XDUOO LEGENDARY CLASSIC WM8741 DAC Module Card for XD05 Pro
The DAC module card xDuoo Legendary Classic WM8741 allows the sound signature to be changed quickly and easily on XD05 Pro portable headphone amplifier / DAC. This DAC module card is specifically designed to deliver a rich and natural sound, particularly suited to vintage recordings and jazz, offering a sound reminiscent of tube-based equipment.
Reference : 22225
219,00 €tax incl.
182,50 € tax excl.
xDuoo Legendary Classic WM8741 WM8741 DAC Module Card for XD05 Pro
Product typeDAC module card
Sampling rateUSB/SPDIF : 16-32 bits / 44.4kHz-192kHz
BT : 16-32 bits / 44.4kHz-96kHz
Output powerSingle-ended output : 2000mW (32Ω, THD+N< 1%) / 240mW (300Ω, THD+N < 1%)
Balanced output : 2000mW (32Ω, THD+N < 1%) / 930mW (300Ω, THD+N < 1%)
Output impedanceSingle-ended output : ≤ 0.2Ω
Balanced output : ≤ 0.4Ω
Peak voltageSingle-ended output : 23.8Vp-p (Turbo Mode)
Balanced output : 31.1Vp-p (Turbo Mode)
Frequency responseSingle-ended output : 20Hz-20kHz (±0.5db)
Balanced output : 20Hz-60kHz (±0.5db)
CrosstalkSingle-ended output : ≥ 75dB
Balanced output : ≥ 105dB
AUX output : ≥ 94dB
Balanced line output : ≥ 105dB
Total harmonic distortion plus noise (THD+N)Single-ended output : 0.0004%
Balanced output : 0.0007%
AUX output : 0.0004%
Balanced line output : 0.0002%
Signal-to-noise ratio (SNR)Single-ended output : ≥ 1174dB
Balanced output : ≥ 119dB
AUX output : ≥ 120dB
Balanced line output : ≥ 123dB
Output levelAUX output : 2.0V
Balanced line output : 2.0V
Packaging1x xDuoo Legendary Classic WM8741
InputNC
OutputNC
DAC / ADC ChipWM8741
Max sampling rate192kHz
ColorGray
The DAC module card xDuoo Legendary Classic WM8741 allows the sound signature to be changed quickly and easily on XD05 Pro portable headphone...
