écran couleur du FIIO QX13
FiiO QX13 overview
Aperçu du FIIO QX13
1Switch mode desktop
2USB-C audio input / Power supply
3Volume control -
4Play/Pause
5Volume control +
6USB-C power port
7Tempered glass color display
8balanced 4.4mm jack headphone output
93.5mm jack headphone output/SPDIF
Product typeDAC amplificateur casque portable
DAC chipES9027PRO
USB interfaceXMOS XU-316
OPA2x OPA1612
Hadphone amplifier OPA4x INA1620
Input1x USB-C
Outputs1x 3.5mm jack headphone output/SPDIF
1x Balanced 4.4mm headphone output
Suppoted sample ratesUSB DAC: PCM 32bit 768kHz, DSD512, MQA
Coaxial output: 24bit 96kHz
EQ adjustment10-band dynamic EQ control (±12dB)
8 built-in preset EQ styles
User-defined EQ support
Screen rotation
Recommended headphone impedance8~350Ω
GainLow/High (Desktop mode)
FiiO Control App compatibility
USB UAC1.0 compatibility (Switch, PS5, etc.)
Headphone output performance and settings (3.5 mm output, USB decoding, desktop mode, high gain)
Output powerL+R≥440mW+440mW (16Ω, THD+N<1%)
L+R≥310mW+310mW (32Ω, THD+N<1%)
L+R≥40mW+40mW (300Ω, THD+N<1%)
SNR≥124dB (A-weighted)
Frequency response20Hz~90kHz: attenuation<2.8dB
20Hz~20KHz: attenuation<0.07dB
Output impedance<1Ω
Crosstalk≥ 77dB
Peak output voltage9.8Vp-p
THD+N<0.0004% (1kHz/-2dB@32Ω)
Noise floor<2uV (A-weighted)
Headphone output performance and settings (4.4 mm output, USB decoding, desktop mode, high gain)
Output powerL+R≥480mW+480mW (16Ω, THD+N<1%)
L+R≥900mW+900mW (32Ω, THD+N<1%)
L+R≥125mW+125mW (300Ω, THD+N<1%)
Frequency response20Hz~70kHz: attenuation<2.8dB
Output impedance<1.5Ω
Crosstalk≥113dB
Peak output voltage17.5Vp-p
THD+N<0.0006% (1kHz/-8dB@32Ω)
Noise floor<3.4uV (A-weighted)
Headphone output performance and settings (3.5 mm output, USB decoding, non-desktop mode, high gain)
Output powerL+R≥370mW+370mW (16Ω, THD+N<1%)
L+R≥250mW+250mW (32Ω, THD+N<1%)
L+R≥30mW+30mW (300Ω, THD+N<1%)
SNR≥123dB (A-weighted)
Output impedance<1Ω
Crosstalk≥75dB
Peak output voltage8.7Vp-p
Headphone output performance and settings (4.4 mm output, USB decoding, non-desktop mode, high gain)
Output powerL+R≥470mW+470mW (16Ω, THD+N<1%)
L+R≥605mW+605mW (32Ω, THD+N<1%)
L+R≥70mW+70mW (300Ω, THD+N<1%)
SNR≥122dB (A-weighted)
Crosstalk≥113dB
Peak output voltage13Vp-p
THD+N<0.0006% (1kHz/-6dB@32Ω)
Noise floor<3.5uV (A-weighted)
Power supply5V 1A
Dimensions64.2x30.7x13 mm
Weight39.2g
ColorCarbon fiber black
Package1x DAC Portable headphone amplifier
1x USB-C to USB-C cable
1x Leather case with magnetic attachment
OutputJack 4.4mm
OutputCoaxial SPDIF
OutputJack 3.5mm
DAC / ADC ChipES9027PRO
Max sampling rateDSD512
Max sampling rateMQA
Max sampling rate768kHz
With its QX13, FiiO offers us a relatively affordable portable DAC headphone amplifier based on quality components. Indeed, the QX13 is armed with...
