AUDIOPHONICS XMOS U208 Digital interface USB I2S AES 2x TCXO OTG 24bit 192kHz
XMOS interface digitale USB 24/192khz Alimentation linéaire Black
This interface based on the now famous XMOS U208 provides high level digital outputs in S/PDIF coaxial, optical, AES/EBU and I2S. USB has Asynchronous USB management.
4.8 / 5
Reference : 10547
179,00 €tax incl.
149,17 € tax excl.
Shipping from France
Billing in France
Technical support in France
USB XMOS U208 Interface
24bit 192kHz
This interface based on the now famous XMOS provides high level digital outputs in S/PDIF coaxial, optical, AES/EBU and I2S. USB has Asynchronous USB management.
This version offers an XMOS U208 interface combined with an integrated regulated linear power supply. Recognized without drivers under MacOS and linux this one requires a Windows driver (Click here).
This model has a regulated linear power supply as standard and can be directly connected to the 220V. This digital interface is compatible with Audio-GD devices with RJ45 I2S or AES / EBU input.
USB interfaceXMOS U208
OTG Compatible
ClockTCXO 24.57Mhz
TCXO 22.57Mhz
12Mhz
Jitter4.6ps (2x TCXO)
Low noise regulated power supply(power cable not supplied)
CompatibilityRaspyfi, Volumio, piCorePlayer
Digital outputs1x Coaxial 75Ω : 24bit 192kHz
1x AES/EBU 110Ω : 24bit 192kHz
Optical Toslink : 24bit 192kHz
I2S via RJ45 : 24bit 192kHz
Housing material100% Aluminium
ColorBlack / Silver
Dimensions162 x 114 x 47mm
Weight0.9kg
Power cableNot included
Wiring diagram of I2S output on RJ45 connector
Pin 1 :DATA DSD A
Pin 3 :I2S LRCK DSD CLK
Pin 5 :I2S SCLK DSD B
Pin 7 :I2S MCLK
Pin 6 & 8 :GND MCLK
Pin 2 & 4 :GND
OutputCoaxial SPDIF
OutputI2S via RJ45
OutputOptical Toslink
OutputAES/EBU
Max sampling rate384kHz
Interface chipXMOS XCore U208
12 reviews
Sicuramente un buon prodotto
Ottimo il rapporto qualità prezzo. Suona davvero molto bene, è veloce con una buona risoluzione. Non pensavo di ottenere questa qualità sonora. Purtroppo mancano le istruzioni anche se il funzionamento è molto semplice. Unico neo il led di funzionamento rosso è molto forte se si posiziona l'apparecchio sul fronte. Per il resto un prodotto che funziona alla grande.
This review has been posted for AUDIOPHONICS XMOS U208 Digital interface USB I2S AES 2x TCXO OTG 24bit 192kHz
Parfait!
Le XMOS U208 me sert d'interface entre mon PC et un DCX2496.
Fonctionnant dès le début sous Windows 11, je n'ai pas eu à installer les pilotes.
À l'écoute rien à signaler, très bon.
Par contre la LED rouge haute luminosité en façade se fait trop voyante.
Dick Van de Merwe
The AUDIOPHONICS XMOS U208 Digital interface is top quality. I have spent a lot of money in the past, often a multiple of what the U208 costs, on functionally identical USB converters of less quality, with fewer connection options.
In that light, I can recommend the U208 very warmly. The price / quality ratio is a big 10 out of 10.
The only thing that can be said about the U208 is that it runs quite hot during operation. Make sure there is enough space around the converter.
Installation très facile
Très facile a installé et son très claire et propre. Je l'emploie avec un Monacor DSM-48LAN avec AES et ça fonctionne fantastiquement bien!
Une interface efficace.
Le rapport qualité/prix de cette interface est excellent. Ayant un DAC sans port USB mais seulement des entrées AES/UBU et toslink j'ai opté pour cette interface pour convertir la sortie USB de ma carte Matrix Element H en SPDIF AES XLR. Le résultat est excellent...musicalité, image sonore bref rien à redire avec en plus une belle fabrication et un prix qui ne sombre pas dans les abysses de l'audiophilie
This interface based on the now famous XMOS U208 provides high level digital outputs in S/PDIF coaxial, optical, AES/EBU and I2S. USB has...
