Digital Interface USB Amanero / Bluetooth 5.0 to AES / SPDIF / I2S 32bit 192kHz DoP128
This small, high-performance digital interface takes a Bluetooth 5.0 or USB signal as input and then outputs it in I2S (via HDMI), AES, Toslink Optics or Coaxial. The Bluetooth chip used for reception is a Qualcomm CSR8675 supporting the high-resolution protocols aptX-HD and aptX-LL for high-quality playback. The USB input is entrusted to an Amanero Combo384 chip.
4.8 / 5
Reference : 14869
119,00 €tax incl.
99,17 € tax excl.
Shipping date: 05-05-2026.
Digital Interface
Interface Numérique USB Amanero / Bluetooth 5.0 vers AES / SPDIF / I2S 24bit 192kHz
The source selection is done using a button on the front panel. The interface can be powered directly via USB or 5-9VDC via a DC jack connector.
The HDMi port of this interface is dedicated to audio. It cannot be used to transport a video stream.
Product typeDigital interface
InputsBluetooth 5.0
1x USB-B
Outputs1x AES
1x I2S via HDMI
1x Optical Toslink
1x SPDIF Coaxial
Bluetooth ChipCSR8675
USB InterfaceAmanero Combo384
Supported Bluetooth codecsSBC
AAC
aptX-HD
aptX LL
Supported sampling ratesUSB-B : PCM up to 32bit 192kHz, DoP128 (via I2S HDMI)
Bluetooth : PCM 48kHz
Power supply5VDC via USB-B or 5-9VDC via Jack DC
Housing materialAluminum
Dimensions103 x 88 x 38mm
Weight235g
Package1x Digital interface
1x Bluetooth antenna
1x USB-A to Jack DC cable
OutputI2S LVDS via HDMI
OutputAES/EBU
OutputOptical Toslink
OutputCoaxial SPDIF
Max sampling rate192kHz
Interface chipAmanero 384
4 reviews
Good USB to AES interface
Good Device. Plug and play.
Do note that if you plan to use Bluetooth as primary input you would have to select that on the box with a button every time the device has been turned off.
For my use case it is perfect.
This review has been posted for Digital Interface USB Amanero / Bluetooth 5.0 to AES / SPDIF / I2S 32bit 192kHz DoP128
Working well
Using it for 1 week only, tried I2S and TOSLINK output on headphone DAC/Amp with Foobar and Tidal on Win11. Driver installation without problems, output to the interface showing on the list. Sound is very good, clean and spacious. On few occassions short noise when PC loads a big piece of software, most likely nothing to do with the interface itself. Overall - too short experience to be decisive, but so far so good. With driver installed the interface works out of the box, provides multiple output options, everything as described on Audiophonics site.
Parfait
Transfigure un "ancien" DAC Audio GD NFB 12.1,dont l'entrée USB est trés moyenne.
Avec un bon câble numérique coaxiale (un Audiophonics commandé en même temps),c'est vraiment très bon : Quobuz+Audirvana,avec un PC (en attendant un streamer dédié)
Fait bien le taf
Destinée ajouter une interface Bluetooth à un DACvia entrée optique : interface facilement détectée, fait le boulot sans histoire et sans défaut audible. Une demi-étoile en moins pour le câble alim un poil court dans mon setup, et une autre pour le commutateur d'entrée qui revient par défaut sur USB lorsqu'on met la chose hors tension - il faut accéder au mini-bouton de sélection derrière le bidule à chaque mise sous tension, ce qui empêche de le caler au fond du rack et de l'oublier..
This small, high-performance digital interface takes a Bluetooth 5.0 or USB signal as input and then outputs it in I2S (via HDMI), AES, Toslink...
