By buying this product you get 147 loyalty points
To celebrate its 15 years of expertise, Denafrips presents the Ares 15TH, a high-performance, balanced NOS R2R DAC. The digital/analog conversion stage is made up of no fewer than 480 carefully selected precision resistors, and is combined with an Altera FPGA. The power supply stage of the Ares 15TH is no exception, featuring a large 60VA O-core transformer with UP-OCC copper windings, eight LDO regulators and numerous high-performance capacitors. This ensemble enables the Denafrips Ares 15TH to deliver sound reproduction of incredible precision, clarity and richness.
Key features:
The Ares 15TH's circuitry is housed in a sturdy, elegant anodized aluminum chassis. Its compactness makes for easy integration.
Le Denafrips Ares 15TH profite d'une connectique complète. On y retrouve en entrée de l'USB-B associé à une interface STM32, de l'I2S via HDMI, de l'optique Toslink et du coaxial. Côté sortie on pourra compter sur du RCA stéréo asymétrique et du XLR stéréo symétrique.
| 1 | Balanced XLR output |
| 2 | Single-ended RCA output |
| 3 | Coaxial input |
| 4 | Toslink optical input |
| 5 | I2S input (HDMI) |
| 6 | USB-B input |
| 7 | Power connector |
| Specifications | |
| Product type | Balanced NOS R2R DAC |
| Inputs | 1x USB-B 1x I2S via HDMI 1x Coaxial 1x Optical Toslink |
| Outputs | 1x Balanced stereo XLR 1x Single-ended stereo RCA |
| Supported sampling rates | USB : PCM up to 1536kHz, DSD up to DSD1024 I2S / Optical / Coaxial : PCM up to 24bit 192kHz, DSD DoP up to DSD64 |
| Output level / impedance | RCA : 2Vrms @ 625Ω XLR : 4Vrms @ 1250Ω |
| Sampling modes | Non-oversampling (NOS) Oversampling (OS) |
| Filters | Slow Sharp |
| Frequency response | 20Hz - 70kHz -3dB |
| THD+N | 0.004% |
| SNR | 115dB |
| Dynamic range | > 119dB |
| Crosstalk | -124dB |
| General | |
| Supply voltage | 100-240VAC 50/60Hz |
| Consumption | ≤ 20W |
| Color | Silver |
| Dimensions | 215 x 230 x 45mm |
| Weight | 3.5kg |
| Package | 1x Denafrips Ares 15TH |
| Input | I2S via HDMI |
| Input | USB |
| Input | Optical |
| Input | SPDIF |
| Output | XLR |
| Output | RCA |
| DAC / ADC Chip | R2R LADDER DAC |
| Max sampling rate | 1536kHz |
| Max sampling rate | DSD1024 |
| Color | Silver |
| Networking | No |
| Remote Control | N/A |
