By buying this product you get 379 loyalty points
The Denafrips Venus II 12Th-1 balanced R-R2R DAC builds on the excellent, award-winning Venus II in an improved version, with enhanced performance and even more musical, richer sound reproduction.
Each channel of this DAC is equipped with an independent high-speed FPGA to facilitate decoding of the digital signal by means of 4 sets of R-2R networks with a tolerance of just 0.005%. The choice of such a design results in very low linearity error, high decoding speed and low digital noise, not only to ensure that the audio signal has extremely low distortion, but also to ensure very low background noise for the most accurate and transparent reproduction possible.
All digital inputs pass through the FIFO buffer and are re-clocked by the integrated TCXO clock. Excellent word-clock jitter rejection makes Denafrips Venus II 12Th-1 less dependent on the quality of the source equipment's clock.
The Venus II 12Th-1 power supply uses a dedicated linear power supply, isolated in a 1.5mm-thick metal alloy housing to drastically limit interference with audio circuits. In addition, two 80VA O-Core transformers supply the DAC's digital and analog sections independently, and a number of low ESR capacitors provide a good energy reserve while filtering the electrical signal.
1 | XLR output right channel |
2 | XLR output left channel |
3 | RCA output right channel |
4 | RCA output left channel |
5 | RCA coaxial input |
6 | BNC coaxial input |
7 | AES/EBU input |
8 | AES/EBU input |
9 | Optical Toslink input |
10 | I2D HDMI input |
11 | USB-B input |
12 | AC power supply |
Product type | R2R balanced DAC |
Inputs | 1x Coaxial RCA 1x Coaxial BNC 2x AES/EBU 1x Optical Toslink 1x I2S via HDMI LVDS 1x USB-B |
Outputs | 1x Balanced stereo XLR 1x Single-ended stereo RCA |
Supported sampling rates | USB / I2S : PCM up to 1536kHz, DSD up to DSD1024 Coax / AES / Optical : PCM up to 24bit 192kHz, DSD DoP64 |
Operating modes | Non-oversampling (NOS) Oversampling (OS) |
Frequency response | 20Hz - 70kHz -3dB |
THD+N | 0.002% |
SNR | 120dB |
Dynamic range | > 121dB |
Crosstalk | -110dB |
Supply voltage | 100-240VAC, 50/60Hz |
Consumption | ≤ 20W |
Dimensions | 320 x 330x 80mm |
Weight | 8.5kg |
Color | Silver |
Input | USB |
Input | Optical |
Input | SPDIF |
Input | I2S via HDMI |
Output | RCA |
Output | XLR |
Max sampling rate | 1536kHz |
Max sampling rate | DSD1024 |
Color | Silver |
Networking | No |
Remote Control | N/A |
