VIABLUE H-FLEX Optical Toslink cable Ø 8mm
Toslink H-Flex cables enable professional-quality optical connections between high-end components such as amplifiers, CD/DVD decks and more.
3.7 / 5
Reference : 115
12,50 €tax incl.
10,42 € tax excl.
Shipping date: 30-09-2026.
ViaBlue H-Flex Toslink cables are high-end optical audio cables that transmit digital signals using fiber-optic technology.
With this type of technology, electrical interference has no influence on transmission.
The special fiber design of the waveguide used in Toslink H-Flex cables ensures maximum light source efficiency.
These cables are extremely flexible, thanks to the various machining processes used to apply layers of insulation made from different materials,
This means they can be bent to very steep angles without increasing attenuation.
In the case of even greater bends, H-Flex fiber optic cable transmits your data unaltered.
  • External diameter: 8mm
  • PMMA (POLYMETHYL METHACRYLATE) conductor cross-section: 1mm
The high-quality waveguide is protected by a special flexible plastic component.
Another layer of a very thin yet very hard plastic material directly covers this component to stabilize and fix the sensitive internal structure.
Finally, a thick outer sheath protects these three inner layers from damage and deterioration.
Diameter (mm)8.0
Length (m)Sold by length
Number of conductors1
Insulation materialNC
ShieldingNo
Section (mm²)N/A
Conductors material (Cable)Optical Fiber
Ground / ShieldingNo
3 reviews
Très bon rendu à bas prix
Après plusieurs tentatives de montage infructueuses (cassage de la fibre car très fragile), je suis enfin parvenu à obtenir quelque chose de concluant (avec un simple cutter et de la patience). Sur un Audio-GD R2R 11 associé à un ampli de puissance hypex Ncore j'ai un rendu plus clair et aéré qu'avec un câble coaxial canare L-5CFB 75Ohm.
J'en commande deux mètres supplémentaires afin de fabriquer d'autres câbles.
This review has been posted for VIABLUE H-FLEX Optical Toslink cable Ø 8mm
Pour moi le montage n'a pas fonctionné... non recommandé pour l'achat.
Fibre optique de bonne facture. La découpe est délicate mais à la portée de tous avec un cutter.
