SOMMERCABLE MERCATOR CAT8.1 Ethernet Cable OFC Copper 8x0.32mm² Ø8.2mm
This Sommercable Mercator Cat 8.1 Ethernet cable has 8 conductors of 0.32mm² each (22AWG) with double tinned copper braid shielding. This cable, sold by the metre, will enable you to design the latest generation of category 8.1 network cables up to 40Gbit/s bandwidth and 2000MHz frequency.
4.0 / 5
Reference : 18042
2,90 €tax incl.
2,42 € tax excl.
Shipping date: 19-08-2025.
Canare
SOMMERCABLE MERCATOR CAT8.1 Câble Ethernet OFC
This Sommercable Mercator 8.1 with halogen-free LSZH sheath impresses with its performance and excellent quality, in particular to meet standards IEC 60332-1-2, IEC 60754-1/2, IEC 61034-1/2 as well as high fire protection class B2ca (flame retardant / low heat release).
Technical specifications
Product typeEthernet cable
Ethernet standardCat 8.1
Bandwidth 40Gbit/s
Transmission frequency2000MHz
TechnologiesPoE / PoE+ / VoiP
StandardsB2ca (flame retardant)
PropertiesHalogen-free LSZH
Cable diameterØ8.2mm
Conductors diameter8x0.62mm (Ø)
Conductors cross-section8x0.32mm² (22AWG)
Conductor materialOFC copper
Cable shieldingPimF - Copper braiding tin-plated
Network - PiMF - Tinned copper braid
Impedance110Ω
Weight / 100m6.2kg
ColorBlue
QuantityCable sold by meter
Diameter (mm)8.2
Length (m)Sold by length
Number of conductors8
Insulation materialNC
ShieldingYes
Section (mm²)0.32
Ground / ShieldingYes
2 reviews
Very Good
I like this cable and price very much.
This review has been posted for SOMMERCABLE MERCATOR CAT8.1 Ethernet Cable OFC Copper 8x0.32mm² Ø8.2mm
Pas terrible.
La ohoto est trompeuse, pas le même bleu et la tresse de masse est en realité quelques fils qui se battent dn duel. Le câle est très rigide et la gaine externe blanchit, voire se fissure si vous tentez de le plier. Son petit frère est beaucoup mieux. Et si vous voulez quand même l'acheter, il faut lui associer des Connecteurs cat 8 car les telegartner MPF8 T568B ne sont pas adaptés, opté pour MPF8 8.1 avec bouchon de serrage.
This Sommercable Mercator Cat 8.1 Ethernet cable has 8 conductors of 0.32mm² each (22AWG) with double tinned copper braid shielding. This...
