SOMMERCABLE MERCATOR CAT7 Ethernet cable OFC 4x2x0,25mm² Ø 7.6mm
4.8 / 5
Reference : 895
2,90 €tax incl.
2,42 € tax excl.
Shipping date: 22-09-2026.
SOMMER CABLE - Mercator
As a result of enormous pressures on the mass production of computer cables, quality is often degraded. The consequence is a mediocre retransmission, which obliges to carry out research of long and costly faults.
With type 4 TWISTED PAIR (AWG24) we deliver a quality cablewith twisted cores at short pitch and insulated by PVC sheath or FRNC. This cable is ideal for high-throughput class-D installations according to ISO / IEC 11801 (FAST ETHERNET, ATM155 Protocols). Also available in flexible version AWG26 for use as a patch conductor. The CAT.5e and CAT.7 installation cables are also available in duplex version with an additional shielding braid.
ADVANTAGES:
-High quality insulation, twisted cores with short pitch
-Each pair is shielded separately
-High durability thanks to special sheath material
-Indication of the length printed on the cable
-Shielding type: S-FTP
USE:
- Network equipment High-Speed 1.2 GHz (CAT.8)
- Connections for computers and media installations
- Manufacture of speaker cables
ConstitutionJ02YSCH 4x2x0.56mm / 600MHz
Envelope, diameterFRNC 7.6 mm
AWG23
Brass Cu per coremonofilament
Insulation of the conductorFoam Skin-PE
Protectionsheet AL / PT + drain wire + cross braid
Optical cover100%
Operating temperaturemin. -20 ° C
Operating temperaturemax. 70 ° C
Fire resistance per m0.17 kWh
Weight per m65 g
Colororange
TypeCAT.7
TypePIMF
Capacity / Cond.per 100 m for 1 kHz 49 pF
Impédanthis characteristic(+/- 15 Ohm) 100 Ohm
Resistance of the winding16.8 Ohm / m
Reduction per 100 m (20 ° C)1 MHz: 1.9 dB
Reduction per 100 m (20 ° C)16 MHz: 7.2 dB
Reduction per 100 m (20 ° C)100 MHz: 16.0 dB
Reduction per 100 m (20 ° C)155 MHz: 23.0 dB
Reduction per 100 m (20 ° C)300 MHz: 32.0 dB
Affaiblper 100 m (20 ° C)600 MHz: 45.0 dB
Number of conductors8
Insulation materialPVC
ShieldingNo
4 reviews
works very well
it is identical with the viablue solid core rj45 cable
are 99,9% sure its the same cable viablue sells for almost 15 eur
the sound from tidal is the same with both cables
very good top performance
This review has been posted for SOMMERCABLE MERCATOR CAT7 Ethernet cable OFC 4x2x0,25mm² Ø 7.6mm
excellent
rapport qualité/prix excellent
fil interne rigide
a permis de transferrer la box tv ,avec 15ml de ce cable , de la box internet
Dinero recompensa de fidelidad no utilizada
Yo hice este pedido pero lo anule por falta de stock del producto. Utilice el dinero de la recompensa de fidelidad pero en realidad al anular el pedido no lo utilicé. Ahora voy a comprar y no veo este dinero. Por favor me gustaría recuperarlo para utilizarlo en la siguiente compra. Gracias
Good industry standard improved "sound"
I have connected this cable with the Telegärtner Cat6 connectors. So for less than 25€ you get a high quality Ethernet cable. Covered it with a black sleeve for optics only. Compared to a CAT8 certified finished cable, which I used before, there is a noticeable improvement.
I use the Ethernet cable after a fibre/optic to Ethernet converted to connect to my Allo USBridge Signature streamer.
Only downside of this cable is, it is a bit stiff.
Compared to the Viablue 7S Ethernet cable, which has basically the same specs (23AWG solid core conductors, and they are not silver coated as in the description from Audiophonics!!) the Viablue cable is 5x the price of this Sommercable. The performance of the Viablue EP-7S is slightly better and the Viable is more flexible.
For longer runs of cables, I would go with the Sommercable, for shorter runs my choice is the Viablue EP-7S.
Both are really worse the effort to replace any standard CAT cable in your system.
